View Full Version : Drivetrain (Cooper S)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 [22] 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43
  1. Question about mini cooper s header
  2. bpv removal
  3. 100 octane in LA
  4. Help - Looking for OBX Header Gasket
  5. backfire/ miss during ecceleration
  6. Is the Mini LSD available as a part?
  7. monitoring device
  8. choices choices choices
  9. JCW vs MCS: Same Air Filter?
  10. I need to contact Milltek...
  11. john cooper motorsport race airfilter kit
  12. Alternative to Webb Exhaust?
  13. A Minor Mod
  14. Fireball Tim Hyper ECU
  15. Quiet Header
  16. Oh Yeah!!! 19% pulley, GIAC, JCW injectors
  17. Turbo Video
  18. 15% install question
  19. Sparks after 3000 miles
  20. Official M62 interest list
  21. unichip install
  22. Got Dyno'd
  23. Fidanza Short Shifter
  24. Megan header installed. Power loss
  25. ?'s on pulley install
  26. GIAC Mobile Tuner
  27. Dinan... yet another question
  28. Another 15%-er here!
  29. Mystery code P0234?
  30. alta exhaust problems
  31. Sac Moded Mini
  32. ECU UPGRADE Need True opinion...
  33. need how to on crank pulley install!!!
  34. Empty OCC?!
  35. Thottle body
  36. Belt Tensioner Diminsions Needed
  37. Need engine mount bolts torque amnts... quick
  38. Stock Intake Manifold Removal
  39. Show me your Iridiums
  40. Vibration at idle after larger intercooler install
  41. Louisiana Minis
  42. Custom air intake
  43. So... What do I need now?!
  44. Hot Climate, Cool MINI??
  45. Got my Mini on the 22nd and…
  46. How many s/c reduction pulleys have colder plugs?
  47. Redline MTL = synchro problem?
  48. Helix minisports pulley
  49. alta header what's the story
  50. Umm... is this bad?
  51. MillTech Installed....1st impressions
  52. Pulley Size Performance
  53. Exhaust with Lowest Tone?
  54. m7 throttle body
  55. Bosch injectors and GIAC done by Helix!!
  56. Options for next mod..
  57. Exhaust System Life Expectancy?
  58. Intake Manifold
  59. New Software and i've fallen in love all over again........
  60. From 03 tranny to 05 tranny review
  61. DFIC diverter (alt.)
  62. turner Motorsports Stage 1 pulley
  63. Dimensions for Belt Tensioner Tool
  64. MTH vs GIAC
  65. Is 225-230 whp possible without TC
  66. megan header gasket?
  67. Want to lower IATs 5º ?
  68. Crank Pulley on E-Bay
  69. My Home-Made CAI
  70. ? with dfic mounting
  71. Cosworth Head, DFIC Installed!
  72. Dyno Results are IN!
  73. Dynod the MINI today
  74. Newbie Power Q
  75. VGS mod &/or DT BPV:2006S Have they worked for you?
  76. Fun and Performance at Monterey!
  77. VGS thoughts.....
  78. POW!!! (#4 spark plug) Right in the kisser.
  79. DDM Airbox
  80. M7 versus Milltek CatBack Exhaust
  81. Easy way to tell what size injectors?
  82. When did the MCS get the new gears in the 6 speed
  83. Helix TwinCharged Owners
  84. 15% Pulley...should I add GIAC?
  85. UNICHIP - please join us!
  86. auto upgrades?-
  87. To Dinan or not to Dinan.
  88. Alta hose diameter?
  89. M7 Air Plate Diverter
  90. Help!
  91. after obx install, exhaust smells weird?
  92. Borla exhaust
  93. 2005 tranny with LSD retrofit question...
  94. How high can I lift the engine?
  95. Appointment made for a resonatorectomy!
  96. Why a dual (split) exhaust system is better.
  97. Aftercooler...
  98. under pressure
  99. The incredible shrinking Milltek?
  100. Oil Change Info
  101. DFIC/diverter
  102. CAI w/ Swain Tech coating
  103. On the fence about a catch can???
  104. Clutches!!
  105. Should I go JCW or Helix/Madness/Alta (Turbo's)
  106. I've been a bad...baaad...boy (DFIC)
  107. Chrono pack questions
  108. hosed!!!! help
  109. GRS IC Removed... DFIC Installed (w/ some numbers)
  110. inter flippin' coolers
  111. WebbMotorsports! Not sure where to post comment, so I posted here!!!
  112. custom exhaust opinions....
  113. Palo Uber London Dual Exhaust System
  114. Photos of DFIC after install.
  115. HELP! (Please:)) SES light with P0171 code
  116. Help!!! Alta Big intercooler Air Diverter
  117. Need new brake pads?
  118. BFP Stage 3 CF Intake
  119. diverter valve?
  120. Powercardtuning.com
  121. Idea: direct air to IC horn
  122. Magnaflow Exhaust Theory
  123. BOSCH O2 Oxygen Sensor For The Mini
  124. DFIC w/ Heat Dispersant & Ceramic Coatings
  125. One Ball Exhaust Install - Vibration
  126. Cold weather, more power
  127. Dyno tomorrow. Any advice?
  128. Coolant tank help
  129. Auqamist cooling system. Who is using it?
  130. Bought my OBX header. Now what?
  131. Just installed short shifter and milltek cat-back!!
  132. "Indexing" the spark plugs
  133. IC After 50k miles....
  134. Mini Cooper S Modifications
  135. Auto?
  136. Is this the dreaded Yo-Yo?
  137. That annoying CAI whistle....
  138. Anyone with a AGS V1 out there.. need feedback
  139. Does a 2005 Dinan exhaust fit 2002?
  140. WTB: Alta stuff
  141. DFIC install = speeding ticket
  142. B&B exhaust...
  143. Go Faster with Koni FSD Shocks
  144. Limited Slip Differential
  145. best cold air intake for the money?
  146. intercooler questions - stock and aftermarket
  147. Check out my new DFIC!! It's on!
  148. Dinan / MINI says pulley is the *last* thing to install?
  149. New Clutch - Now rubbing sound
  150. cleaning a new intercooler
  151. JCW Intake -> Alta CAI
  152. Boost loss?
  153. Does pulley upgrade need new ecu?
  154. Normal oil pressure?
  155. Air filter test video
  156. Alta Twurbo/Turbo questions here.....
  157. $2600 to blow.
  158. Denso Iridium Plugs
  159. CravenSpeed short shifter help
  160. R56 Engine transplant into an R53???
  161. Best Short Shifter?
  162. Does anyone still sell the silicone intercooler boots?
  163. Has anyone successfully installed the Alta Box Top?
  164. Dinan Exhaust Clips
  165. Headers!!!
  166. HDI now available direct from DDM
  167. which high flow cat
  168. unichip!!!!! for sale......
  169. Anyone ever do a RWD conversion?
  170. Help with Vac Lines
  171. pix or schematics of jcw exhaust
  172. Motec anyone?
  173. Milltek installed, but tips a bit too high
  174. Dinan CAI with Alta 15% Pulley?
  175. is the 2007 MINI's engine as bullet proof as our current one?
  176. I failed....miserably.
  177. OBX header, OEM Cat, no CEL light
  178. Forget turbos/TC and the like
  179. $500...what next???
  180. M& DFIC parts & Install
  181. question about start up, boost and brakes
  182. Vibration after installing Alta Air Diverter...
  183. mini racing car in BMW brossard
  184. Benefits of water-to-air I/C?
  185. AGS V.3 intake Anyone have installed?
  186. Intake test
  187. who has this header installed ?
  188. Difference in exhaust for 2002-03 and 2005?
  189. Inproved airflow for the AGS...
  190. Will this crank pulley be OK?
  191. Invida Exhaust Installed
  192. Clutch and LSD
  193. All The Great Ones Are Gone
  194. Engine Damper from Sales@shoe-in.net
  195. AGS Numbers
  196. Shark Injector
  197. Has anyone built there own custom exaust with a performance header?
  198. Bleeding clutch slave cylinder-Need help
  199. Need some help with a custom Head!!!
  200. Recommended track set-up?
  201. Supercharger Heat Management
  202. Yay!!!
  203. Requesting info and Pics for the MCSa Pulley install
  204. High Volume Injectors
  205. Clutch Chatter Concern
  206. Engine Light On: OBD code P1683 - Because of Mods?
  207. Direct Air Scoop for the Intake
  208. My Remus is in.
  209. 15% and plugs
  210. Ceramic-Coated SuperSprint Header, w/ Stock Cat
  211. Alta2% Install Complete
  212. Which Intake? Suggestions Solicited.
  213. Alta Turbo kit
  214. Dyno temperature compensation?
  215. OBX header install tips?
  216. Warranty Impact
  217. Aftermarket cat for OBX
  218. Which Belt For 16% M7 Pulley
  219. does a pipercross VIPER kit need to cleaned and...
  220. Exhaust pics (ideas for MC) - french site
  221. Oil pressure gauge bouncing around!!!!!
  222. Installed AGS and have problems
  223. Exhaust RAttles............. :(
  224. Gearbox oil How-to?
  225. plugs
  226. Engine Problems with Lightened Crank Pulley?
  227. Installing CAI
  228. Crank Pulley + Superchanger Pulley Percentage
  229. 05' stock airbox...
  230. PWR Radiator?
  231. Rear Seat..
  232. altanator
  233. MINI Madness Pulley
  234. Help What Do I Do
  235. whats the difference between these two headers (see pic)
  236. 17% SC + 2% Crank + 5% Altanator = What belt?
  237. which aftermarket CAT. do u rec.
  238. OBX Header + One-Ball
  239. Temp probe install
  240. Temperature reduces HP?
  241. Header or 2% crank pulley + sound opinons?
  242. Project M7 Hood Louvers!
  243. M62 SC on the MINI is reality
  244. M7 DFIC shipping this week???
  245. Fun MOD
  246. Someone Please Tell Me
  247. DIY- crank pulley install
  248. First Performance Modification
  249. todays dyno result
  250. Torque steer with engine damper?
