View Full Version : Drivetrain (Cooper S)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 [21] 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43
  1. I need help! which exhaust and intake should i get?
  2. I need an exhaust, which one?
  3. What size piping is the cat back Magnaflow?
  4. The (definitive) scoop thread
  5. High Altitude tuning question-
  6. Best Resenator to quite down a Magnaflow exhaust?
  7. Who has the most HP in their MCS?
  8. GP sc pully size ?
  9. Insulation for DFIC
  10. Alta Crank Pulley for MC
  11. JCW Intake installed today
  12. Here we go again...
  13. O2 Sensor...two white wires?
  14. Comments from M7 DFIC owners wanted
  15. PSE Supercharger
  16. OBX Header Thermal coated? Pros & cons
  17. 19% pulley
  18. Good read on Dynos, HP ratings and things of that sort.
  19. installed engine damper, what do you guys think....
  20. Lost a nut.
  21. What you to can do with a mini, that is powered!
  22. Need some advice here!
  23. Where has BERFER Performance gone to???
  24. Borla XR-1
  25. no bites on wire me???
  26. Digi-tec max power
  27. wire me
  28. New Product from Helix!
  29. Replacing Header Screws???
  30. Whats the best short shift kit on the market
  31. Can someone help as I'm a little confused ref my Venom nitrous kit
  32. WMS SportBox RAF
  33. Any header owners out there? (multiple)
  34. Can you run a Shrick cam/Head with a Twincharger?
  35. hot air extractor
  36. Modified stock muffler
  37. 2% crank pulley
  38. Teaser: Really Big Hole scoop for DFIC
  39. Will this be a better place to mount my venom Nitrous jet?
  40. Any thoughts on this brand PULLEY?
  41. icy cold
  42. rattle from SS catback ???????
  43. FINALY got to install my CAI...
  44. Installed a Larini Header today!
  45. FMIC for MCS?
  46. Pulleys & compression
  47. Works GP intercooler upgrade
  48. Lightweight Battery Questions
  49. gatorback vs. napa
  50. uh oh - my wife's Mini
  51. Looking for a flash in the Midwest
  52. Will a LSD cut down WHP?
  53. unichip help
  54. TWURBO KIT ?????s
  55. Samco Sport Induction Hose
  56. AF's
  57. Time for new spark plugs -- Denso question.
  58. The Best
  59. Alta OCC
  60. Do our MINI's have "Half-Mode DSC"?
  61. What's wrong with this header?
  62. Dyno Run
  63. Alta aftercooler w/diverter or M7 aftercooler?
  64. Alta CAI - alternative filters
  65. what should i do?
  66. Oneball - supplier?
  67. What next? Need your help for future performance mods.
  68. Unichip new "Flux" looks cool
  69. question
  70. Stupid me
  71. apexi turbo timer install help.
  72. alta twurbo vacum routing
  73. CAI Scoops
  74. JCW Kit & SMOG
  75. Ball flange gasket for supersprint header
  76. Do you need to upgrade you fuel pump with injectors bigger than 380s
  77. First modification
  78. Installing Fireballed Head and Schrick cam this month.
  79. Bypass valve?
  80. Dinan intake install instructions
  81. Alta Intercooler, sound increase?
  82. AWD Mini conversion?
  83. A Newby Question Re: Electric Fan
  84. Virtual Exhaust
  85. FIRST MINI, Is 17% safe for occasional redline?
  86. Pulley reduction on S automatics
  87. MTH Header with JCW exhaust
  88. Flex joint importan on OBX header?
  89. need a boost
  90. Messing with the Clutch
  91. 17% pulley (will i need new fuel injectors)?
  92. Mini Works???
  93. Alta silicon hose vs. stock JCW
  94. Alta CAI vs. M7 AGS sound?
  95. Fairly new with ALTA!
  96. PaloUberMINI Exhaust
  97. Wegner Motorsports Built Cylinder Head
  98. Opinions on tuning options
  99. Weird rattle, perhaps ALTA exhaust related
  100. flywheel vs crank pully
  101. Help w/ Unichip
  102. DDMWorks cold air intake
  103. I am reading the local classifieds...
  104. Some random questions
  105. Palo Uber Londen Hoop scoop & DFIC
  106. It just fell off!!!
  107. exhaust flow test data Help...
  108. M7 16% Pulley without 2% Crank Pulley?
  109. How to get 80% thermal efficiency from the stock IC & scoop
  110. ECU GIAC upgrade
  111. MINI Mods and California Smog Check II
  112. Blue Flame Dual Exhaust kit for MCS
  113. Anyone seen this exhaust for Cooper S
  114. Do you need to upgrade the rear brakes with BBk in front?
  115. Sequential Shifter Interest?
  116. Anyone In the Los Angeles Area??
  117. OBX header - cut off OEM cat
  118. M7 Occ
  119. Intercooler Theory
  120. My plan: Project Improved Daily Driver
  121. Not much different after pulley?
  122. Palm OBD II Readers
  123. Getting Crap from Outmotoring...
  124. Shifter/Exhaust question
  125. Silent performance mods.
  126. New to Engine Mods
  127. Ethical Dyno #'s
  128. Dinan + Header & Intercooler
  129. K&N Typhoon Problems???
  130. Flat spot between 3000 and 3700 RPM
  131. My plan - comments/opinions welcomed
  132. Already have LSD = Price Break on JCW Kit??
  133. Borla Header / MC Magazine Misprint?
  134. Stahl Header & CAT back system
  135. Do MCS have a CDV? Clutch Delay Valve
  136. How to Reduce Power
  137. OBX+One-Ball sound clips!
  138. Re-Designed Magnaflow
  139. Fireballed Twincharger Kit
  140. why i didn't go to work today
  141. Pulley and brake in.
  142. spacers
  143. 218 HP?
  144. heads and cams? what HP should I get
  145. Horsepower related to my upgrades...
  146. I got Fireballed today!!!
  147. Plug Heat Range Help Needed
  148. Who is running Cat-Less?
  149. I've narrowed it to 3
  150. I am thinking about a MCS to trick out....
  151. How much should I pay to install a turbo?
  152. MyMini exhaust or blowing through a straw
  153. Pistons/Rods
  154. Limited Slip Differential Input - Top Gear
  155. Which belt for pulley?
  156. quick question:
  157. anyone have a pulley puller?
  158. menu of performance upgrades on 's'
  159. Heads...a discussion
  160. Lighten Crank Pulley or not?
  161. Best CAT back?
  162. I've got a squealer thanks to Pilo Racing
  163. detroit tuned!!!!!
  164. My mods increased my fuel economy!
  165. What does the m7 180 degree thermostat do?
  166. Switching cams
  167. sending units
  168. Question re: M7 AGS intake
  169. Torque Setting?
  170. Oil Pressure Gauge Problem HELP!
  171. Uprated Main Bearings
  172. FORD LSD who knows the part#
  173. Front strut bar with CAI
  174. Milltek Exhaust Installed!
  175. ECU reset after GIAC flash...
  176. Making the Alta CAI colder
  177. Where to buy other than a dealer?
  178. Alta CAI = Loss of torque?
  179. New "Project"
  180. how do i fill this gap?
  181. what to do? M62 or Alta turbo kit?
  182. s&m
  183. who has used ultrik parts?
  184. 4-1 vs 4-2-1 Headers
  185. Helix short shift installation problem encountered
  186. Modded my JCW intake (no pics)
  187. power loss
  188. Need Help with warped SC
  189. Hood Vents (part 2)
  190. True or False?
  191. Intake Question?
  192. where to buy a side exit muffler???
  193. Eisenhaus exhaust
  194. Upgraded Lower Engine Mount
  195. Exhaust suggestions.........
  196. NGK iridium part number?
  197. 05 exhaust on 02?
  198. Interesting "problem"
  199. odd liquid
  200. cranks alot
  201. ? for those that have knowlege of a 'going bad' motor mount...
  202. help ECU plugs wont budge!!!!!!
  203. Best CAI?
  204. Difficulty to replace pulley belt?
  205. Fuel has relation to SC boost?
  206. 2003: Power steering noise
  207. ALTA Intake
  208. Types of LSD explanation needed.
  209. M7 16% Pulley Installed...
  210. Larger injectors - when do you need to bump up?
  211. How do "ECU" upgrades work?
  212. Another software option?
  213. Seattle Pulley Installer?
  214. Improving / Cooling down the HAI
  215. OCC Does Work!
  216. 2005/6 MCS Project Vehicle Needed
  217. TC and M62 Comparison
  218. Helix to release m62 kit?
  219. DFIC Installed - Flat Spot Gone!
  220. LSD Interest/Group Buy??
  221. Alta Sporttone
  222. Headers....which one....why?
  223. Madness JCW intake direct fit high flow filter replacement
  224. Alta Exhaust Fix
  225. oh boy oh boy !!
  226. belts-not whiskey
  227. OBX header... how good or bad
  228. JCW Airbox Flapper Mod
  229. Pre-Installation Question: Borla Exhaust
  230. Ebay Race Header
  231. protection?
  232. Good place to dyno in LA?
  233. pulley head to head comp
  234. Slipping 15%pulley
  235. LSD ... I don't have one.... is it worth it?
  236. Lightweight Crank Pulley
  237. 15% + 2% vs. 17% + 0%, which is better?
  238. Crank Pulley Busted
  239. Gatorback belt part number?
  240. MTH versus FTR reflash
  241. 15% Pulley Addition - effect on gas mileage?
  242. Webb Stage One Kit
  243. Spark Plug Cleaning Techniques
  244. m7 Exhaust Pics and Video
  245. supersprint catback RATTLES !!!
  246. HELP!!! crank pulley got torn off
  247. Is Borla "sport" Worth The $$$
  248. Dealer problem w/15% pulley?
  249. Supercharger Intake Tube Help.
  250. bought JCW intake, reprogramming needed?
