View Full Version : Drivetrain (Cooper S)
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43
  1. Where to find hex standoffs
  2. stage kits anyone?
  3. JCW CAI or
  4. Cutting off cat on Cooper S
  5. Any tuners in colorado?
  6. Do I need to bleed the brake lines?
  7. Also looking for exhaust options...
  8. Dinan exhaust or Tsudo?
  9. Help--asap brake rotor removal torx bolt
  10. Pulley or Intake first?
  11. RMW's new race inspired CAI
  12. Ballpark HP based on mods
  13. Squishy Brakes >:(
  14. Does adding W/M Injection require ECU Tuning?
  15. r53 ecu tuning?
  16. TPR-2 build
  17. NGK BKR6EIX #6418 Gap Question for MCS
  18. Start me up
  19. Catback exhaust opinions needed
  20. Engine Damper Issue
  21. Coolant Overfull by 16oz-Advice PLS
  22. Fuel injector adaptors
  23. I lost my RMW tune!
  24. Nashville Tuner
  25. who is THE BEST TUNER in So Cal???
  26. Godspeed TMIC
  27. Finaly its Pulley time!! any tips?
  28. Powerflex gear box and lower engine bushing inserts
  29. Take a look at my ride!
  30. Help intake breather tube valve cover
  31. The Mini is about to undergo surgery, any advice?
  32. Horrible Sound!
  33. Looking for a nice loud exhaust
  34. ebay exhaust?
  35. Help w/ a guide to servicing our supercharger
  36. Question about damper (SC tensioner shock)
  37. Loudest Intake?
  38. Anyone delete the resonator on their Milltek/Stratmosphere exhausts?
  39. M7 / Venom nitrous question
  40. Wife's observations after driving my car (her car is stock)
  41. Throttle Response besides using Sprint Booster or Detroit Tuned Bypass Valve
  42. Pulley problems!
  43. Sprintex
  44. Poorman's Intercooler Diverter type modification..... $17 bucks total
  45. Engine Slow Off Idle
  46. Twincharging R53 (Turbo and Supercharger)
  47. Shops in Fort Lauderdale or Miami, FL
  48. Cranking takes too much time.
  49. MC R53 Turbo
  50. How is your car suppose to boost
  51. Clutch Replacement Suggestions
  52. need torque specs
  53. 04 to 05 transmission swap
  54. Questions about a CAI
  55. eBay huge intercooler for R53 anyone?
  56. New Dinan CAI anywhere?
  57. Dinan to ALTA CAI?
  58. r56 turbo system on r53
  59. What Comes First, Then Next
  60. bypass valve vent to atmosphere
  61. loud m45 supercharger
  62. Where to find these parts for AUS ?
  63. Header w/o retune?
  64. Data from autoX runs
  65. I am 99% sure this is a stock pulley but...
  66. Whats the best exhaust?
  67. Belt squeal only when cold (M7 pulley, JCW belt)
  68. Home-made Cooling Project Done!
  69. 15% pulley
  70. Dinan Pulley Installation Instructions?
  71. 2% Crank Pulley
  72. Will low compression cause a code?
  73. Bimmian & Simota CF Intake
  74. straight pipe exhaust question
  75. New Pulley!!
  76. should I be running brisk plugs?
  77. Computer
  78. How much power is to much power without a LSD
  79. Injectors
  80. car wont start??immoblizer
  81. Intercooler
  82. custom exhaust build thread part II
  83. Anyone know where to buy the OBX header?
  84. Supercharger bolt M10X40, what PITCH is it?
  85. Mini Love part II
  86. Exhaust flange-header side
  87. Belt size for pulley
  88. spark plug popped out
  89. HEAT Intercooler
  90. Time for new injectors and O2 Sim?
  91. intake and 15%pulley
  92. Anyone tried Microlon?
  93. OBX header donut Size
  94. Caliper Bushings
  95. HELP PLEASE!! Something is leaking ONTO my exhaust piping....
  96. Cylinder head swap
  97. best place to purchase go fast parts
  98. Pulley question
  99. Another Pulley Thread, SORRY!
  100. Custom Header with de-cat, engine light on!!!
  101. Mod question
  102. Which is a better delete pipe?
  103. new valves and springs
  104. Megan Header and One ball?
  105. tune in the St Louis Area?
  106. Thinking of swapping out Milltek header/exhaust
  107. Hole in Alta exhaust?
  108. Stage Upgrade help
  109. Stock pistons?
  110. 2005 cooper s aftermarket clutch problems
  111. best downpipe for the Mini 2008 S
  112. Smoother Shifts?
  113. heat shield
  114. 06 MCS Clutch
  115. what do you think about ebay tsudo catback
  116. $50 - $60 per horsepower
  117. Tuning and Torque steer. My observations FWIW
  118. Carrillo Rods - R53
  119. Thoughts on Oil Catch Cans?
  120. WP Pro 6pistons Calipers
  121. Is smoother shifter feel possible?
  122. When is it time to install new injectors!?
  123. Custom Garage Intake System - Handmade :)
  124. Blow-Off Valve
  125. Dinan intake install template?
  126. MCS 2002 noise from the engine "Help"
  127. MCS 2002 noise from the engine "Help"
  128. Hissing sound after JCW resonator delete
  129. Which clutch release bearing?
  130. Squeaky/stiff clutch pedal when engine warms up?
  131. If i got a S/c pulley do i need to upgrade the inectors?
  132. ireland engineering exhaust sounds so good....
  133. apexi safc
  134. Need opinions..oil leak after pulley job
  135. 05 MCS Auto - Bad Idea?
  136. Buying a Mini with a code on it? Bad idea? Need help
  137. Pulley at 100k?
  138. Anyone near Chico Paradise Oroville with a puller?
  139. Twincharged Mini?
  140. Invidia exhaust install problem
  141. NM exhaust on '11 MCS?
  142. Running lean at full throttle.
  143. NEW Stuff At ALTA (again)
  144. Strange Whine - SuperCharger?
  145. RMW dyno tuning DC area May 13-14
  146. Detroit BPV Install Problems
  147. Engine Damper
  148. What is this?
  149. LiquiMoly CERATEC
  150. Supercharger Removal DIY...anyone have one?
  151. oil in #1 plug; others ok....need advice
  152. SC pulley install help in the bay area
  153. Custom Garage Headers & Exhaust System with Videos
  154. Stratmosphere Resonance?
  155. engine blipping by self when lifting off throttle
  156. Exhaust Question
  157. Installed new ALTA CAI 2.0
  158. Which injectors with these mods?
  159. Colder Spark Plugs - mostly stock
  160. please help, oil pan is leaking from gasket ..
  161. Opinions Wanted - Best and most efficient boost sources for a mini
  162. Any thoughts about this exhaust?
  163. mini racers please come in. need help with making a decision on which exhaust to get
  164. Installed JCW exhaust, Battery box heatshield wont fit.
  165. Finally getting some extra HP
  166. What mods are on this MCS?
  167. Supercharger Maintenance
  168. why pay 150 for a diverter?...
  169. what would happen if.....
  170. Help Reading My Spark Plugs
  171. Final Drives
  172. best way to removing the pulley with out the tool?
  173. Heat after helix SSK install
  174. 380cc Enough With tune? or 450cc
  175. Anyone use the Shark Injector flasher?
  176. RMW Header Porn
  177. Questions about the pulley job, Pls help!
  178. Ported head.. Will the stock ECU take it?
  179. No mods for this year...health problems :(
  180. Bavarian Auto spark plug wires?
  181. Renting Tensioner Tool
  182. Belt Tensioner Stop Broke?
  183. Stripped Spark Plug Hole
  184. Need some help with air intake...
  185. K&N Typhoon CAI
  186. Supercharger noise / Remove and replace DIY?
  187. What ECU to get???
  188. WMW 17% pulley installed
  189. stock injector spec's
  190. Finally installed the DDM Diverter
  191. upgrades!!
  192. Coilpack relocating bracket
  193. no pops or bangs
  194. low compression? upgrade time? i think so...
  195. Steptron Trans clunks down into 4th can it be fixed
  196. Are 6 Speed Steptronics Repairable?
  197. Alternate tool for supercharger removal
  198. Ticking sound from pulley?
  199. jcw intake wiring
  200. How can I tell this is a Schrick Camshaft?
  201. mini newbie which one to buy?
  202. supercharger bypass valve sound?
  203. Winning
  204. Supercharger back from Stiegemeier
  205. Which aftermarket clutch is better?
  206. 05 MCS Crank Pulley replacement- won't come off
  207. Project Bluey: Modding my MCS
  208. Ok needing some help here =(
  209. Gasket
  210. RMW dyno tune in CT, April 11-14 sign up now.
  211. ACT Clutch/PP/Flywheel Question
  212. bushings and clutch time...
  213. Differentials
  214. Fuel injectors, please advise?!?!?!
  215. What about just a pulley kit?
  216. Just picked up new exhaust
  217. M7 DFIC question
  218. new exhaust?
  219. 15% Pulley Requires Aftermarket Exhaust?
  220. OCC on supercharged MINI?
  221. Torsen LSD - Chime in.
  222. R56 JCW Front Calipers
  223. dented muffler = big issue?
  224. exhaust, header, cam???
  225. Wheels v. Tires
  226. Dinan Supercharger Kit
  227. Retrofit liquid filled motormount
  228. Best place to purchase Magna flow?
  229. DDMWorks CAI Question
  230. Supercharger noise after pulley install
  231. New Parts
  232. Will a 2005 exhaust fit a 2003?
  233. What if.....
  234. r53 air intake question
  235. Ported Supercharger
  236. Pulley or CAI
  237. Whine in reverse after clutch change?
  238. Aftermarket Companies that sell superchargers?
  239. Custom Exhaust Thread
  240. Borla Universal Muffler
  241. Alta exhaust vs. Borla Sport. Which is louder? (R53, 2006)
  242. Thoughts on modifying...have I lost the spark?
  243. Dinan Throttle Body
  244. Megan Header
  245. Can I prevent valve build up?
  246. Best way to replace input shaft seal?
  247. Mini Cooper GP Intercooler
  248. Cold Air Intake Recommendation for R53 S
  249. rmw Rochester tune party???
  250. What exactly does it mean to rebuild a motor ?
