- 412whp still has a cat!
- Impressions on MyMini JCW Exhaust Resonator Eliminator
- GT Tuning pulleys
- Separate Alta Diverter Squirter Reservoir?
- MSD's DashHawk - Anyone look into this yet?
- Added VGS to DT BPV
- IT's ALIVEEE...it's alivvvee... mods
- Alta Exhaust tips melting plastic
- 15% pulley w/o ECU remap
- Crush Zone on factory JCW exhaust
- one ballin
- MINI-Madness Turbo Only
- Turbo, TwinCharge, M62 etc.
- 1st mod
- Boost Gauge Buzzing...
- 2007 MINI less mod friendly?
- SC Drive Shaft Diameter?
- Help with low boost
- Just installed Megan Headers
- 300+whp PUMP gas Turbo Mini
- The FAD works
- Intercooler boots.
- Post Your DYNO Sheet Here
- Magnaflow+Aero bumper for MCS(C)
- Purpose Of the VGS
- progressive water injection system
- Engine Dampers
- Borla Race Dimensions
- Mod bug finally bit
- GP flash vs JCW flash
- intake tube insulation
- GIAC/19%/Injectors vs GIAC/Intercooler/header
- Borla Street Or Great Deal On Magnaflow
- Alta vs M7 DFIC
- Best bang for buck mods
- FBT, anything new to market?
- Hartge exhaust anyone?
- Removing firewall for intake?
- Sorted out turbo conversion
- "Stock" 04 JCW upgrade paths
- Comment needed..This boost amt correct?? (CAUTION : VERY Long with DYNO graphs!!)
- Engine burns oil??
- Restting the ECU
- JCW Flap Removal = AWESOME!
- Considering these mods
- 19%-GIAC-JCW injectors dyno
- 93 octane
- CAI - Ok for the Desert SouthWest?
- Stage 2 Head, need some input on,,
- anyone with pinging problems
- any other mini pinging under boost
- JCW Cold Air Intake (CAI) Race Version?
- My Own Engine Dampener Brackets
- AWESOME deal on turbo mod !
- Crank pully for $20 ???
- OBX LSD Pros and Cons?
- bastuck II exhaust
- 19%-injectors-GIAC owners, unite!
- Ford SVT LSD fitment
- Timing Case Cover
- The Detroit Tuned Bypass Valve
- Do any aftermarket flashes learn like the stock ecu?
- Pully questions
- Pulley reduction - Lack of "smoothness"
- DFIC mods
- HELP! unichip Flat spot!
- aftermarket axles
- Performance Mods vs. MPG
- Unichip ECU maps / injectors
- Best Lighten Flyweel that will not CHATTER?
- Exhaust Gaskets - Need Help
- ADVICE on 0% or 2% Crank Pulley
- pretty new
- Injectors and 15% question
- Densos after 10K miles - Please Comment
- Pulley 17% or 19%
- Exhaust advice
- Who here has a twincharged or turbo only daily driver?
- Borla RacE exhaust Tip measurement??
- unichip help......
- removing a pully
- How well does giac 15% work with more extreme mods
- anyone with problems with big bore throttle body
- Milltek Warranty Trasnferable?
- 62 kit on its way to M7 ... Yes it is happening
- Having trouble mounting GRS IC
- junk inside my IC
- after head;
- Epod + Defi Gauges!
- anyone interested in a turbo
- Fireball drag car going to amviv?
- Difference between the cold & hot Nology wires
- Noobity tranny/clutch question...
- Larger injectors?
- 6spd gear ratios
- How to Lower shifter knob but avoid interference with Borla system
- All wheel
- Milltek installed today
- Cam Numbers ?
- OCC what makes a good one????
- Broke the Ram air pipe...AHHH
- DSC switch off with 15% pulley
- picture of new header for the M62
- Crazy Super Dupper Cooper??
- Quetion about GIAC/MTH
- Why are there so many Unichips for sale?
- UUC Motorwerks MCS Exhaust Pics
- Stop Watch vs Seat of the Pants
- Some power thinking .. please validate
- Help with mods
- Great resource for exhaust "stuff"
- NEW Milltek Exhaust for the Mk2 Turbo Mini...
- Skipping gears, like my Dad does?
- Apexi SAFC2 settings
- Newbie question
- JCW CAI filter change
- So Many Cold Air Questoins!
- Ok so going to Shanghai...
- information about lightened crank pulleys
- Supersprint exhaust....
- Turbo spool and lightweight flywheel?
- One Ball Modification
- Alta classic? or 2.0?
- 06 MCS Dyno results (mostly stock)
- just installed madness water to air intercooler!
- Santa brings DDM CAI
- Just a little fun before getting JCW kit. Err... my way
- Pace Products- Top Deck™ Combined Chargecooler Kit
- pulley, injectors & GIAC install question...
- Are there any Lysholm SC kits for MINI?
- Pilo Green filter = which K&N replacement?
- WAY WORKS 17% pulley
- How much shorter is the Alta short shifter in the middle position?
- Problems M7 ags and my TAC... HELP!!!!
- Is the middle setting on the Alta shortshifters best or the shortest throw?
- Turbocharger
- Alterator pulley
- Service Engine Soon Light and Problems
- Advice on new head
- LSD Question
- Schrick Cam with JCW Head?
- More HAI and IAT numbers
- 15% pully Drive belt????
- Plug gap
- Used Parts, Cooper S, where???
- What mods can I do....
- Oil Cooler Size & Changes in Pressure
- anyone know of a good place to get Dinan
- Installing- Bypass Valve, OCC & VGS????
- Magna Flow questions...
- Limited slip diff
- Helix (15% Pulley, Bypass Valve & Milltech)
- MA suggests the Shark
- M7 Aerogel Heatshield for the DFIC
- FWIW Has anyone dyno'd their car before and after header install?
- An Exhausting Decision
- High Performance Outlet phone number?
- Should I trade my MINI
- Trouble Installing Pully
- Dry Film Lubricants
- Part# for JCW pulley belt, help
- Broken hanger bolt during install
- anyone heard of this exhaust?
- B&M shifter
- My little Forge intercooler & GIAC ECU review
- lowering engine after s/c pulley
- Loud “clacking” noise after pulley install?
- Battery box metal shield
- Exhaust leak or not?
- advice on R56
- Received first official mod!
- Lohen/Superchips Bluefin re-map any good?
- what is a smooth sounding exhaust (not loud)
- M7 DFIC vs Alta V2 vs Milltek Header
- Losing boost with Unichip?
- someone know this intercooler?
- While I was urious about the powertrain upgrade path for an '06...
- what is the optimum WHP and TQ
- Quick JCW Intake Question...
- supercharger seizing?
- Has anyone upgraded their JCW with Madness stage 1 or 2 kit?
- Pipercross Filter ?
- AFE Install Experience
- OBX vs Megan Headers
- Eaton TVS R900--who will be first to market?
- Nos
- GIAC Flash
- Got BOOST?
- Cheap LSD?
- 200 WHP not possible without head/cam...
- Gintani air to water intercooler
- WEBB Still around?
- Other than Supertrapp, what exhaust for GS?
- Help! Service engine soon light after installing headers
- I need a little more noise
- Power Conversion
- Bad experience with Alta Twubo kit
- Interesting water to air intercooler...
- Endyn stuff: First impressions.
- Anyone Order From Outmotoring ?
- Stupid question.
- Alta 17% version 2.0 installed.
- Need clutch and more,maybe, High Perf.?
- JCW+Schrick or 2% Crank pulley??? Anyone?
- Is there something wrong?
- Custom short-shift
- Educated guess...
- Could I install?
- Is it worth doing the big intercooler?
- ITG. JCW replacement filter.
- Detroit Tuned Bypass Valve
- Cosworth Head and Cam?
- Post Your Gauge Readings
- Raced 04 MBZ E500.
- OBX MINI Cooper S Helical LSD Limited Slip Differential
- There is A Ghost in My MINI
- Clicking sound under the hood. What is it ?
- Clutch replacement delimma
- Gauges...finally
- How to build Touge monster MINI?
- First post! First MINI! First question! LSD?
- 4 wheel'en MINI
- Ultimate Upgrade 20k
- Air Intake My Way.
- Calling all chemists/ physicists
- New 215/40/17 GY F1 GS-D3 shoes
- ECU Upgrades - GIAC or Shark Injector
- Large Core aluminum Radiator?
- Anyone have a Palo Uber exhaust?
- Heat-soaked surface temperature measurements
- Measuring and logging
- What am I doing wrong?
- i feel my front wheel shaking ~,~
- New kind of yo-yo?
- YO-YO at 5000 rpms!?!? Suggestions??
- Craven Short Throw Shifter and Whalen Knob
- LOTF (Shoe) Engine Damper Review
- One ball today !
- Hood scoop question.
- unichip help
- Please I Need your Help (Headers)
- Crank Pulley Installation DYI
- Would this work on the MCS?
- Does anyone knows...
- Best tuner on a dyno in the Southern Ca area?
- Oh crap, my buddies trans blew! Help!!!
- Helix vs. TSW dampers
- Installed M7 strut brace, TSW motor shock and brake mod
