View Full Version : Drivetrain (Cooper S)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 [18] 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43
  1. Danger of water without driver's side bulkhead?
  2. CP pistons or Wiseco?
  3. New oil cooler (picture warning)
  4. JCW Air Filter help needed.
  5. Late model JCW exh on early production MCS?
  6. thinking about modding
  7. Suggestions for Coil Packs
  8. whos the cheapest for wiseco pistons?
  9. What are the top 4 ways not to blow up your motor?
  10. Are Wiseco pistons a good performance stepup from stock
  11. How to intall head info needed
  12. What happened to the Webb exhaust?
  13. Cooper S Automatic, refilling gearbox???
  14. Air filters and engine wear
  15. i need your guy's opinion if you would so kindly
  16. Bizarre issue
  17. JCW Tuning Package *Retrofit* PRICE
  18. JCW gurus - need your advice ASAP!
  19. Alta CAI Question - Remove the rear partition?
  20. How much are clutches?
  21. S. Florida Pully Install
  22. install tomorrow
  23. yipppeeee!!!!!!
  24. 180 Degree Thermostat....Worth it?
  25. What to do?
  26. Engine is using oil ,if i need new rings and pistons which offer good performance ?
  27. M7 STB - Where to buy?
  28. TWIN Charge Set-Ups
  29. New M7 product
  30. Who has a Twincharged daily driver and whats your HP?
  31. HYDRAULIC HANDBRAKE HANDLE
  32. blow off valve
  33. Twin Charged and Cams?
  34. exhaust question
  35. Alta V2.0 pulley - any thoughts?
  36. TSW Engine Damper Installed
  37. Clutch pressure plate
  38. 478 WHP
  39. Magnaflow exhaust ID needed!
  40. is a header worthwhile?
  41. O2 sensore leaning out ari/fuel mix...
  42. Broken O-ring around oil filter housing...
  43. ENGINE SWAP
  44. Jackson racing header...Anyone?
  45. Comparing different replacement panel filters
  46. dinan intake and M7 strut tower...
  47. How do I get the @*&#! plug wires off the plugs??
  48. ALTA V2
  49. DIY intake: cutting a hole through the back wall
  50. AGS V.3 air filter replacement?
  51. Got my ECU back from Lucky Dog Garage today!
  52. GP intercooler installed
  53. Panel Filter replacement recommendations
  54. SuperCharger Clean?
  55. please help
  56. ALTA Water/Methonal Injection Results!
  57. $3,000.00 for a new clutch/flywheel...
  58. Hydra EMS
  59. Urgent, need help
  60. if JCW's flap open??
  61. Stuff Keeps Dying
  62. Let's Talk Air Intakes..
  63. Remap? I need it? Lean mixture?
  64. Compare/Contrast Different Intakes
  65. Serious Issues! Need input!
  66. new clutch in 2002 MCS...it don't feel right!
  67. P1125 Code - help?
  68. What size belt for the JCW pulley?
  69. resetting the ecu
  70. Webb Intake broken??
  71. Help! Removing M716% for Alta V2
  72. borla sport vs magnaflow
  73. who has alta's header
  74. Radford Mini Miglia info
  75. pistons?
  76. Installing Quaife, what else when everything is down?
  77. P Fault Codes from OBD 11 Reader
  78. Oh So Happy..
  79. Joined the Pulley & Sway Club today
  80. Flapless JCW intake vs Green or K&N panel filter
  81. I broke it :-(
  82. Dinan or JCW for 2007 MCS cabrio
  83. exhaust question?
  84. MCS ECU MAP
  85. anyone with 17%pully and stock injectors do GIAC
  86. Air filter question?
  87. Performace Exhaust Question
  88. 19% pulley plus 0% crank pulley?
  89. Oil TEMP?
  90. Why are pulleys illegal
  91. Stock Pulley Reinstallation
  92. Reviews on M7 Thermostat...?
  93. Tensioner Tool Plans
  94. Finally installed my Unichip
  95. Alta vs, K&N vs, JCW vs, DDM HDI vs, Webb RAF
  96. Pully Install in Minnesota??
  97. Fact or Theory? 15% + stock plugs = detonation
  98. 231.9WHP with new big valve head. Stock cam and ECU.
  99. Flow Rates of the Stock Injectors vs the jcw Injectors
  100. Will the One-Ball Satisfy?
  101. ESP Problems with 19% and GIAC
  102. 17% S/C Pulley & 2% Crank
  103. Quaife LSD/Clutch Install help
  104. The real deal at Lucky Dog Garage
  105. Not all performance parts are complimentary to one another!
  106. idle problem
  107. more boost???
  108. quick question about m7's super charger
  109. Axel Nut size?
  110. Final Drive... continued
  111. headers
  112. what Pulley to pick?
  113. If you could see through the bonnet...
  114. M7 AGS opinions
  115. Alta upgraded fuel pump?
  116. Pulley size question
  117. NGK Irridium or Denso Irridium
  118. Modest gains on my MCSa
  119. FI induction and headwork? Why?
  120. Need help! Power Loss!
  121. Justa Catback on an MCS?
  122. Header install - how hard
  123. NEED HELP brake vibration
  124. Spark Plugs
  125. Cam Swapping
  126. ALTA 3'' Exhaust Installed
  127. Deluxe Pulley Tool Which Vendors Still sell These?
  128. Boost Gauge Install
  129. One-Ball exhaust parts available?
  130. Pulley detection
  131. a Couple of Thoughts on ICs...
  132. BLOW OFF/ DIVERTER? can i ?
  133. The few, the proud, the 3" exhausts.
  134. New Palo Uber Dual Exhaust
  135. Cosworth Head & Cam replacement
  136. 2% crank + 17%sc need new belt?
  137. Milltek, Borla S, or JCW Exhaust?
  138. Engine damper installed!
  139. Video of Mini at a real dyno
  140. Alta intake just installed!!!!!
  141. Mini Madness Air Filter
  142. Noise and vibration with Milltek Catback exhaust
  143. Off these headers, which will be the best
  144. Cat. converter question
  145. Ok, Now I'm sure I need a new belt tensioner.
  146. Best Performance Upgrades For Cooper S?
  147. "BBR" Mini, at 275 bhp!!
  148. HP Guess? Next Steps??
  149. variable drive pulley for supercharger, 25% to 13% available
  150. Big power with the obx + one-ball combo?
  151. Quaife LSD/Clutch Install
  152. CAT camshafts
  153. Fumoto Engine Oil Drain Valve
  154. Has anyone here put a header on an MCS Automatic?
  155. How Much Boost PSI
  156. oil catch can
  157. Yep...
  158. Oneball vs Catback
  159. New: could experts answer questions about mods?
  160. Oil Catch Can at work....
  161. Flat Spot with Unichip - Randy?
  162. M7 thermostat
  163. Alta IC Air Diverter Install
  164. Question
  165. No Brainer FWIW...
  166. Quick seafoam question
  167. Show us your shift light
  168. Resetting Check Engine Light
  169. DIY One-ball?
  170. Need advise on how to replace an air filter
  171. Exhaust idea-crazy?
  172. balancing act.
  173. Blue Flame Exhaust...
  174. Service Engine light gone?
  175. spark plug wires
  176. Webb Pulley Party in Boston?
  177. New Method to support AGS - DYI
  178. Can I use the M7 16% Pulley with a stock belt...
  179. JCW Injector Install Question
  180. brakes
  181. Who has a Twin charge or turbo only set up
  182. Dynos & Tuning
  183. anyone with 78mm pistons?
  184. Milltek Exhaust Help
  185. New Tune, Header and Injectors
  186. K & N Filter on an Alta box?
  187. Incredible Whine!
  188. Spot a twin-charged MINI @ Helix
  189. Choosing one pulley vs another
  190. Crank Pulley Bolt-Part Number?
  191. anyone have a phantom grip lsd ?
  192. M7 AGS v3 install instructions???
  193. Where to get Mini-specific Mod's done?
  194. Tranny fluid replacement
  195. intake question
  196. swepco 201 gear lube-anyone tried this?
  197. want either a msd or screamin deamon coil,who's cheapest??
  198. Too much boost?
  199. how big of a tire can i fit on stock 17" wheel
  200. Who is the cheapest outlet to purchase a PALO UBLER bonnet scoop from??
  201. Is your MCS JCW underperforming? Read this...
  202. Rear hanger interchangability?
  203. LSD/Clutch/Lightweight Flywheel
  204. Invidia exhaust installation ?
  205. overhaulin'
  206. ever been here??
  207. Oil Pressure higher at startup
  208. what would it cost for JCW mods but aftermarket
  209. anyone have an evotech chip and have any problems
  210. Just released... New ALTA SC pulley!
  211. DT BPV Installed Today, WOW!!!
  212. Used pulley?
  213. BBK options
  214. Palo Uber Titanium Reduction Pulleys
  215. Back Pressure - Hissing
  216. Cooling Mist Boot Mount Water / Meth injection kit
  217. no puffy cloud!!!
  218. Eeek. Did I get the wrong plugs?
  219. Thermal tape'd Alta CAI
  220. Anyone ever use an NPT Tap? How to?
  221. Vgs=p0171
  222. Alta CAI cleaning time-maybe
  223. Exhaust rattling (Gaskets? Heat-shield?)
  224. M62 dyno numbers
  225. Borla's lack of customer service:
  226. Aquamist Water Injection
  227. First Real Upgrades
  228. 3 mod 300 dollar 2 many smiles to count
  229. Blew head gasket after head upgrade!!
  230. JCW intake install question
  231. Alta Air Intake Hose on JCW Box?
  232. Quicksilver Exhaust
  233. Firewall demolition
  234. switching pullies without the extra work?
  235. M7 DFIC, OBX Headers or,(yes I know its suspension) NEX Coilovers
  236. Milltek Exhaust Advice
  237. Does anyone know what mounting hardware comes with the ALTA intake?
  238. Questions Engine Bushing
  239. Installing the Detroit Tuned Bypass Valve
  240. Alta Intercooler Air Diverter with Sprayer
  241. What kind of improvement we're looking at
  242. Blue exhaust ( smoke )
  243. vent to atmosphere bypass
  244. Fireballed Turbo Vid....
  245. JCW Exhaust Replacement Recommendation needed
  246. GIAC Impressions
  247. MCS: OEM and JCW, external sizes. Please help
  248. Crank Pulley install help...
  249. JCW + 15% Pulley = worth the time?
  250. Who needs a 36mm Oil Filter Socket?
