View Full Version : Drivetrain (Cooper S)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 [17] 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43
  1. One-ball photos, videos, exhaust tips
  2. General header question
  3. SuperCharger Install
  4. oil quantity
  5. K&N Air Filter Drop in??
  6. 3" Custom downpipe to twin cans
  7. Endyn Rollerwave piston installation
  8. Fixing the stutter.
  9. Project "Low IAT"-Intake Manifold Cooling
  10. does the promini/bmp intake fit under the m7 strut tower brace?
  11. Intake/exhaust combo recommendations
  12. Cleaning the Inside of the Intercooler
  13. which ones?
  14. Belt Size Chart
  15. What size belt do I need?
  16. Alta 17% Reduction Pulley
  17. compressing rear wheel caliper piston?
  18. ticking
  19. Leaking Oil, do I believe Service
  20. Request for help
  21. Halfmoon Auto
  22. Best place to buy Invidia exhaust?
  23. Port & Polish Intake Manifold?? worth it?
  24. front mount???
  25. Alta intake help for MCSa
  26. AHHHHHH My AFR Help! (Dyno inside)
  27. How to make one-ball to sound a bit meaner?
  28. no boost:(
  29. Water to Air intercooler
  30. Alta CAI v2?
  31. 380cc injectors with other mods, noticeable perf. upgrade?
  32. HELP! Over Boost Question
  33. Fidanza flywheel and OEM clutch
  34. Do I need a JCW charger belt with a 15% pulley
  35. Stumble & Lurch, best solution mods?
  36. Alta Exhaust
  37. Newly installed STRI Boost Guage Question
  38. Tensioner Pulley
  39. Installing Engine Damper...please HELP!!
  40. Where to Start? Please help!!!
  41. Problem starting after VGS mod
  42. Little confused so can someone just clarify this please?
  43. Want to trade water pump to electric and spin to 8300rpm
  44. Torn OEM Crank Pulley / Vibration Damper due to SC pulley?
  45. Help 3k rpm stumble/flutter
  46. New Stuff at the Dragon?
  47. Pulley make supercharger go boom?
  48. Are the later and lighter OEM crank pulleys worth fitting?
  49. Can someone help me get a replacment fidenza flywheel friction plate
  50. WTB or Rent Belt tensionior in Chicago, IL ASAP
  51. 2550 miles on new clutch, DEAD!
  52. Problems installing Mini Mania pulley HELP
  53. Phantom exhaust advice needed!
  54. I'm not a virgin anymore!
  55. Custom exhaust?
  56. JCW software with 15% pully and 2% crank pully ?
  57. Power Steering Fan "Air Channel"
  58. Can you buy new friction plates for the fiidenza flywheels?
  59. Need more low end!
  60. Custom ECU Tune options around Florida??
  61. Belt size and part #
  62. Electrical Oil Pressure Gauge install - help needed
  63. Homemade intercooler sprayer?
  64. Need help finding OEM part #s
  65. "Standard" mods only make 7 WHP ???
  66. How do i know if my charger is a generation 4 or 5?
  67. Experience with MiniMotors?
  68. Correct part # for NGK plugs ???
  69. Passenger side cowl mod?
  70. How to remove alta pulley?
  71. JCW Plugs at a reasonable price
  72. Magnaflow Catalytic Converter pt no.94136 - is this the right one?
  73. Opinions: Balanced crank with lighten pulley?
  74. Exhaust & Intake which one first?
  75. opinions on m7 aerogel and areogel ex wanted
  76. Engine Dampener question!
  77. What sort of mods do you need for a 63mm Throttle body to work well
  78. Crank pulley install????
  79. holding up the motor;
  80. Palo Uber exhaust
  81. Alta V2 pulley problems?
  82. Unichip Question
  83. chipping
  84. boost difference 15%-17%-19%
  85. GT Tuning exhaust manifold
  86. Oil Change
  87. Headers, SES Lights and o2 Simulators
  88. What sort of power gains can you expect from a works/GP head
  89. What sort of bhp will i expect to get with these mods?
  90. Clutch issues, car wont go in gear...
  91. need help fast!!! pulley install gone wrong
  92. Need Crank Pulley tool ASAP! Help!
  93. custom tunes
  94. I want to sing the praises of GIAC software!
  95. Aaron Cornaby at Outmotoring is awesome!!!
  96. Opinions on 15% Pulley Installation Wanted
  97. unichip experts
  98. Pulley install in (boston or philly area)
  99. Got my Thumper head on.
  100. Optimal Power and How to Get it?
  101. Dinan S1
  102. Apexi Exhaust Valve. Does anyone have experience with this?
  103. Alta Sounds clips?
  104. DINAN (Get together at the MOTD?)
  105. battery screw down replacement
  106. I'm getting the 19% pulley, any advice?
  107. Where can I buy metal H2O sprayers?
  108. Is there a HP difference between Boral Sport vs Race?
  109. LOTF Engine Damper-easy way to get bolt thru hole
  110. Madness intake finally installed
  111. How to adjust Magnaflow tip clearance?
  112. MINI Cooper S exhaust!
  113. HAI + Aerogel EX vs. M7 DDM HDI
  114. GP or GRS intercooler?
  115. head install problems part II
  116. Alta V.2 Intake W/ M7 STB
  117. Alta CAI install
  118. MPGs dropped by 4.3 mpg...
  119. Arias Pistons & Clearwater Cylinder head
  120. I need a tensioner tool!
  121. 230WHP!! I'm back!! Thanks Emil
  122. Cleaning bugs out of AC evaporator
  123. Has anyone heard of the TCSportline Burnout Catback Exhaust?
  124. Borla Sport, Not Loud Enough...
  125. R&R Intercooler and now MCS wont idle...
  126. Where to find 3" silencers for my exhaust
  127. DDM vs. WMS RAF Box
  128. Drive belt missing
  129. Selecting drivetrain components
  130. P1684 what does this code mean?
  131. Which cylinder is the hottest?
  132. selecting a high flow CAT
  133. Water in CAI???
  134. Alta header is on...
  135. Mini Madness Oil Cooler and Unichip Version Q
  136. question regarding my fidenza flywheel and helix clutch
  137. Front wheel bearing replacement/ upgrade
  138. P1498, what does this fault mean
  139. The meat of the matter/planning for success, v2
  140. I need dyno tune ASAP in Sol Cal
  141. A Lucky Dog Tune ... 227WHP, 188lb/ft TQ !!!
  142. ALta header or custom tune ?
  143. Borla Exhuast NOT what I expected.
  144. how do you measure a charger pully to work out the %
  145. Flywheel problem(?)
  146. Drilling out stock mufflers?
  147. Changing fuel pump how-to?
  148. Pulley Install Video
  149. Need more burble/pop
  150. DEAD MINI with a p1237 code
  151. 19% S/C pully good idea bad idea???
  152. Cheap Custom CAI/HAI
  153. Head Removal problems
  154. Madnees JCW intake fitment???
  155. SpiderX's Header from CMC (Juston Poole)
  156. WMS Sportbox vs. DDM HDI
  157. Magnaflow Exhaust.... too loud?
  158. Wait for engine break-in before mod's?
  159. Madness lower poly engine isolator inserts...
  160. Alta CAI is installed....is this normal?
  161. Removing intake lower box
  162. Dyno in SoCaL
  163. The Meat of the Matter/Planning for Success
  164. Single Outlet Cooper S Exhaust
  165. Webb Exhaust and Straight Pipes...
  166. JCW Exhaust Whoosh Sound
  167. Methanol injection (injector placement)
  168. What type of LSD is used in 06 MCS?
  169. Alta 17% or 19% version 2.0 pulley
  170. Whats so good about the Cometic head gaskets and are OEM ones ok to use.
  171. Interesting Thought about a scenario
  172. methnol injection questions
  173. Anyone used a front strut bar like this?
  174. Swapping o2 sensors
  175. Tools for CAI, 16% pulley and Cravenspeed Short Sifter
  176. Grind baby grind, got a funky sound up front...
  177. ebay, clearwater cylinder head
  178. short shifter help...please help
  179. Plug wires
  180. $60,000 in Mini Cooper mods for 0-60 in 4sec - SMOG LEGAL
  181. Milltek Installed
  182. W#hat to do after CAI, full exhaust and remap....
  183. DynoJet Data Viewing Software for Mac?
  184. question ;
  185. After a day of customizing and a ticket....
  186. M7 front strut bar and Alta CAI - clearance issues?
  187. Cam Installation
  188. Installation Guide for Craven speed short shifter?
  189. IE engine/trans bushings Qs
  190. 2% cank pulley
  191. Upgrade recommendations?
  192. M7 Intake: Any feedback?
  193. 05-06 exhaust hangers on 02-04 MCS???
  194. 16% reduction pulley: Will I need a dyno tune or a new chip?
  195. What a 2% Crank Pulley and 16% reduction pulley combo
  196. m7 AGS...gone?
  197. Lower motor mount installed!
  198. what headers to buy at good price
  199. Pulley Installation
  200. 15% pulley question: Gas?
  201. Oxygen Sensor Plug Location
  202. Help: thoughts and opinions on M7 vs Alta SC pulley
  203. I got Helixed again :)
  204. supercharger went kabloooie!!!!!
  205. Twincharge:Helix, Who has it?
  206. Long term impact of 15% pulley and no software?
  207. Any info on RENTING a pulley puller?
  208. Helix Cold Air Intake. Any Feedback?
  209. a little help please?
  210. And so the turbo conversion begins...
  211. Alta CAI installed!
  212. 19% Pulley. Too Risky? I dont wanna damage my car
  213. Which short shift kit to get? Any feedback?
  214. I have a pro mini intake would i feel a difference with a CAI?
  215. amazing!!
  216. Preformed the JCW CAI Flapectomy today!
  217. MINI VS Z Check this out...
  218. Are there any special tools needed to remove a head apart from:
  219. How much WHP to run this.........
  220. Bottom end?
  221. 2005 engine dampening - upper or lower?
  222. Upgrading from a JCW Air Box
  223. modding help in Albuquerque?
  224. A plug...and reminder about plugs
  225. does anyone use toluene to increase octane
  226. texas speed works
  227. Will these mods allow my engine to run my venom nitrous kit safely?
  228. 06 engine damper removal
  229. Cheap Oil Catch Can Thread?
  230. Oil Catch Can: M7 or ALTA???
  231. Where to buy timing chain locking tool for removing head?
  232. M7 16% pulley torque specs, hints on installing??
  233. Cooper spare tire size
  234. ALTA CAI v2.0 install...quick question
  235. How do you get hold of Mini Madness as ive emailed with no reply
  236. Crank Pulley install help...
  237. exhuast header wrap
  238. Tire replacement!
  239. 250 WHP, is it possible??
  240. Made 213.36whp with stock head..
  241. Help my car went into limp mode! What to do?
  242. 230.2 WHP
  243. UPGRADE THE GEARBOX
  244. El Diablo high lighted in Euro Tuner Magazine!
  245. which ARP bolts to buy?
  246. "Best" OEM Clutch
  247. How to change supercharger?
  248. Alta Intercooler boots help needed.
  249. Alta V2 intercooler air diverter w/ sprayer
  250. Anyone here change their own cam?
