- MyMini/ Minspeed exhaust installed!!!
- QuickSilver exhaust questions ??
- Alta SC Pulley Identification
- Ireland Engineering Catback Installed
- Do i need or could i use bigger injectors?
- Thinking of getting Dinan software (quick question)
- thinking to upgrade head..comments?
- question
- Need OBX header dougnut gaskets!
- new dyno
- my new found power!!!!
- OBD2 Extension cables
- Pulley puller
- Power Steering Fan Shroud on 2006?
- stuck balance
- New boost gauge
- Magnaflow Exhaust
- Aircon will not kick in.
- First mod questions
- Removing cat
- 911!!
- just a thought / question
- Got a dragging/slipping problem with my new performance clutch .
- Car doesnt seem to pull smoothly whilst at high speed.
- HR 19mm rear sway bar VS. stock
- At Track in limp mode
- Clutch, flywheel and LSD install by MiniCorsa
- Volt Exhaust
- Which Sway Bars
- questions on my first set of mods
- 2.4 L cousin ?
- Gatorback belt with 17% pully. tensioner Qs.
- North American Motorsports
- Intercoolers
- Alta 2.5" vs. 3.0" Exhaust?
- Help me out
- Loudest?
- service time + mods: what to say?
- Invidia Exhaust Install Question
- Alta Diverter/Sprayer Compatibilty for MCSa
- Alta vs. Samco intake hose
- Downgrade CAI?
- One-ball mod
- GIAC Questions/ Problems
- Craven Speed Short Shift Kit
- Anyone running Unichip Q ?
- intake question
- 15% reduce pulley, wow
- Alta Sporttone exhaust install?
- So Cal Mod shop
- WTB: GP Intercooler
- Alta Diverter and M7 extreme scoop
- yessss!!!!
- PA dyno day
- How fiddly is the Nitrous/Venom system?
- Best mods for high elevation
- methanol
- new head
- Best TB for the $?
- Vitesse Pro Tune on Danny's 250WHp car!
- Supercharger and ECU
- Supercharger pulley install
- Not driven enough
- Unichip Q and Custom Dyno Tuning
- M7 DDM CAI
- Revolution Mini Works car breaks 251.72whp
- SOON TO BE BAPTIZED BY THE JESUS HEAD
- wmi!!! it's here!!!
- CAI questions on mpg and installation.
- stock ic .
- The JCW gods are thwarting my efforts.
- DFIC IATs at track days - Suggestions?
- pin holed ic ?
- New Modification
- DFIC install issues
- Radiator fan
- The wait is going to kill me
- Magnaflow exhaust mod...?
- Hamann distributor in US
- Is this normal???
- What difference will a dinan 59.75mm throttle body make ?
- Fireballed Mad Mod One ported cylinder head
- Performance improvements due to one-ball/15% pulley/HAI??
- Emil Tune and Dyno Run in Burbank CA
- my coolant resevoir
- Still having vibrations.. :-(
- Taking the plunge
- ags?
- tensioner stop
- it's alive!!!!!
- weird problem and situation
- Ireland Engineering Cat back exhaust
- Great mod on MCS - Sprint Booster
- thx detroit tuned
- What does the Dinan intake Sound like?
- Any info on Bored Out Engines
- question;
- JCW with 2% crank pulley = faster spoolup?
- Milltek Installed!
- Dinan CAI
- $2000 for 2005 MCS Tranny w/LS? Good deal?
- Alta Clutch Hyper Single Stage 3 ???
- Aftermarket MCS header census
- New Header
- Power update w/video!
- a.f.s
- argghh... still hate the oil filter. Help!
- Project MSFITOY Part 2...
- Advice needed on my Clutchmaster fx3oo clutch
- coolant pressure ;
- Hypothetical:Pulley Install-Dealer?orIndependent Shop?
- help pls.
- Evans NPG+ coolant
- Is this a factory Oil Temp Sensor? Gauge bigger issues? Pic inside
- Schrick camshaft for MCS info
- Need help, how to contact Mini Madness
- Drive my car from Atl to LDG and back
- Under the hood beer holder
- Alta 17% pulley
- Two birds with one engine damper...
- Does anyone make a taller shifter?
- question about the ags v2
- where are they?
- Blow Off Valve
- Pulley/ Mod questions
- mini mania rocks!!!
- coolant question
- Wow, more power than my pulley gave me...
- Dumb question, how does the pulley % relate to boost?
- SAE Corrected Dyno Numbers
- Halo Spark Plugs
- One ball
- Engine Damper
- Cold air intake - worth the money?
- Reasonable install time for power upgrades?
- cp s
- CAI for 2004 S
- going for the meth
- Where does the "bypassed" air go?
- Dinan for Mini
- Need to know what part this is
- Best place to buy an Invidia exhaust?
- Post JCW CAI - Check Engine lights up
- How easy is it to uninstall a venom kit
- Pipercross CAI on MINI Cooper S (R53)... This intake has DYNO RESULTS...
- Throttle response and boost gauge discussion
- Anyone running the Hydra EMS?
- Miltek Exhaust
- what gauges
- yoyo after pulley install
- engine gave up
- A few new mods for Vader
- 15% Alta V2 Pulley, belt choice?
- Air con probs ,help please
- Dinan dealers, etc.
- Helix CAI and promini strut brace
- Wilwood Rear Calipers
- How a custom exhaust works?
- Custom Exhaust
- ITG FOAM FILTER
- CRAVENSPEED Short Shifter Vs. B&M
- Please Help!!!
- After intake/exhaust- next mod?
- Deleting Alta 2% crank pulley...Where to find OEM?
- ECU no BS runnarounds please
- webb head
- Alta CAI with JCW Strut Brace Issues
- Air con pump not kicking in?
- 15% pulley, best belt?
- main bearing ladder
- pulling my crank;
- M7 aerogel
- 03 cooper S header and pulley
- Installation labor quote for mods
- Can I install "Colder" plugs even though I do not have any mod?
- M7 DDM CAI install
- wiseco vs. je
- Which pulley to buy???
- Custom tune or canned?
- Installing crank pulley? Kit is almost ready!
- Craven CAI and JCW strut brace
- diy one ball?
- JCW exhaust sound (VIDEO)
- OBX LSD install + tranny bearings.
- G Tec Pro accuracy.
- Magnaflow for MCSa?
- Dinan S with video
- LARINI Installed!
- Your TOP SPEED, before & after mods?
- Which Software for low end torque?
- ECU, how difficult is it?
- What's the difference between factory and dealer JCW?
- Which Dinan Stage SW w/ JCW HW & Mini Madness CAI?
- Anyone changed shifting cables?
- Magnets on Oil Filter
- Minspeed Dyno day
- under hood melt-down
- AGS V1 V2 V3?
- OBX HEADER
- MOD Friendly dealer (Miami)
- First? Review: TC Sportline cat-back exhaust
- Is it possible to put a blow-off valve on a MCS?
- m7 ags/vgs wanted!!
- Good mod installer in the OC
- IMPORTANT !!!!!
- Selecting a Water/Methanol Injection System
- MINI Dies at stoplights when A/C is on!!! 0% pulley?
- DSC - it's doing it's own thing!!
- super charger red-line
- Air diverter w/ sprayer vs. pulley - which will be more effective during FL summer?
- whos bearings?
- Extra reinforcement bars in cabrio engine bay - Can I remover them to paint?
- Engine is running hot and rich... What to do?
- Pulley tensioners seem to be failing - FYI
- mini mania 's
- JCW BELT PART NUMBERS
- Hazzahs are in Order
- Is 2 litres of oil enough to do a gear box oil change?
- Schaefer Club Sport- out of Germany.
- 2002 MCS Stuck in Reverse!
- What is code 0107?
- Fuel Pressure Regulator
- what would you do
- From Ultrik to Alta?
- Throttle very erratic after boost gauge install? What did I do wrong?
- install new head
- Big Mods, Low Boost - an ideas??
- Blown head gasket after pulley install, HELP!
- DT BPV Problems (?)
- HELP!! - Apexi II
- What kinda Spark Plugs should i buy?
- Newbie - Perf. Upgrades
- JCW suspension kit for MCS... Is it worth it ?
- New to MCS's, long time mod-er
- J&S Knock Gaurd
- Anyone experience this??
- (Part 2) Ahhh my fuel ratio saga!
- ICs and IAT questions for the techies and various interested parties
- Say the Magic Word... win a CAI.
- [B]Having engine Warranty issue[/B]
- Lord of the Dampers Question
- Project X-300
- Alta Air Diverter issue
- How many % reduced is the Hartge pulley ?
- Alta supercharge pulley classic Vs V2
- Invidia Sound!
- $259 for an Exhaust?!?!
- High Flow Heads and MPG
- 1st mod on '06 MINI
- Quaife Install ?'s
