View Full Version : Drivetrain (Cooper S)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 [15] 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43
  1. Madness New MINI Cooper S V2 Exhaust Header
  2. Gintania ECU
  3. Looks like Randy's "Mule" is for Sale..wow!
  4. paraphin
  5. New Tensioner Mechanism installation tips?
  6. Alta Sportone V2.0 exhaust (R53)?
  7. anyone with a shark injector b.c canada ?
  8. remus back in business?
  9. Keep melting the Cat!
  10. Tucson area custom shops?
  11. Oil change, Mods + Warranty questions...
  12. 17%er's Sign in!
  13. 356BHP 12.162 @119.02 on BFG Drag Radials
  14. Fire from your exhaust
  15. Anyone try Helix lower harden gear set?
  16. Shark Injector ques
  17. Going Turbo (part 2 metal in IC)
  18. Engine cutting off or stumbling at 80 mph
  19. header questions should i wrap them
  20. Need to replace pads, what to buy??
  21. Beyond 19% club ( 19%+ ) ( >19% )
  22. 330bhp 11.772 @ 115.93
  23. Exhaust Questions
  24. LDG
  25. Carbonized some more
  26. mod suggestions
  27. clutch flywheel combo
  28. Help? Exhaust gaskets
  29. EBC Brakes
  30. VGS and service
  31. my low dyno number
  32. Slight boost leak(s)?
  33. GP engine support/damper
  34. M7 pulley install problems
  35. Cat-back or 1-ball & header?
  36. 17% pulley
  37. question about TSW damper
  38. Is It Really Needed?
  39. 02 6 speed to 06 with LSD Swap
  40. DinanPerformance Engine Software: is it worth it?
  41. how to- MINIPRO INTAKE
  42. Custom Exhaust
  43. Invidai Rocks
  44. some newb questions
  45. taking off with 18's, shrick cam and 04 gears?
  46. Bosch Stock Coilpack vs. Screamin Deamon..
  47. Alta header or OBX?
  48. Boost Tap Point
  49. R56 brakes = R53 JCW brakes?
  50. Picking up Dinan S1 Tomorrow Morning...
  51. Wanted: MORE HP!!
  52. Block heater for MCS??
  53. Peoples experience with warranties & engine work with a 15% pulley installed.
  54. s/c belt tensioner self adjusting?
  55. Injector sizing for a twincharge application
  56. Short Shifters with smoother shifts
  57. Alta Pulley Removal Tool
  58. Why no CARB certification for MINI mods?
  59. MINI of SF vs. mods
  60. Who sells a one-ball pipe?
  61. which pulley?
  62. Custom Front Intercooler!
  63. unichip
  64. Metal in Intercooler TB side??!!??
  65. anything good about obx header
  66. How to keep HEAT out with new Short Shifter?
  67. Question about OCC install
  68. Adding GP intercooler to R53 - what does it take?
  69. Whats the % mean??
  70. Webb Pulley
  71. CAI logic
  72. Mounts
  73. Solid Motor Mounts
  74. I think my upper engine mount has gone
  75. Apexi NEO Craziness/Technical Question
  76. Broken Invidia Weld
  77. wanted : supersprint header connection
  78. Laptop controlled ECU? Does it exist?
  79. Quick question about Mini-madness pulley
  80. cravenspeed pulley
  81. Meeting or Beating GP specs
  82. Getting up to GP specs
  83. Short Shifters
  84. Flowmaster Hushpower II Exhaust ??
  85. Looking for A/F info after pulley swaps
  86. 15% pulley + Flash before and after dyno
  87. I.E. exhaust?
  88. 6 Speed Shifter Slop
  89. Installing Fuel Injectors
  90. Twin Charged for MCS??
  91. oil leak
  92. Review: 15% KMT Pulley
  93. WHY B&M SHORT SHIFTERS SUCK!
  94. Short shift kit disappointment
  95. Running 100 Octane
  96. Dinan Exhaust Sound Clip
  97. ECU upgrade?
  98. Header, Borla , Short Shift almost done!
  99. 17 and 2 ECU tune??
  100. 17% pulley caused cel caused bad cat
  101. Camshafts
  102. Some MCS Exhaust Fun 118db
  103. i know i know....
  104. Pulley Install Question
  105. OBX exhaust... Anybody using this system?
  106. hai today
  107. Is the 19% SC Pulley is too much??
  108. HP Loss with Intercooler installation?
  109. Custom exhaust?
  110. witch code reader obdII to buy?
  111. M7 Aerogel Heat Shield
  112. Where did you put your stock exhaust??
  113. Tensioner noise after pulley change?
  114. Is Airbox Removal Required
  115. Pulley & tension tool needed.
  116. Gintani Tuned...
  117. Oil Light
  118. HELP SUPERCHARGER HOW TO
  119. Brake conversions
  120. Scoops - do they make a difference to performance?
  121. 2004 MINI Cooper S Idle problems...
  122. Can I hear the difference between CAI and stock?
  123. Removing catalytic converter???
  124. Pulley install on Auto Transmission: Question
  125. Manual trans fluid
  126. so; everybody happy?
  127. Anyone solved throttle whistle by switching to JCW intake?
  128. Pulley torque specs comparison
  129. Found 2psi of boost today and it was cheap?
  130. At a stand still
  131. ENGINE DAMPENED
  132. Turbo on pre 2007 MCS?
  133. "Honeycomb Mod" to stock airbox
  134. One-ball Mod : Where to get it done?
  135. New Clutch - Exedy or Clutchmaster
  136. RMW Dyno Day
  137. ECU Tune Dyno Graphs - S. Fla dyno day
  138. Advice on Injectors and Software
  139. Belt Tensioner Removal
  140. long block for $1000.00
  141. $155.00 header?!!!
  142. Mileage loss after intake
  143. Where to buy an used supercharger??
  144. EEC Tune
  145. little longer cranking time
  146. Engine Mounting Bolt Backing Out?
  147. MTH-Motorentechnik Hölzl MTH-Cartune
  148. 380 Injectors
  149. Pulley Broken...
  150. 380's
  151. Throttle Response (in neutral)
  152. HELP! cravenspeed shifterkit and m7 pulley install guides?
  153. Damn yo-yo!
  154. What is this ?
  155. Boost Problems!?!
  156. JCW Suspension on a 2002 MCS?
  157. pics of a Helix.
  158. where can i get the Cat back piece for a MCS 04??
  159. Which belt for 19% Pulley?
  160. Supercharger whistle
  161. What's new on your Cooper S!
  162. Bolting torque specs
  163. Oil catch can...
  164. 15% reduction and colder plugs
  165. Unichip vs. Flashing ECU
  166. Favorite/Preferred S/C Pulley?
  167. Oil Coolers
  168. Any updates on the RMW Rotrex SC kit?
  169. need some help
  170. Any failure due to lightened crank pulley?
  171. Consensus on JCW airbox vs other CAI's
  172. Any tricks when swapping injectors?
  173. DFIC versus OEM IC revisited
  174. Clutch Issues
  175. M7 DDM cold air intake
  176. M7 vs Alta!
  177. Sourcing a lack of power issue...
  178. JCW kit price and install
  179. Thanks to TSW!
  180. meth installed!!
  181. Modifying OEM Headers??
  182. VGS: Still like it?
  183. Help!! 02'MCS with Helix TC throwing codes and shut down at high boost(Long post)
  184. How I removed lots of mods and made lots more power… (Warning - long & detailed post)
  185. Need Help Getting Stock Hangers Off!!!
  186. CAI - Which is better?
  187. looking it over today
  188. SC shaft protection bolt size?
  189. Very hard shifting on 2002 Mini Cooper S
  190. Headers without the cat?
  191. JCW Exhaust kit & Sound.
  192. Conoco? Really?
  193. How to modify 02-04 Milltek exhaust hangers to hit an 06
  194. is it a hassle?
  195. Question regarding warranty and boost gauge
  196. CRYO2 Intercooler sprayer Questions
  197. Quaife LSD Bearing Part #?
  198. Intercooler advice!!!
  199. I need a new clutch.... your opinion requested
  200. PWR Radiator... Didn't Fit.
  201. megan header wow
  202. What Vacuum should I be, at idle?
  203. A/F Wideband
  204. Hartge 4 Exit Exhaust in the US?
  205. Catalytic Converter has gone, what to replace?
  206. New Scoop Required for DFIC?
  207. Suspension upgrades
  208. Alta Top Mount Intercooler Version 2.0
  209. Milltek Exhuast--Best Price?
  210. tire opinions!
  211. Oil drain plug thread/size
  212. Indy Area: Pulley Puller Pretty Please?
  213. Someone to lend pulley-job tools?
  214. Let's hear your Exhaust Notes...
  215. shark????
  216. Air-Liquid Heat Exchanger ?????
  217. Air box hose emergency
  218. Yet another exhaust thread
  219. I've been bitten!
  220. water to air
  221. Resonators..
  222. 1st Mods installed
  223. Does anyone have the DT BPV installation instructions the can post?
  224. MM Air/Water installed today. WOW!
  225. New Rims! What Tires should I Buy?
  226. shortest shifter?
  227. Short Shift Shift Well!!
  228. Help me find this intercooler
  229. Intake Question
  230. DDM CAI Filter Replacement (Paper)
  231. SuperCharger Pully
  232. TSW engine torque damper
  233. A possible Intercooler solution?
  234. 11 second street mini?
  235. Failed gearbox bearings
  236. Good news the clutch isnt slipping/bad news down on power??
  237. Alta "Twurbo" Twin-Charged Turbo Kit
  238. HALTECH MANAGEMENT!!
  239. hissing sound after instaling megan header
  240. Unknown Sound Problem???
  241. Helix Short Shifter Installed - Possible Installation Issue
  242. PowerProg. ECU upgrade
  243. Hood scoops and IC efficiency
  244. Need track pads...any recommendations?
  245. Ditch the AC?
  246. Nothern Virginia repair shop recommendations
  247. Magnaflow Feedback
  248. 14.7
  249. My car is sick!
  250. MyMini/ Minspeed exhaust installed!!!
