- BLACK HEAD LIGHT RINGS
- Rear Exhaust Valence
- Check out this guy's custom intake!
- stroker
- Amsoil Cone Air Filter for CAI?
- Blown shifter?
- Best IC for the street
- COOPER PULLEY ON COOPER S??
- Lower Engine Mount Bushing(s)
- GP vs DFIC on Track
- Short Blocks?
- Engine Damper
- To those of you with an RMW or LDG tune
- Intercooler Pressure Drop; Supercharger RPM
- OK, now what? Questions about pulley upgrade...
- Motor Mount
- Custom Header
- alta classic VS alta 2.0
- Stock Transmission Fluid
- ALTA's GP meets the Unichip and gets 12WHP and 8ft-lbs
- RMW (Jan) Tuning in Detroit on December 8th
- Dyno Day in Mesa, AZ
- Revolution Mini Works (Jan) tuning in Dallas, December 15th
- You might want to try this w/ R53 exhaust tips
- M7 Coilovers w/215/40/18 43et SLAMMED!
- how should i spend $1100 on my MCS?
- Tuning Information
- Anyone run w/o exhaust?
- Twincharge
- Air intake kit for 04 Cooper S
- R56 Engine Swap?
- Ignition question
- can you see the rear sway from behind the car?
- How to make my intake colder...?
- Del Rio Power
- Adding JCW tuning kit
- VGS feedback??
- I need some help to prove our cars!
- m7 oil cc
- intake question
- Adding A Cat To An Ultrik Header
- Magnesium replcement intake manifold and engine mounts
- Spec Clutch
- Ireland Eng BBK
- RMW dynotune: 239 hp, 190 ft-lbs tq.
- Under-sized Bearings
- Want to throw some upgrades on my 07 MCS
- Anyone have experience with these guys?
- Cam
- Engine bay pics(before/after) plus Kittens and Intercoolers!!
- Does anyone know what happened to MTH?
- CAI, Pulley, One Ball - What to do with the ECU?
- Webb Camber Plates
- Double-walled airbox
- brake pad on MC and MCS
- Header Bolts
- Cruise control install
- Gauge questions
- Spark plug question...
- OCC, The correct install?
- Burble
- Engine Transplant.
- diameter of OBx header
- Alta V2 IC and Intake review
- Alta V2 IC - Cutting the hood scoop...
- Dinan Intake; Intake Filters
- JCW aftermarket parts and and anything That wont void a warranty
- Loose nuts concern from Strut Tower Plates?
- DT Bypass valve and VGS
- Part # for shifter shaft retainer ring?
- Changing intercoolers! An Alta TMIC to an M7 version2 DFIC
- MINI Cooper Tuner in Minneapolis-Saint Paul?
- 320 whp and 240ft lbs TQ
- M7 180F Thermostat questions...
- Twincharge on the cheap?
- anyone exp. CLUTHCHMASTERS clutches ?
- ALTA R53 TUNING
- Exhaust (battery) heat shield traps exhaust heat?
- SC Pulley Install - Cost?
- Automatic transmission and High horsepower?
- Anyone know of a supplier of a 14% SC pulley?
- Pre 05 Vs Post 05 Crank Pulley
- True CAI, not ram air
- DDM Works CAI
- Squish grooves
- Backing off rear brake piston- what's the trick?
- My MINI's MODS -- Thank you
- cAi
- Exhausting dilemma!
- R56 Intercooler - DFIC?
- ALTA vs. JCW Intake and Catback.....who won???
- Mods from Japan?
- 15% or 17% SC Pulley??
- 7 digits code, reading from ECU by GT1
- strut bar
- Turbo Kit - Cooper S
- DIY: Make your turbo spool faster
- Oil Catch Cans on Ebay vs. Aftermarket
- Pistons and Fireballed! Q
- Clutch and LSD
- Georgia supercharger Pulley install... Where?
- RMW Midwest Dyno Tune Session
- cosworth???
- 5:50 mobil1
- 30-70 Et in 3rd
- New Toys!
- Finally pulled the trigger on an intercooler
- No gain on bottom end after pulley install
- Big Bore or 2.0 conversion?
- Which is the better Oil Cooler
- installed my 255 walbro.....
- Revolution Mini Works (Jan) tuning in Atlanta November 10th
- S-AFC
- Help estimate my power numbers...
- ECU - Megasquirt or GIAC???
- Seeking confirmation
- Night Racing Pics
- Clutch Discs
- Do I need a smaller or lager belt?
- JCW cold air box
- 15% SC pulley belt life
- Tensioner tool for belt change?
- Header & O2 sensor
- Polyurethane Engine & Gear Box Bushings
- One of those ideas
- Do I need bigger injectors after ECU upgrade
- Short shifter
- Topside oil change
- How much power can the stock clutch hold?
- Tach re-calibration
- M7 Mods?
- Unichip and Flux Module
- Modifying stock CAI, and exhaust on 05 MCS
- Water to Air or DFIC Intercoolers?
- Thoughts needed
- UNICHIP REFLASH FROM 16% TO 17% PULLEY
- '04+ exhaust mod
- Volt MCS Exhaust
- Dear NAM's Abby, What should I do?
- pop sound when i first touch the gas pedal !!
- Antonov 2 speed supercharger
- Fuel Gauge Issue
- HELP! I need a throw out bearing for Spec stage II clutch
- New Custom exhaust done!
- Three weeks to break in a belt, to stop slipping?
- why 15% SC and why not 19% SC??
- Thunderhill Track Wknd 10/20-10/21
- 237 HP
- FYI B&M Short shifet on Ebay '02-'03 $50
- I know Air Filter should be oiled a bit... I thought not dripping...
- Get rid of the supercharger...
- Throttle response delay..??
- Straightening one-ball exhaust?
- One for all the TwinCharged guys.
- '05 MCS Upper engine mount failure/replacement
- price range
- Ireland Engineering exhaust
- Torque steer and 15% pulley
- help me find out whats on my car
- help with intercooler related prob
- Weird sound from front ends, please help identify
- By Pass Valve
- Japanese universal mufflers for custom exhaust
- Transmission question
- megan header.
- Engine swap question
- Do I need BMW Tool 11 8 370 to install a new cylinder head?
- Shark Injector vs. Factory Software Update vs. ?
- MAP Sensor Problem
- Laptop Data logger
- Magnaflow Drones No More
- Alta intake hose & TB fitment question
- K&N Typhoon CAI Recommendation
- Header Ceramic Coat Peeling
- BMP Intake
- which pulley ?
- One balled my exhaust this weekend
- Low Buck, DIY 04 MCS Mods
- To Quaife or not to Quaife.......Quaife
- Problem with low mpg.
- DT BPV, after-install, help!!
- What's this intake?
- CAI Filter Performance, (filtering particulates)
- how much money?
- Is it okay to use this pulley?
- JCW exaust -- crimp in exaust pipe
- 75w90 gear oil for a weekend?
- Screamin Deamon and NGK IX's... Gap?
- BMW Show Post Mortem Results In (Pics as well)
- what is the best bang for the buck after a 15% pully ?
- One-ball mod question
- SC Port & Polish and Maintenance (Oil)
- M7 ram air intake or Alta intercooler air diverter
- What kind of numbers should I expect?
- 210 whp!!!
- Noltec Bushing Inserts
- Electric Cutout
- Bad Smell
- DIY Occ, Little different
- Invidia Exhaust Question
- Instructions on removing Alta CAI Filter for cleaning.
- Scoop "cone"
- Custom Tune on Factory JCW
- BMC CDA
- haltech intercepter
- Alta Exhaust, alignment question!
- OBX donut gasket
- Exhaust cut out
- The need for speed.... WHY and what KIND!!
- Busy Week! (Exhaust Upgrades and Suspension Upgrades)
- boost gauge install
- B&M shifter How-To?
- Alta's Front Mount Anyone???
- Intercooler Sprayer
- Will this work?
- MCS improvements
- Raising Idle to 1K RPM
- CryO2 installation?
- belt
- Palo uber intake?
- What will happen if I replace my resonantor with a glass pack?
- m7 Pulley Installation question
- Anybody else jealous that the R56 owners get such sweet looking CAIs?
- in search of QUIET freeflow muffer
- drive belt lengths??? M7 16% pulley
- Removing SC pulley without a puller
- Just another Dyno thread.
- Pics of Ireland Eng Big Brakes?
- SSK install help!
- hep me hep me Pepper is in limp home mode
- Has anyone had their MINI S gearbox oil changed?
- Where did my burble go?
- Apex Super afc
- sloppy wheel?
- Labor cost to install s/c pulley
- Boost Guage for "Mickey" cluster?
- twin charge
- blow off valve
- What size are Stewart Warner Volt/Boost gauges
- What GPM for an electric water pump?
- Anyone in the NC/VA area?
- Best 60mm Wide Band gauge? AutoMeter like.
- Alta, M7, or Madness? (etc.)
- Do it yourself pulley install
- How is the S/C lubricated?
- Supercharger Pulley Removal Tool.....rent/borrow????
- Transmission Problems: HELP NEEDED
- What is the right Cat to put on
- ITG Dinan Intake Filter...
- HELP!!! ARE GRILLES INTERCHANGABLE???
