- whats the deal with the BPV?
- AFTER OBX HEADER....vibration
- squeaking
- exhaust cleanup
- Coolant flush/change
- Catback install, how long does it take typically?
- Intake delema
- 17% Alta SC Pulley and 2% Crank Pulley ?
- Haltech Interceptor
- lsd
- home made heat shield
- Need some specifications
- Need help taking this out!
- Intake and Exhaust
- Unichip Install Instructions
- b&m short shifter
- clearance for wilwood BBK?
- Gintani Aftercooler Program
- exhaust rear section install
- head cc/ gasket
- Jan tuning in Las Vegas @ AMVIV5
- Bypass valve vs. boost gauge
- GRS Intercooler issue
- RMW/Jan tuning party in Florida
- JCW exhaust and Craven SSK
- Anybody gonna splurge for the Cross Exhaust
- DYNO Results
- squeaking when cold with M7 16% and JCW belt
- Serp Belt Swap
- Madness V2 Cat Back Exhaust System
- Anyone ever regretted going to a 15% pulley/gone back to stock?
- Thanks Jan 262 times
- Alta Classic or 2.0 ???
- Squeaky serpentine belt...
- Megan racing header
- Reliable MINI Service in Cleveland Ohio
- RMW tune results!!!!
- How much brake fluid?
- Pullied
- M7 16% Pulley
- Alternator failing? Shaft bent???
- Brake squeaking?
- weird sound?
- Vacuum leak with my M7 OCC
- Alta Pulley question..
- Oil Catch Can question
- Lets talk Plug Wires... (Long Post)
- Injectors???
- VIP engine stabilizer
- Modulating the VGS
- HELP!!! having boost issue i think
- Non-Cooper engines in a MINI
- What can I do to get THIS kind of exhaust note?
- Supercharger Pulley Won't Come Off!!
- Cool animation of a supercharger in action
- Finally got pullied!
- Header and catback excessive exhaust burble
- Borla sport
- obx header with 2 and 1/2 inch high flow cat
- obx header question
- 04 MCS Shifting Problems
- 06 MSC Exhaust ? Will it fit?
- Codes P1498 and P1125
- k - number
- Warranty issues ?
- Anyone know where to buy an exhaust tip like this?
- Belt Q
- how to gap spark plugs?
- Supercharger install vs Oil leak?
- Blew motor up!!! AGAIN!!!
- Clutch and Flywheel opinions
- Version 2.0 pulley owners
- Alta vs. AEM vs. Injen vs. M7 vs....
- Exhaust question
- RMW tune and the exhaust burbble
- mod suggestions
- New resonator
- JCW Short throw shifter?
- Odd Smell
- Removing Cat Converter?
- Open ECU reflashing?
- Reflective heat resist stuff at Advanced auto
- O2 Sim Vs P0420 code..
- *Revolution Mini Works "NEW" exhaust*
- Can anyone identify this exhaust?
- Gatorback belt on 17%.. Life span?
- Cooper s pistons
- GRS chargecooler dimensions?
- Turbo FTW!!!!
- Belt Tensioner Install
- Anyone know of a Gilmer belt/pulley kit for MCS?
- RMW camshaft testing results
- Engine Code?
- In the 6spd tranny questions?
- I think I figured out my tuning path...
- exhaust hangers
- Borla Street Mid-Pipe on Borla Sport?
- DT Bypass Valve MPG and other Observations
- Head Gasket Thickness
- Views on MSD Coil Pack and Best Plug Wires
- JCW Air Filter Installed easier than i thought...
- MINI's are quite capable
- Frozen Stiff Shifter
- Installed Alta intake. Now have a ? about it.
- eBay intakes, shifters, exhaust...
- Billy Boat Exhaust :-)
- How do I test the newly installed JCW Intake
- Turbo + supercharger??
- Went to the dyno today
- Calling All OBX ,RMW HEADER Owners!
- Just Did All Bushings - My Opinion...
- M2 Head on eBay, any experience?
- Another RMW Tune
- Project Super MINI!!!
- Props to danny at Minicorsa!
- Question about injectors
- Car won't start
- RMW tune for my Mini....
- Anyone have experience with Sprint Booster?
- Pulling out Automatic Transmission and replacing with manual...worth it?
- New Here Looking for information
- Looking for Tube that AGS Replaces...
- GIAC Software question
- Exhaust tip. What do you think.
- water overheating
- Which is better of these filter ?
- Prosport AFR gauge...
- Tools for a transmission fluid change
- I am a Cooper owner wanting to upgrade to a Cooper S!
- Project MSF...
- Exhaust System Help
- 1st Gear Tranny Sound ???
- UUC flywheel potential problem/question...
- Radiator Reserve Tank - spilling its guts
- Oil catch can problem
- Pulley slipping on the shaft? Try this...
- obx lsd, where to buy?
- Remove the grill in the MAF?
- PLX Devices - A/F Guage - install help
- Eisenhaus exhuast for MINI
- Thinner Head Gasket?
- Water from Exhaust@Cold Start.
- Is it my trim or my head?
- OBX Exhaust
- alta short shifter question
- Removing rubber exhaust grommets
- Alta 15% Pulley Install Problems
- Any ECU tuning in the North East?
- Which Pulley to go with????
- Does short shifter add more cabin noise?
- GP intercooler install instructions needed.
- Pulley Change! Need local help
- oil change
- crank pulley install
- Add a little fire to that burble
- wow
- Need Help from NAM Members
- Throwing a code, getting boost leak of some sort?
- Big Brake kits and Wheel Offset
- Jan-tune nets 50hp! (Well actually 49.9)
- Okada Project coil pack
- M7 extreme scoop or ram air scoop?
- Anyone in Atlanta?
- re: Important Dimsport ECU tuning news thread
- New supercharger from dealer but....I need opinions
- Oil Sludge
- Getting more air from the windshield cowl...
- Installed the MiniSpeed One Ball pipe
- Fidanza flywheel and OEM clutch
- Front end shaking help needed.
- Alta Header
- Jardine/Thorley catback exhaust for MCS
- Intakes????
- One Ball Mod in San Diego
- ALTA Turbo kit
- Guarantees?
- short ram intake
- HELP Transmission
- Upper intake cleaning, now a misfire?
- Short Shifters:Alta or Craven?
- M7's Direct Flow Intercooler 2 (DFIC2) System" - Technical and Detailed Opinions
- Headers, should I get them??
- First time performing a Flapectomy
- Honest, cost effective mod list for R53
- M7 MINI Cooper S Throttle Body
- Spark Plugs Question
- DIY CAI (Alta filter, CF heat shield)...
- One Ball mod pipe, weld or not?
- Tranny Fluid
- Water + Intake = ?
- M7 air gain system
- Less pull in 2nd gear
- How to attach stainless front brake lines to shocks
- HELP in picking new injectors for my cooper s
- Anyone rebuild a SC?
- M7 "Little Scoop"
- Remote turbos.
- Easy Way to Re-install Oil Filter Canister
- Good Shop in the Orlando FL Area
- itg air filter
- Any ECU tuning happening anywhere near the Seattle-Bellingham, WA Area? Vancouver?
- Golf tee modification for AC Schnitzer exhaust
- Another Great RMW Tune w/ Dyno Graph
- Alta Turbo on 2006 JCW
- Has anyone used a tailpipe cutter
- Difference between JCW head and stock
- RMW tuning in the spring
- Possibility for RMW (Jan) or someone similar to come to Vegas for a dyno-tune day?
- JCW cam to Schrick Cooper S Cam !
- 450cc injectors
- Diameter of Remus Cat back exhaust
- some upgrades
- Remote ECU Work
- ECU mods
- 15% pulley on a 2007 MCSca
- MINI S Upsolute tuning experience
- Front Intercooler
- Failing Miltek Cat Question
- 15%pulley and gas milage
- Have Alta twurbo install question please help!
- Alta OCC Kinked Hoses
- Questions Re:MCSa Intake Tubes
- Modified head: Cautionary tale!
- alta cats okay?
- Look! New light-weight pulleys from DDMWorks
- Back by Popular Demand: Jan at Helix in Jan.
- Wanted: how to on Clutch, LSD install
- Problems with big bore TB
- RMW Tune in Dallas Possible 2nd Date!!
- HELP!!!!!!!!!! sc pulley install gone bad
- Best way to change MCS Belt?
- SUBSTITUTE FOR BELT TENSIONER TOOL
- NOT A REPOST - RMW tune - best mod ever
- RMW (Jan) Tune - Best mod by far
- Got some questions
- Has anyone made a solid lifter head?
- 5th gear 80mph to 124mph probs
- DME Reflash
- SC Pully and ECU re-flash question?
- Weird clutch/tranny problem
- Downpipe red-hot. Weak spot?
- Help With Catalytic Converter
- Pulley change!
- Twincharge question
- Tell me about Supercharger BPV replacement
- yikes!!
- Pinging under boost
- pictures of your starter from under the car
- M7 throttle body not calibrating anymore
