View Full Version : Drivetrain (Cooper S)
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43
  1. How To Choose Good Engine Oil for My 06 Mini?
  2. Will Redline 5W30 motor oil harm my R53?
  3. What is a fair price?
  4. Can the 07 dash fit on the R53?
  5. average hp gain from a cam
  6. MSD box
  7. Oversize valves
  8. Omega Halogen Fog Link???
  9. Durable R53 Cat Converter?!? Help!
  10. last second mods
  11. Cooling Improvement of Intercooler ?
  12. Another boost problem.
  13. Illinois RMW tuning party anyone?
  14. Boost problems and ??'s
  15. Newbie Question - Filters?
  16. 2007 block in a 2006
  17. Premature clutch wear pre 06 5/6 speed manual
  18. Which Head to get?
  19. Most "Bassy" exhaust?
  20. How-To for Lower engine mount bushing?
  21. volt exhaust
  22. resinator?
  23. Next upgrade
  24. Intake Modification?
  25. Removing the cat/ o2 sensor
  26. Jan RMW-Rochester,NY April 25-26
  27. SF and Bay Area Coopers!
  28. Wheel Offset question
  29. Why you should'nt use an engine dampener. (sorry it's a bit long)
  30. Whats the best way to take the tension off the timing chain?
  31. do I need a re-tune?
  32. ALTA Exhaust System
  33. DSC ON or OFF with the Quaife
  34. SO....InViDiA.....yay or nay ?
  35. Any special info for a cam swap
  36. Tuning for Fuel Economy
  37. Nitrous Install
  38. Whats your oil pressure?
  39. big heads and small injectors
  40. fuel pressure on R53?
  41. Thunderhill Track Event April 12-13
  42. Alta intake hose install - quick question
  43. Tyrolsport Caliper Stiffener install....>
  44. Aftermarket clutch problems
  45. Anyone try this intake ???
  46. Need advice on mods... like every other newbie
  47. 2 absolutely unrelated questions, 1 thread
  48. Dimsport tunning
  49. Injectors - again
  50. green twister CAI? any good?
  51. CAI = less miles per gallon?
  52. Clutches
  53. Pulley Weight (steel vs. aluminum)
  54. Best CAI for '06 MCS???
  55. Anyone do FMIC on R53?
  56. Powerflex Bushings Break-In Time?
  57. Unplugged temp sensor and now odometer reads -40 ??
  58. Install issue on MSD Coilpack
  59. Indexed spark plugs -- anybody do it
  60. Madness Polyurethane Engine Bushings or TSW Engine Damper?
  61. re-setting ECU?possible?
  62. oil catch can
  63. intercooler coating
  64. Is is still possible to get MTH Tunes?
  65. need after market ideas, any thoughts?
  66. Is this the wrong Magnaflow for a 05?
  67. More Hp - Pulley or crank?
  68. Looking for a replacement filter for my Dinan intake
  69. Exhaust question
  70. borla exhaust, anyone lose MPG?
  71. OBX/invidia VS Alta/Alta
  72. Intake identification
  73. oil/power steering reservoir caps
  74. EBC Dimpled/Slotted Rotors & Misc Questions
  75. Craven Speed SSK - thoughts & problems
  76. Help Please! Remove of Power Steering Tank Hoses
  77. HELP! Remove Covertible Fuel Filler Door!
  78. RMW tune
  79. Tech Question to Gintani
  80. pully help
  81. Madness JCW Filter & Cowl Mod
  82. Anyone use an Ntercooler on their MINI?
  83. Just put in a CAI. verdict: cake
  84. DIY - Port & Polish TB
  85. Mini Myth Busters
  86. m7 crank pulley
  87. List of Gatorback sellers
  88. MADNESS CAT BACK?
  89. Ported and Polished my TB
  90. CAI - who's best?
  91. The best spark plugs for pullied cars?
  92. Gintani Questions
  93. 220 WHP after Jan's tune
  94. DIY Black Exhaust Tips
  95. Voltage intake thread?
  96. OK guys Pony up!!
  97. Coil pack terminal corrosion & Iridium plugs
  98. intercooler sprayer
  99. Helix 17% + JCW Belt + Stock Crank Pulley
  100. DIY Pulley Change
  101. HEADLINNER REMOVAL & INSTALL
  102. New Voltage CAI!
  103. supercharger intake duct removal
  104. MSD Coil Pack and Leads
  105. most bang for my buck :D
  106. Nitrous, how much can my mini take?
  107. Sprint Booster
  108. can old belt cause power loss?
  109. ENGINE STABILZER
  110. GT Tuning Oil Catch Can
  111. Advice: What to Mod Next with $4K
  112. obx header high flow cat question
  113. For those of u who...
  114. Fitch Fuel catalysts ?
  115. Water to air intercooler
  116. OBX ATB Diff, Clutch, and Cam
  117. shark ECU
  118. when will the RMW 2.0ltr engine be avaliable???
  119. let's rate aftermarket intake noise levels
  120. Jan/RMW Tune - Worth a 7 hour drive for sure!!!
  121. ON TEST: SuperChips vs Standard & 15% vs 17% Pulley
  122. Modding question please help...
  123. What are the common gains of a cam and 380 injectors?
  124. Buying a new g=belt tensioner
  125. Dealer won't do JCW flash on MCS
  126. Why did MINI decide on 11% pulley for JCW
  127. Nasty grinding when clutch is engaged. HELP!!!
  128. What supercharger pulley is this? *pic inside*
  129. Q's on Unichip
  130. Tuning a car with just CAI and pulley
  131. New Borla Race Exhaust Question
  132. RMW nets 82.8 WHP gain!
  133. thinking about adding a header
  134. Alta Silicone IC Couplers... installation tips?
  135. Bosch 440cc injectors
  136. Miltek resonator
  137. $13.00 OilFilter wrench
  138. WERE TO GO NEXT?
  139. Pulley installer cost in Mpls/St.Paul area?
  140. K&N Drop In plus Drilled lower Half?
  141. Any thoughts on the DT Bypass valve?
  142. One Ball Exhaust for my MCS....help~
  143. Short shifter question
  144. any sound clips? exhaust & intake mod's ?
  145. CHR cylinder heads
  146. Fooling the stock oil pressure sender
  147. Most Useable Power in a mini?
  148. Need Some Help, What to Upgrade?... Wanting to go faster!!!
  149. Show us your... plan for performance mods
  150. oil cooler for summer
  151. Exhaust Comparison
  152. pulley 17% and crank +3
  153. Finally Camshaft Prices are Falling.
  154. oil and transmission fluid recomendations
  155. O.E lightened
  156. JAN TUNE ADDS 20 HP/17 TQ
  157. Any difference between LHD and RHD headers ??
  158. One ball exhaust for $20
  159. Questions before I start changing my MCS
  160. DSC, ABS and tire pressure lights on???
  161. small gains
  162. 15% Alta: Before and After (Dyno Results)
  163. New M7 CAI!
  164. Any pics of RMW header?
  165. GIAC Flash Opinions
  166. How much nitrous can the S handle?
  167. Who has the Alta Exhaust?
  168. What exhuast?
  169. Upgrade advice
  170. Noob Brake Question
  171. Belt Size
  172. CF Roof Replacement
  173. remapping ECU ?
  174. MINI Conversions
  175. Help! My belt schredding?
  176. New to MINI. Any Turbo First Gen engine pics out there?
  177. Alta CAI fitment to hood liner
  178. How to install ALTA CAI for R53??
  179. pulley instructions
  180. Help needed for small Modification
  181. 2008 JCW Mod questions.
  182. OEM Fluid Viscosities
  183. i need a new belt for 15% pulley
  184. OBX header + stock cat = loud?
  185. OBX Header to Invidia exahust
  186. DIY Air Plate Diverter for < $2........
  187. torque spec for Alta classic 19% pulley
  188. OBX/ HEADER sound clips
  189. Revolution Mini (Jan) Tune Party in Houston, TX
  190. How to Achieve 350 Hp at the wheels
  191. custom tune
  192. spark plugs
  193. Clutch Replacement Recommendations in San Diego
  194. New Mini
  195. lower temp thermostat a bad idea?
  196. JCW Injectors Install - DIY?
  197. Pulley or Wheels?
  198. Which Cat-back for performance yet still similar to OEM sound
  199. Alta crank pulley question
  200. Help,what hanger design do I have?
  201. Injectors - at what point do you need bigger?
  202. flat spot developing.
  203. Opinions on manual transmission fluid
  204. exhaust sizing question
  205. Where to buy a larger fuel rail and high flow pump ?
  206. clutch opinion Organic or Ceramic
  207. JCW Air Filter Kit vs CAI
  208. Another exhaust question
  209. what intercooler is the best ?
  210. 19% pulley gives 20psi!?
  211. Belt size for 19% pulley
  212. Expansion Tank Exploded!
  213. New TSW Engine Damper Kit Installed
  214. Vote ur opinion about CAI "JCW vs ALTA vs M7"
  215. Hamann engine upgrade kits
  216. Tensioner Stopper
  217. Anyone need a stock exhaust for MCS
  218. Cross Exhaust
  219. Fyool filtah...
  220. alta twin charged
  221. Dimsport Software in Roundel Magazine
  222. Hose came away from CAI - would this cause problems?
  223. The Rest of the Story...
  224. Fuel Injector Question
  225. quieting aftermarket exhaust
  226. Imported Fidanza flywheel?
  227. Need a left front axle...
  228. I NEED Detailed Engine Bay Pics
  229. kwik lift
  230. M7 16% Pulley - Opinions?
  231. Engine knock & ping
  232. Max Manifold Pressure
  233. Header wrap pics
  234. Torque For Header Bolt
  235. Intercooler off pictures.
  236. MCS Snow Plow
  237. Convergence of TSW and OBX?
  238. need plans for one ball mod for my cabrio.
  239. GP intercooler install question
  240. Biulding a head, need help sourcing parts
  241. The pulley plunge
  242. Top Tier Fuel
  243. Problem !
  244. Brake Upgrade
  245. Tensioner over torquing causing belt failure
  246. oval exhaust tips
  247. Juice Box "Hot Pill" ???
  248. How much HP can an auto tranny handle?
  249. Where to find
  250. Belt tensioner bolt torque
