View Full Version : Drivetrain (Cooper S)
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43
  1. Spec Clutch with Stock Flywheel?
  2. Going RMW but need a few opinions.
  3. What is Evaporative emmison leak
  4. JCW brakes Vs. R84 X-lite wheels
  5. Alta & Craven SSK. How low can you go?
  6. RMW 440cc injectors with final tune!!!UPDATED WITH GRAPHS!!!!
  7. Special oil dyno result
  8. Fastest M45 MCS in the World!!
  9. Wiring Help w/ Intercooler Mister
  10. Short shifter install how-to??
  11. Intercooler Cover/Diverter project
  12. OBX/ no cat
  13. tanks and goodbye
  14. AMD kits
  15. How do you measure A/F?
  16. Revolution Mini Works goes 291.7whp!!!!
  17. to crank pulley or not to pulley
  18. Dyno results 220WHP with no tune!!!
  19. TwinCharged MCS From Istanbul/Turkey
  20. Nology.. where should I buy them?
  21. New style OBX Header
  22. Brake modifications?
  23. Have 3Grand how to spend it???
  24. Boost at altitude
  25. Damaged Diff
  26. Stock Open Differential Plus Phantom Grip
  27. IAT Sensor
  28. Revolution Mini Works Camshaft..... taking orders
  29. Revolution Mini Works New Header for standard catbacks
  30. Revolution Mini Works Laminova Water to Air intercooler
  31. 259Whp Jan is the King
  32. Flat spot in HP/Torque curve?
  33. Apexi AFC
  34. baffled oil pan: opinions?
  35. Air filters - Paper vs Foam
  36. Dinan Exhaust install
  37. Dyno results from The LAPD & Vitesse Pro
  38. Dyno Results
  39. So I finally changed the Oil, but... (slight long Story)
  40. Going for it!...but need guidance from NAM
  41. So much debate about intercoolers and intakes
  42. Belt noise - Please HELP!
  43. So, is this bad??
  44. Seattle RMW tune @ Speed Factory!!! June 19th, 20th, 21st
  45. Got ECU flashed today
  46. No more tuning from Jan?
  47. exhaust came in...:(
  48. bolts,springs for obx header
  49. 03 -> 06 exhaust mod
  50. Milltek Rattles!!!!
  51. Who wants Jan to come to Boston?
  52. Hear your SC?
  53. SC pulley tool rental
  54. Do I need the belt tensioner tool when changing my pulley?
  55. Oil catch can information
  56. GRS or ALTA Intercooler ?
  57. I want a Blow of Valve
  58. when do i need bigger injectors
  59. Overboost Problem Help
  60. What would you do?
  61. Stall at idle
  62. Phantom Grip LSD
  63. Tyres, to change or not to change
  64. Sharkedit tune from Jim C. ($299 and details)
  65. Remus clamps, anyone know where to get these?
  66. Pulley + CAI = New Exhaust?
  67. Pulley + CAI = New Exhaust?
  68. Closest Revolution Mini Works tuning session??
  69. Alta Intercooler diverter mod
  70. Desperate in Columbus In
  71. linkage part #'s?
  72. alta exhaust how-to?
  73. Swapping from a 15% pulley to 17% pulley?
  74. R53: Battery relocate & straight exhaust
  75. Pressure Bleeding Brakes
  76. NYC One-Ball
  77. What's the gap on the plugs?
  78. Comments on head gaskets
  79. OBD Scanner
  80. I got my one-ball done! brief review!
  81. Ultrik intercooler bellows.
  82. Belt Noise Question
  83. Pulley install near Boston?
  84. Helix vs. B&M short shifters
  85. NOOB-Ness Confirmed: (Mandess-Equipped?!?)
  86. SES light and aftermarket Catbacks
  87. DMH/Wegner GP
  88. 02-04 Borla Race on 05 MCS
  89. Please Help Me Out
  90. Turbo Manifold build...
  91. Cammed.
  92. Stock clutch, hard start - what to do?
  93. Last thread about CAI's.....
  94. Flywheel replacement under warranty
  95. Introducing....
  96. Blow Off Valves
  97. Supercharger lifespan
  98. Tuning results with new head
  99. Can i Borrow your Pulley Puller?
  100. pulley chat
  101. Pulley Change w/out Tensioner Tool???
  102. Dyno'd my Cabrio and tuned
  103. O2 sensor broke.
  104. Exhaust for a mini S
  105. Superchargers
  106. tapping a hole in oil pan
  107. Head job gone wrong!
  108. psi problem
  109. "mushroom", "sandwitch"???
  110. FLY WHEEL. No Warrenty from DINAN OR MINI
  111. Twurbo
  112. simple mods for more performance?
  113. Mods on High Mileage MCS
  114. Reduction Pulley and Water Pump
  115. Strut braces for sale?? Why??
  116. Popping, gurgling and/or backfiring from Dinan exhaust?
  117. Ignition Mod
  118. $6.00 CAI
  119. Engine Electrical Failure??? Help!
  120. rough idle
  121. Where to buy B and M Shifter?
  122. Warranty is expired - time for upgrades
  123. header bolt - what size??
  124. HOLLY CRAP! WHAT A RIP-OFF!!!
  125. best cam for mpg?
  126. Aftermarket Battery...choices/opinions...
  127. ECU Tuning Performance Comparison
  128. Alta Exhaust Help
  129. Clasic Mini - Once again, great service!
  130. Pinging
  131. Clicking on take off
  132. Modded 08 cabrio vs. Waiting for 09?
  133. Any TN MINI Owners Want a "Jan Tune"?
  134. Survey - MCS Exhaust Types
  135. Thanks Jan!
  136. Borla exhaust compatibility
  137. Stock pulley wont come off
  138. Not Starting
  139. no love for the LSD?
  140. K&N Filter for Dinan Intake (Part Number?)
  141. Jan's Florida Tuning Session Results
  142. Oversized Crank Pulley & "Alta-nator" pulley?
  143. @ Jan/RMW - Rotrex & 2.0
  144. Alternator Pulley Removal
  145. Replacing Motor Mount??
  146. Enjoying the new exhaust
  147. Belt Squeaking badly...
  148. R53 SC vs R56 Turbo, both JCW, best?
  149. ECU Upgrades
  150. ALTA or Miltek
  151. Would this even be worth my time?
  152. Changing Plugs
  153. I'm "Heading" in!!!!
  154. Curious to know..
  155. header
  156. "Jan" tune - what is it exactly
  157. Anybody have MSD Dashhawk?
  158. Thanks everyone
  159. I changed my plugs to the NGK BKR7EIX-11 and now the cars sounds different???
  160. @ ALTA - Stealth single-oval tip pics?
  161. Does new catalytic converter need break in?
  162. One ball mod
  163. 2005 MCS Sport Calipers
  164. Charlotte, NC pulley install??
  165. rear wheel drive
  166. Will be looking at a used magnaflow exhaust
  167. Anyone have instock injectors?
  168. Do Scowl Coops work?
  169. service engine soon
  170. Do Cowl Scoops work?
  171. Injector flow-match
  172. Making Mods to an '05 MINI S
  173. Water/meth install
  174. $500 for B & M shifter and install
  175. Iridium S. Plugs - How long do they last?
  176. Stock internals
  177. Search option is terrible...
  178. Alta CAI Install Issue - What am I missing?
  179. Review of M7 sequential shifter and more - long!!
  180. Water/Meth Injection or Nitrous for cooling
  181. EMERGENCY, bushing install
  182. Help me in modddin ECU (+)
  183. Jan's Connecticut Tuning Session Results
  184. Pully question: size and manufacture
  185. The great flywheel thread
  186. Best intercooler boots?
  187. D8 GT. The anti-MINI
  188. Shift Cables R&R
  189. The road to 300fwhp...
  190. Fuel consumption after mod'ing
  191. Wilwood bleeding problem
  192. Please help me find a Drivers Rear R53 CALIPER
  193. Quaife Getrag 6 speed dog engagement
  194. OBX PRODUCTS
  195. pully puller
  196. OEM LSD vs Quaife
  197. Turbo/Supercharger warning ANY INTEREST?
  198. K&N Question
  199. Seattle RMW tune. June 20th & 21st at Axiom Motorsports!
  200. Seattle RMW tune. June 20th & 21st at Axiom Motorsports!
  201. Help M7 or Alta V2??
  202. going turbo i need a manifold..
  203. Lightweight Flywheel Question
  204. powerflex bushing install
  205. Custom RMW Rear Section
  206. M7 direct flow intercooler
  207. Spark plugs
  208. Really inexpensive JCW plugs - BKR7EQUP...
  209. midpipe
  210. Engine movement problems, I've tried everything
  211. pulse star
  212. What's My Next Mod Would Be? Opened For Suggestions
  213. Cam Shaft Installation How To
  214. all this talk of modification to the powertrain...
  215. What is the correct JCW spark plug?
  216. ?? put 2005/6 tranny in an 02??
  217. OBX Header + m7 Exhaust Video
  218. Need HELP before tune
  219. 315WHP no M45 or NOS...
  220. Me and ChrisMCS04 out motoring
  221. SC Pulley Consequences - Advice from Experts Only
  222. RMW/MiniCorsa go 267.9whp
  223. JUST INSTALLED MY NEW INVIDIA M1 EXHAUST...SWEET!!!!
  224. pulley install gone bad, hub stuck but not on shaft
  225. 240+ whp
  226. DIY clutch replacment???
  227. RMW tune with HAI or no?
  228. Finishing pulley install, 4 bolt go into which 4 holes
  229. NEW M7 PADDLE SHIFT THREAD, No AMVIV BS
  230. M7 OCC + JCW strut bar
  231. Need your help...pulley install/oil leak?
  232. LSD - Limited Slip Differential
  233. Paddle shift w/clutch from M7...
  234. pulleys?
  235. Jan & RMW unbelievable! +30hp!
  236. pulleys?
  237. Anyone actually KNOW about plugs?
  238. Motor Mount
  239. Pulley: Original vs. Version 2.0
  240. Supercharged
  241. What plugs - stock pulley, 15% soon
  242. RMW Rocks the UK!!
  243. Dimsport remote Tuning.
  244. Engine Mod Advice
  245. Boost gauge how-to
  246. Best replacement filter for JCW airbox?
  247. Checkmate's problem
  248. So my pulley replacement was great until...
  249. BPV/Supercharger Intake Tube
  250. any vendors have ignition wires on sale or best place to purchase
