View Full Version : Drivetrain (Cooper S)
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43
  1. hdi box
  2. Kenne Bell S/C ?
  3. RMW shorty header results @ GP0734.
  4. Side Exit Exhaust
  5. Stupid @$#%&* Belt
  6. i need help....DINAN CAI 2005 MCSC
  7. engine mount v's clutch ?
  8. What are normal coolant temp fluctuations?
  9. New custom Voltage CAI...
  10. Port for the boost gauge
  11. Best Deep Burbly MCS Exhaust?
  12. 2% crank pulley on an Auto. Problems?
  13. Trouble Removing Stock Pulley: 4 ALTA v2 @15%
  14. 19% pulley, 20 psi, cars running lean, what to do?
  15. my first minification
  16. To anti-seize or not to anti-seize
  17. Alta Intake/Crankcase Tube Question
  18. Boston RMW Tune Results: 25-27 July
  19. occ
  20. Next HP mod...hmmm
  21. Quaife Install
  22. hydrogen power
  23. OBX/SuperSprint Gasket Replacement
  24. Quaife
  25. how much hp can oem clutch take
  26. BORLA RACE question?!?
  27. milltek exhaust problem
  28. Revolution Mini Works Shorty header update on port finish
  29. Minspeed exhaust sound clip
  30. dinan boost kit gas milage?
  31. unichip in an auto?
  32. Sourcing Coilovers
  33. Advice needed. Cone filter for the stock MCS airbox
  34. Thoughts on replacing coilpacks and sparkplug wires...
  35. e85 conversion?
  36. Voiding Factory Warranty?
  37. 300 HP MCS
  38. 380 injectors for tune?
  39. Link/List of mods for S to increase HP?
  40. pic of RMW exhaust gasket over stock header inlets
  41. New mods to 05 MCS
  42. CATLESS HEADERS 02 SENSOR
  43. belt tensioner question
  44. Pulley install - Spark Plug Q
  45. 250bhp with stock head...........
  46. RMW $5K Project 'Sweet Spot' Mods MCS!
  47. whistle when accelerating
  48. Another RMW tuning session! Charlotte, NC. Results!
  49. ITG PART NUMBER NEEDED FOR DINAN CAI
  50. What Supercharger Oil to Use?
  51. Newbie Overasked Rhetorical Performance Question...
  52. Radiator Hoses
  53. I need pictures of...
  54. gatorback belt part #
  55. What about "Bmc cda" air intake?
  56. K&N Intake: Good, bad, supposed to look like this?
  57. Unichip & 17% pulley = engine damage? Unichip told me so...
  58. Pulley Install: How difficult?
  59. C02 for cooling
  60. OEM cat-back bolts - Re-usable?
  61. air intake question?
  62. Chicago area AutoXCooper * Jan Tune Results
  63. HELP Gatorback part number
  64. Need help - new exhaust to match my aero kit
  65. webb motorspors
  66. Engine swap tips?
  67. S/C Pulley Modifacation
  68. Brake Noise?
  69. my new air intake w/ pics
  70. Water meth injection system
  71. Cam or Tune...or something else?
  72. crank pulley install without oem tools
  73. Boost/Vacuum readings...
  74. Black Rims Red piping
  75. Diagnosis Help
  76. Boost Problem?
  77. Pulley Swap FTF...(minor rant)
  78. how to replace passenger motor mount in R53
  79. alta type intercooler coupler dimensions??
  80. Were to start Modding?
  81. Dinan CAI owners ring in!!!
  82. Exhaust Port Matching
  83. Dinan or Madness intake????????
  84. Another plug question
  85. How to turn off a check engine light?
  86. Speed in gears.... Clutch issues Driveline?
  87. HELP!!! ASAP
  88. where to start?
  89. OPINIONS...Ultrik intake
  90. Ultrik camshaft>?
  91. Possible Pulley Problems?
  92. Tell me what you think
  93. Supercharger rebuild
  94. STUPID supercharger question
  95. Determining pulley reduction ratio / belt size on vehicle
  96. 03 Invida exhaust to fit an 06 Cooper S
  97. SOFT clutch (aftermarket) - what to buy?
  98. Stuffed LSD
  99. JCW exhaust owners... a favor?
  100. oil catch can
  101. E3 Spark Plugs
  102. code gone bye=bye
  103. Another clutch / slave cylinder question.
  104. Pinging under load...Knock sensor, High compression?
  105. rotex info
  106. Super Over Drive Supercharger...
  107. CV Boot Replacement
  108. Deeper tone sound: Alta2.5 or IE?
  109. change in A/F readings - how to debug?
  110. Sound of CAI
  111. CLUTCH CONCERN
  112. oil catch can help
  113. JCW to 15% Pulley: Belt And Tensioner Replacement?
  114. More Kudos For Jan Tune And RMW Products
  115. RMW Dyno Tune in Boston, MA: 25-26 July
  116. Spark Plug Uneven wear
  117. Low compression
  118. No More Hesitation But Power Seems Less
  119. Looking for NJ shop for pulley install
  120. RMW stroker (aka air-sucky-thingy)
  121. What is Considered a Tune?
  122. Just bought a RMW Header
  123. Mod #1: TINT
  124. At the dyno today...
  125. Pinging?
  126. damper=sick supercharger,wha?
  127. Reasonable price for a clutch/flywheel install?
  128. Powerflex bushings from Moss Mini
  129. alta tuned unichip
  130. Little help with reading my spark plugs?
  131. What I learned from Evotech/MM experience
  132. Fresh helping of Rice
  133. FS R53 Dinan CAI
  134. mini madness stage 2 upgrade
  135. Seattle RMW Tune Results!
  136. Changing Manual Tranny fluid - quick question
  137. Detroit Tuned great help
  138. Evotech Tune from Mini Madness
  139. Will an 05 Cooper S Borla Exhaust fit a 2003 Cooper S?
  140. Coated vs. non-coated supercharger - how to tell?
  141. RMW Header Install
  142. AutoEnginuity's Scan Tool
  143. alta exhaust mod
  144. options for replacment power steering, and Radiator expansion tanks.
  145. Which Red Line Oil for Factory Limited Slip?
  146. How-to for injectors?
  147. Plugs/Plugs+Wires/Plugs+Wires+Coils?
  148. Alta Catch Can
  149. Sniper flash tool
  150. Just finished the install on Deimos71's mini
  151. Willing to rent: pulley puller and tensioner tool
  152. Fuel pressure adapter
  153. I need a header picture.
  154. New MINI S Owner
  155. for mcs 2004, invidia vs ireland catback
  156. Detroit Tuned/RMW Tune Party Results 253 whp!!
  157. Aftermarket Clutch Kits.
  158. Cam Swap.
  159. Cat back alone or get header?
  160. want to by dinan cat-back
  161. Alta V1 pully install help!
  162. RMW Dyno Tune in Charlotte, NC :18th/19th July
  163. Oil Drain Valve
  164. CA Header replacement due to dead Catalytic converter
  165. No Compression cyl#3
  166. The dreaded clutch squeal - conclusions and request for help!
  167. Intake Cleaners
  168. GRS intercooler
  169. Spark Plug review
  170. SES light = Bad Cat(?)
  171. New Exhaust!!
  172. LSD swap - is it fairly straightforward?
  173. specific RPM Studder/Power Drop out?
  174. fan running? - with ignition off
  175. tooo loud exhaust...
  176. really bad gass milage.. out of no where
  177. Belt issues!?!?!
  178. Torque Specs for Helix pulley
  179. How to tell the difference between 6-speed boxes?
  180. thermostat
  181. Changing Brake Rotors Question
  182. upper engine bushing install
  183. Alta stealth exhaust
  184. Header wrap
  185. M7 DFIC and water sprayers
  186. DDM Works intake w/ Alta JCW filter
  187. Quick Help with Spark Plug Gap BKR7EIX-11
  188. T-stat
  189. Which vendor wants my business?
  190. 15% or 17% with RMW Head/Cam/Header
  191. Changed plugs and wires, whats next!!!???
  192. Coolant or Water Temperature Range
  193. OutMotoring: what do I do now?
  194. Need Clutch help ???
  195. Header comparison
  196. A/F ratio via hack or via hardware?
  197. Limp Mode
  198. 200whp
  199. Gas Mileage
  200. Any new word on Sprint-booster
  201. Mods = Increase in MPG!?!?
  202. Engine Oil with ZDDP
  203. PLX dm-200
  204. Fuel Filter
  205. Doug Thorley Cooper S Exhaust ???
  206. Stainless steel brake line???
  207. High RPM Stumble
  208. M7 vs Alta intercooler, what one and why?
  209. read these plugs
  210. pulley alignment / belt question
  211. Ignition Coil Pack
  212. loudest exhaust
  213. Hai Done! Pic
  214. Not Happy with Alta Tech Support and Customer Service
  215. What is DME reset in the ECU?
  216. Alta Catch Can Reinforcement
  217. Tuning & Performance SHOPS
  218. Need some more PEP
  219. For ECU mapping... does a one-ball = a catback?
  220. Brake Questions
  221. Newb mods
  222. What Belt is Recommended?
  223. OBX Catback
  224. Thanks to Dan at GrassRoots Garage
  225. Pittsburgh dyno day
  226. Mechanic in New England
  227. P0420 Fault Code
  228. Water/Meth Concealed Install
  229. Water meth injection installed
  230. Cam/ Lifter major problem, yay!
  231. cam clearance help!
  232. Why no BOV
  233. RMW cam on MCSa
  234. One ball exhaust
  235. Early R53 power steering fan shield
  236. Driving Jan's GP with the 2.0L stroker motor - impressions
  237. Alta CAI Lid Problem
  238. A MINI Adventure (pan european)
  239. tip-in burble or does skynet have my car?
  240. Has Anyone Produced a Remote Oil Filter Mount?
  241. Dinan Stage 1 flash works on stock cars?
  242. INSANTIY from the STUPID B&M SSK
  243. Acceleration Vibration
  244. JCW kit dyno result...
  245. JUST INSTALLED TSW ENGINE DAMPER...NICE!!!
  246. alta cai or afe cai: which one?
  247. Best place to get.......
  248. Having the pulley mod done? Check this out.
  249. scan gauge 2 bhp
  250. SuperTurbo Dyno+Track Day data - 297WHP/232TQ
