View Full Version : Navigation & Audio
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18
  1. Car Radio on / off switch
  2. Auxiliary port on h/k system
  3. Moving climate control for double din
  4. Adding OEM Navigation / Speedometer possible?
  5. Can the Harman Kardon display MP3 CD Track Names?
  6. Fitting 0gauge cable
  7. Homemade Palm Pre Charging Dock
  8. Dice Silverline iPod interface question???
  9. OEM SIRIUS sound gone... please help!
  10. Alpine in MINI
  11. Help! Need to install Nuvi 360
  12. Blocking outside sounds
  13. SIRIUS mounting and power hard wiring
  14. 2004 depth specs for stock speakers
  15. Aux in the switch bank!
  16. Where is the Harman/Kardon Amp?
  17. How powerful is the H/K system?
  18. Is it safe to clean Nav. DVDs with alcohol?
  19. HD Dice questions
  20. Cravenspeed gps mount w/ Garmin Streetpilot: Installed pictures & feedback
  21. IPHONE INTERGRATION
  22. 04 MCS Stock HU Question & Need Speaker Advise
  23. Question of Multi-Functionality (NAV, IPod, Bluetooth)
  24. Possible blown H/K speaker
  25. MINI iPOD/iPhone 3G OEM radio with H/K adaptor suggestions for 2004 MINI Cooper S
  26. Nav System Unable to Read Map Because of Heat?
  27. OEM SIRIUS antenna base?
  28. Tried to remove the lover speaker grill.
  29. Radio wiring for Dice Universal FM box???
  30. Armrest Bluetooth Comfort System w/Smartphone Prep help needed!
  31. Time to go Alpine - How do I DIY?
  32. Stuck "MENU" button on Nav System
  33. Anyone have experience with eas eAmp module?
  34. Simple iPod hookup option for 04 (pre update) stock headunit?
  35. Stalk Radio sound distortion! looking for help
  36. iPhone integration options (R53)
  37. Question on installing the usaspec pa12
  38. Aftermarket Front Speakers on a 2002
  39. Auxiliary Jack in a 2002 Cooper
  40. Looking for input on potential setup.
  41. Noobie Question- What Bluetooth Unit is this?
  42. 2005-2006 Head Unit
  43. iPod interface issue
  44. *Unveiled* Pioneer AVIC - U, AVIC - X and AVIC - Z Car Navigation
  45. How to charge iPod?
  46. Alpine iDA-X305 help
  47. Aux Input won't give me Aux Mode
  48. Idea for GPS mount
  49. iPod and SIRIUS and phone question
  50. Factory vs Dealer Installed Ipod Adapter
  51. [DICE] help - no text display
  52. Changing Harmon Kardon 'mode' or EQ...
  53. Nuvi through the NAV?
  54. jdillon
  55. Help with complete system replacement
  56. NUVI OEM Installation Bracket?
  57. Reverse Camera + stock navi
  58. MINI theme for BlackBerry Bold
  59. OEM iPod Interface Adaptor
  60. Navigation disc issue
  61. How to test aftermarket wiring harness?
  62. Proper Remote Lead to amp
  63. MINI Dealer iPod installation AFTER purchase?
  64. Rear 6x9 Question
  65. Underseat amp grounding question
  66. 3 piece comp set
  67. Wanted: some advice on diagnosing a HK system
  68. WTB Stock replacemnt for 04 Cooper
  69. Any Gouge On The Craven FlexPod For R53 w/Chrono?
  70. H/K + JL Audio 8w7 Sub?
  71. Anyone convert ipod jack to regualr aux?
  72. H/K amp blown, is a E46 H/K amp ok?
  73. Where is the break wire need to tap it for JVC KD-NX5000
  74. New Head Unit for 04 MCS
  75. iPod cable routing to CD Changer location
  76. Should I bother with rr. speakers in changeout?
  77. GPS Newbie needs Garmin (255w?) Advice
  78. Opinions on stereo idea
  79. Could a Kenwood 6982ie fit in the 6x9 area?
  80. New system installed
  81. Rear seat delete question
  82. Replacing Speakers and Amp in H/K Convertible
  83. 2008 MINI Cooper S Cabrio integrated Bluetooth
  84. Does this setup require an amp?
  85. Thinking about changing out my H/K H/U
  86. Selling Harman/Kardon soon...
  87. H/K Amplifier Repair?
  88. Audio upgrade questions
  89. Can Copper R50 with stock headunit plug TimeDrive MP3?
  90. My non-iPod/Nav upgrade
  91. I just got new DICE from eas and need your help :'(
  92. DICE iPod installed, now no navigation voice?
  93. Need more room for amplifier! Adding Fuel cell.
  94. Factory installed Bluetooth
  95. Blaupunkt Plug N Play Amps
  96. Speaker and amp compatibility. '07 HK into an '03 HK
  97. Nav voice input
  98. Steering wheel controls
  99. Nav and MP3 upgrades
  100. Can't get my CD out
  101. Reverting to factory
  102. My radio is possessed
  103. Help with installing SWI-X
  104. Bluetooth and iPod adapter not working
  105. Help! No output from factory stereo
  106. Activating Bluetooth in a Premium Stereo
  107. Death of a navigation system!?
  108. iO Play - Bluetooth Music Streaming
  109. Opinions on audio upgrades
  110. No Nav screen on startup
  111. Head-unit ground
  112. Amps for under the seats
  113. HELP - XM Radio - no audio
  114. Navigation voice command?
  115. Replacement OEM Nav, plug and play or ?
  116. My windows, getting pwned...
  117. Switching a 2004 head unit with a 2005
  118. 2003 integration harness? Which one for H/K?
  119. Swapping a old HU for a 2005 HU
  120. Bluetooth capability?
  121. Is my NAV going out?
  122. Can I use the BMW X5 map DVD in my GPS
  123. How to tell if I have bluetooth
  124. CD runs but head unit controls don't work...
  125. R53 aftermarket BT questions???
  126. Running speakers in parallel mode
  127. iPod Touch w/factory interface
  128. Head unit not recognizing aux input
  129. Rear speakers change - DIY
  130. Few vids of the 18s
  131. Dual Box MTX9515 in MINI?
  132. Will a JL 300/4 fit under the passenger seat?
  133. I.C.E. ???
  134. Where to hide amps or satellite radio receiver type things?
  135. 2005 Mini Convertible: CD Changer Wiring
  136. Creative Zen + aux input = no music
  137. H/K Head unit + aftermarket amp ?
  138. GROM iPod interface installed
  139. WANTED: a working H/K amplifier
  140. Vibration Damping and sound proofing under rear seat
  141. Install OEM SIRIUS with H/K?
  142. Nuvi 350 — GREAT deal
  143. Need help... iPod question...
  144. Factory aux input with an HK Drive + Play
  145. iPod question
  146. 2005 H/K HU in a 2003... no disc
  147. SIRIUS receiver?
  148. 04 R53 iPod aux
  149. AVIC hideaway unit
  150. Flat pin or round pin on hard wired interface
  151. Aftermarket Nav unit in place of stock Nav
  152. Install files on Garmin
  153. iPhone in R53 connection to H/K
  154. Best Aftermarket HU w/HK system?
  155. My new boot set up
  156. Problem re-installing stock system
  157. Fair install price?
  158. Any experience w/Parrot mki 9200 & R53
  159. R50 radio manual
  160. What's the best iPod AND HD Radio head unit?
  161. OEM MINI GPS (Garmin) Nuvi
  162. What have we here?
  163. SIRIUS in the 04 R53
  164. Help! Aftermarket head unit installation
  165. Annoyance
  166. Do it yourself RCA input cable 2002 R50
  167. Troubleshooting Harman/Kardon system
  168. Nav CD Version 2008.1
  169. Need help-HU won't turn off w/ignition
  170. Where to mount XM Direct in boot with H/K?
  171. RCA preouts on H/K?
  172. Installing a Subwoofer - help from a 08 non-S cabrio...
  173. 05 Nav system
  174. Floor pan por favor? Sound proofing road noise
  175. Just bought a MINI, need help with Nav
  176. Need Help with OEM iPod interface!
  177. H/K woofer - tweeter crossover frequency found
  178. Need to replace CD player radio
  179. Grey Target Icon - 04 Nav / GPS
  180. Navigation fuse keeps blowing???
  181. Alpine iDA-X100
  182. iPod interface troubleshooting
  183. 06 radio into 03 Cooper
  184. Pioneer Avic n3 HELP!
  185. Can the stock Nav tell time
  186. Auxiliary input between switches
  187. iPod issue a good one
  188. New iPhone adapter, need guidance
  189. Blown tweeters after DICE?
  190. Rewiring 2004 MCS Door Harness - HELP
  191. H/K HiFi - trying to add a sub
  192. How have you mounted your iPod Touch or iPhone?
  193. Help! Stereo doesn't turn off when key removed
  194. iPod integration at last!
  195. Navigation Issues
  196. DIY Disaster! Audio Upgrade Failure... HELP!
  197. DICE iPod Issues
  198. Radio / single CD work, but iPod doesn't, need help
  199. DPSM owners and iPod help
  200. Cabrio stereo upgrades
  201. iPod Nano 4th gen with Dension ICE>Link Plus?
  202. Audio recomendation
  203. Recommending DVD Headunits w/ Navi expandability
  204. Stereo shuts off at certain volume
  205. MFSW function-ability with H/U change
  206. 04 HK same as 06 HK system? easy swap?
  207. Bluetooth Audio question
  208. Amplifier under the seat
  209. Replacing H/K Amplifier
  210. Upgrading sound system...
  211. Tweeter replacement?
  212. Pioneer Bluetooth Option - Anyone done?
  213. iPod adapter and Aux in H/K do not work
  214. Add SIRIUS but no harness
  215. Which channel is which
  216. R53 factory Stereo Replacement
  217. What is this?
  218. H/K Stock vs KFC-1682 & KFC-6982??
  219. Patch cable recommendations
  220. iPhone 3G MINI Bluetooth connection
  221. CD player install ?
  222. Portable GPS and Stereo Mute
  223. XM announces new channel lineup (link to original thread in 2nd gen section)
  224. iPod integration... what's your solution?
  225. Roadstersound Sub - How does it sound?
  226. 3 Way Speakers In The Door?
  227. Phone number for Roadstersound?
  228. Radio Popping Noise
  229. Cleanest way to hide wires
  230. Accessory Wire Into Fuse Panel
  231. 2005 Stock Radio fit a 2003?
  232. Finally an interface that will work on iPhone 3G
  233. Bewildered
  234. Replacing the HK Amp & Speakers, Good Idea?
  235. Holy crap! I've got Aux Input! How do I use it?
  236. Aux input question
  237. X9002 Plug Location
  238. Bluetooth for MINI
  239. HK Amp Replaced - No Sound
  240. Trunk Audio Install Pics?
  241. Would these speakers work?
  242. My GPS Mount Success Story
  243. Line Level Converter...HELP
  244. Stock H/U aftermarket amp install questions
  245. stock speaker
  246. SIRIUS radio units are not compatible for the XM merger
  247. H/K Died yesterday... HELP!
  248. New Speaker Setup - Need Help/Opinions
  249. MINI repair procedures
  250. Smallest amp
