- Where O Where can I get an Intravee II
- Aftermarket tweeters?
- Is this my CD changer cable?
- 2006 Mini S with Nav. Is there a OEM Sirius Retrofit?
- Anyone have an amp for sale?
- NewMINIStuff's Full parrot 9200 kit
- HK audio and iPod. Where's the CD changer cable?
- Mini Mk4 nav 32?
- JCW Wing and the antenna issue
- Aftermarket Head Unit With Stock Harmon Kardon Set Up
- Subwoofer Box Dimensions
- Boss Bass 600 Install
- Navteq no longer making/selling map DVDs
- Harmon Kardon... White Noise??
- is it possible to installl OEM bluetooth?
- will polk db691 fit?
- Help adding Sirius to 2006 stock system, SC-C1 Sirius Connect Universal
- Need help with speaker replacement decision
- 2004 MC, No A.M. on After Market Radio
- Any clue as to what these cables went to?
- AUX Drops in and out without notice- HELP!
- 2003 Navigation system problem.
- iPod G3 turns off at random
- iPhone as a iPod Only
- whats the best place to mount a JL cleansweep?
- 05 S CONVERTIBLE-Does it have a trunk CD Harness? Dice connection?
- Any Suggestions for a Great iPhone Mounting Solutions?
- Add Factory Nav??
- Get it all out there!
- HOW TO: Add Auxiliary Input to Switch Panel and Change Switch LED color
- Bass is hitting, then its gone.. H/K
- Navi...please wait and wait amd wait
- crackling noise coming from speakers
- Does replacing head unit disable the Nav?
- Please help with RCA connections. I've searched for 2 days!
- Want to get rid of Harman Kardon AMP/HU
- Question about stereo system!!
- NavTWEAK Color Schemes
- GROM usb/mp3 input adapter
- Are these cables for a CD changer?
- how do I attach a 3/4 "mdf speaker ring ?
- Alpine 17Pros as coaxial?
- My 2006 MCS Sub install
- Audio question 07 HK into an 08
- Adding ipod To H/K & Sirius?
- Navigation "Menu" button stopped working!!!
- 06 hk speaker replacement
- 05 MCS Speaker Confusion - 5.25" or 6.5"?
- using factory hands-free mic with an aftermarket kit
- 06 hk radio change
- Tried to upgrade the nav, now have blank/black screen
- AM Radio Stations
- Navigation icons
- Best Way to listen to ipod?
- OEM stereo randomly turns on then wont turn off
- Wondering about my stereo...?
- Need help putting stock headunit back on 02 Mini
- Built in Navigation Not Working
- stock head unit question.
- OK to mount crossovers in dash?
- Harman Kardon audio fades to silence
- What size is the 6.5 MDF spacer whole?
- Replacing stock HU - What aftermarket HU's match?
- Dealer iPOD and GPS
- Sat Antenna on Back Glass Using Rear Wiper Delete Hole
- 04 MCS with H/K questions.
- Bypassing HiFi amp?
- can I test car speakers on a home stereo?
- Swanks 2004 MCS stereo install.
- ego flash bluetooth and DICE works together
- 6 cd changer install help?
- MINI Software Update after Replacement of Factory Amp
- Aux Input not recognized problem
- '07 Cooper S Convertible and SIRIUS
- Bluetooth Blocking Radio (Audio) Play
- Looking to borrow/rent DICE box
- Question about JL Cleansweep CL441dsp
- radio problem
- What 4 ch amps will fit under passanger seat?
- Calling all techies
- Auxiliary input on H/K system
- What Head Unit do I have?
- Is keeping the Boost head unit a bad idea?
- H/K Amp needed.
- 2005 Mini Cooper S Sound System Advice/Info
- no volume display or volume H/K Amp?
- Please help, two speakers not working.
- Help Finding the "Front to Rear Channel Switch" Thread
- Which USA SPEC do I need?
- r53 tweeter question
- R56 Speaker Confusion
- Problems adding an amp to stock head unit
- Bazooka Tube with H/K. Same as normal sub?
- Garmin/Blackberry mounts?
- H/K with subwoofer?
- Does my mini have bluetooth?
- RMS of standard speakers
- New Cooper owner looking to make some changes.
- Has anyone replaced the OEM Navi Screen with Aftermarket
- Audio upgrade advice
- need help with speakers mini cooper
- HELP!! IPOD AUX!!
- CD Changer Connection Location
- Just purchased an '06 convertible. Audio question
- 2006 Mini Cooper S - having trouble pairing my iPhone!
- '04 Bad H/K Amp
- R56 JL Audio Stealthbox
- Harman Kardon Head Unit Question
- HELP with Aux port
- AM Radio w/aftermarket Alpine HU
- Pioneer AVIC-Z2 Installed Double Din
- Mod the Garmin bracket to hold an iPhone?
- audio out jack
- replacing component speakers in mini
- General stereo upgrade question
- After Market GPS
- Finally ditching the HK system
- Questions Questions Questions
- HEADUNIT
- Aux jack quit working
- Suggestions?
- HK headunit question
- Parrot 9200 question
- Aux Jack addition
- Anyone tried a Parrot rki8400 (iphone friendly)?
- Navigation is Broken - Is Replacement Worth It?
- Audio Build.
- GPS audio through Aux. input
- Satelite Radio for o6 cooper s
- Cheap Alternative to $40 MINI Aux Audio Jack
- Anyone konw if this Ipod adapter works?
- Oh no...Ipod interface questions/opinions?
- Looking for Nav mounting advice.....
- display language
- Motorola Droid and Kuda
- GPS undetected / display blackout
- '06 factory security system?
- Which Head Unit do you have?
- My Car Audio Upgrade!
- radio function problems
- Need a spare Garmin mount
- alpine ida x305
- Will BMW High Version nav dvd work in mini gen 1?
- "Mini" logo
- Bluetooth or Aux Jack
- Aftermarket Stereos
- High Pitch Squeal when using the iPod Interface
- Add a sub and amp to an HK system
- Anybody gotta Nakamichi CD500?
- Navi "Mini" logo
- ipod mounting - SoundGate M2?
- Newbie needing help - NAV not working
- upgrade: Amp/speakers/Head Unit, Need advice
- 06 HK Sirius ready - How 'ready' is it?
- DICE, X305, or other?
- Can your stock radio be turned on without a key?
- Sub woofer - jl 6w3
- Kappa Perfect 6.1. Is it worth it???
- Update of Navigation system question
- Need help with Mini Hands Free System
- MINI iPod interface playlist #6-- Used to be artists order, now song order.
- Weird Problem with Alpine iDA-X305
- Making a new mount, need to know some things about the dash
- Operating Factory Aftermarket Ipod cable instructions?
- New Maps Disc
- Rattles, Rattles, and more Rattles
- chrono pack
- Nav voice at max volume & can't change...
- Aux in & ground loop isolator
- OEM iPhone integration
- iPhone 3Gs options?
- Parrot Bluetooth/Satellite/IPod Issue
- OMG HELP ME cannot install oem ipod kit...and now radio doesnt work
- Installing Harman Kardon Stereo
- 05 H/K Head unit, just bought the MINI
- Where to get audio work done in DC?
- Boost HU Dead/Asleep?
- My $2.50 DIY Sirius Dock
- iPod integration choice for a weirdo like me
- Is this a DICE Silverine or Silverine Pro?
- GPS and Rail Traffic
- Stereo Volume Modulation on HK, any ways to turn it off??
- Front Speaker Replacement / Amp Question
- Gps in visor
- Please help: Need advice on amp and how to boost volume.
- Dice unit on 2/2005 model R52?
- Ipod Connector Cord is loose.
- AUX input shuts off for odd reasons
- MFSW Control
- Perspective View Not Available?
- Blue Tooth set up
- Good Portable GPS Unit for 02 Mini?
- Replacing Blown HK amp with MRP-F300?
- 06 MCS W/ Nav and HK AUX INPUT PROBLEM.. HELP!!
- which amp should I get???
- Aux input - please help!
- what audio system do i have
- New Head Unit
- iPod Interface with EQ Control
- Question after changing head unit
- looking for a head unit that has:
- How to turn off Nav display
- 05 HK audio - possible to have ipod adaptor + aux both???
- 05 Harman Kardon Aux Input Problem
- 2005 MCS with H/K – Blown Front Right Speaker?
- iPod adapter questions
- Where is the H/K amp?
- Newb Having some trouble
- Radio Boost CD - Owner's Manual
- Confusion Abounds
- Panel under steering column
- want to replace h/k hu
- 12-volt Accessorize...
- Battery drain since IPOD installation
- Removing Radio
- Sterio has ghost that turn it on after car is shut off. Must like the music stays on
- Need help wiring h/u
- Keeping stock HU, adding aftermarket power amp..
- Upgrading Firmware to V32
- Nav to Chrono Guages
- double din for 1st generation coopers?
- Alpine iDA-x305 in a 2006 Cooper S
- New member, V32 nav question
- Grom audio adapter
- Can't play CD's
- Sub hookup questions, how to tell what stereo I have?
- Wher is the Amp in the 2005 Mini Convertible
- Tapping off rear speakers in an 09' for sub. Install help
- iPod adapter doesn't work
- Ditching the head unit
- Radio Mute / HU pinouts
- hu change?
- full signal help
- Relocating Head Unit
- iPhone free resources!
- R56 HiFi logic front 6 inch woofers in R53
- Another iPod Post
- Alpine Head Unit w/ H/K Install HELP!!!
- '05 HK system same as '07?
- Hidden AUX input?
- Radio Reception
- How To: Wire H/K Replacement Amp & Headunit
- Recommendations on a headunit?
- Sound deadening opinions
- Help with my Satellite Radio!
- DICE radio integration help
- Help with wire routing:
- HELP. Radio stuck on...
- USB stop and radio start
