- Problem with 04 MCS radio
- annoying aux buzz from cigarette powered device
- Stock Apline deck question
- How to troubleshoot my HK audio system
- Harman Kardon and the Head Unit of Doom
- Porsche Radio knob question ?????/
- GROM USB question
- HK amp needed for R53
- H K radio problems
- HK amp question
- sub & amp
- Harmond Karden Head Unit
- how to remove nav screen emergency
- Crossover with no amp? HELP!!!
- Aux input for '02 (Impossible?)
- Where is the clock?
- gps
- Sub Enclosure?
- Aux input with NAV
- gps upgrade
- Latest firmware, map, and how to check
- Never had a "legal disclaimer" now I do!
- Anywhere else to buy the newer, H/K speakers?
- garmin install with traffic
- show your stereo setup
- Radar systems; who has what?
- opinions on Kenwood KDC-6047U
- best position for subs in the boot?
- Headunit installation problem.
- Stupid questions
- Nav system
- Aftermarket Stereo and the MFSW
- Dice Ipod Integration programing issues.
- My GPS mounting location
- DPSM remote on the amp or wiring diagram? DPSM owners?
- Does anyone know how to harwire a V1?
- OK now I need help.
- Issues with iPhone 3GS in center armrest dock
- Removing Sirius Antenna?
- Front speaker spacers?
- 2005 Owner manual
- Building/Fabricating false bottom sub box/amp rack
- Alpine KTP-445
- Replacement Harman/Kardon 2005 Speakers
- Looking to add this sub and stereo to my 2004 Mini Cooper S
- 2007 MCS w/ HK - best route for satellite?
- nfl news
- Blown basstube sub, need help selecting correct replacement sub.
- Stereo Frustration
- Front and Rear Speakers
- Help with Ipod adapter
- Someone Replaced my H/K Amp
- Which are the best speakers out of these?
- 05' OEM Head Unit Volume Knob Issues
- Enabling Code Mode in HK HU
- Best Speakers for Front Doors?
- anybody have info on built in gps
- facelift HU into pre-facelift?
- Want to get original HU for '04 (crazy, I know)
- Need step by step HU install for R53
- NO Warrantee On Owner-Installed DPSM?!
- Will the Dice unit work if i already have the AUX installed?
- USB plug's power is always on?
- Aftermarket HU Install?
- Constant/Switching power to HU
- My New Mini and New Audio Project.
- Need help for iPod hookup and how to use
- Installing an Aftermarket Head Unit (+Aftermarket Amp) through the old H/K
- Bass Problem after going to auto body shop
- Neet to buy HK front tweeter
- Nav System Install?
- Aftermarket stereo questions
- changing headunit without/ HK
- newbie want to install pioneer mvh-p8200 on mini 03
- OEM CD Changer Cable Routing ?
- "Preset Increments?"
- Standard Sterio to HK Sterio System
- usb/sd interface
- New amp-GPS Navi volume problem
- Tape Deck for our MINIs
- Sound Overhaul
- Here goes the town
- H/K + iPod = (Pandora) Streaming worked w/4.0
- Mystery Beep through Stereo
- Whining again
- Difference In Chrono and Nav?
- AM Radio & Power Lines
- which iPod/iPhone interface works with HK audio?
- Where is the wire to connect the Dice Ipod Kit located on the Mini Cooper?
- Stereo Cuts Out at High Volume
- NAV monitor
- blown speaker
- 6.5" front speaker adaptor plates
- Need To Buy A Hk Amp
- ipod/iphone interface install help
- Integrating phone into factory radio?
- Pac Swi-jack ?
- DICE MediaBridge: Anybody use it?
- Aftermarket HU, HK speakers, aftermarket amp/sub?
- No Sound, HK
- Head Unit Upgrade
- Question on Amp Installation
- Replacing HK hu and amp FS
- New OEM MINI Short(y) Antenna
- Sirius & FM Transplant into OEM 04 Sat Nav Antenna cover
- Amazing Alpine system... yep, nicer than yours
- 2004 navigation menu button
- Sealing up the rear speakers and other sound deadening questions
- gps navigation system problem
- H/K amp removal
- '03 Cooper S Amp Trouble
- question about aux please help
- Mini Cooper Radio Noise
- Need help with sd/usb interface
- Component Question
- Factory CD Changer
- H/K questions. I'm a noob.
- iPod adapter that turns ipod off when car is off
- Harmon Kardon radio just stopped working
- Iphone 3G in Mini Cooper S Convertible 2005
- Help, Setup!
- Replacing head unit with HK upgrade...
- Crossover/tweeter question
- Sirius Issue
- How do you hook up external amp to stock non-HK head unit?
- 2 ...or maybe 3 MINI GPS questions
- Help a complete audio n00b upgrade stock head unit!
- Newbie w/ iPhone interface question
- Factory AUX Input issues
- Audio System Help!!
- Can anyone recommend any bluetooth head units?
- Max amplifier size for stock electrical system
- head unit replacement with nav
- CD inserted but no CD in system
- Tailgate Speaker?
- Car mounted Smartphone - Ground Loop Isolator
- Killer Car Sound for Cheapskates
- Want Sirius with stock radio. How to do it?
- Need some better sound
- My navigation voices have just disappeared. No more Turn-By-Turn!
- Full aftermarket system install, for the win!!!
- aux question and charging of iphone
- Can anyone tell me which iPod adapter I inherited
- XM Tuner with Stock Stereo Acting Wierd.
- iPhone Hookup Question
- Matching Aftermarket decks?
- No Sound
- Mounting plate question
- where can i get a signal for and amp/sub install with stock headunit?
- Dice Silverline vs iPod interface
- Having a little bit of an issue with speaker install..
- ipod nano video (5th gen) in my r53?
- Amp & Sub Install Questions
- Off brand Head Units
- Need suggestions - audio upgrades on early '02
- Help with Sirius Install
- Installed audio in 06 MCS and now car does weird stuff...
- Universal Tach Cell Phone Mount
- anyone upgraded their battery to something BIGGER ?!?!??
- How do you eliminate audio whine?
- Nav Update CD?
- Question about new R53 system install...
- Adding a NAV?
- iPod adapter interfering with electronic system
- Basic audio questions
- Replaced HK amp!
- HK Intermittent crackle in all speakers
- Can't plug my Silverline Pro Ipod/Iphone Connecter to Iphone 4 with Bumper
- New iPhone4 not working with 1st Gen '06 ipod interface?
- Installed New speakers, I have a few questions...
- 05 Owners With Factory Sat Radio Please Read!
- Dice ?: What's the difference between Media Bridge and Silverline Pro?
- Any MINI Mechanics/Owners ever encounter this???
- HK + Sirius problem
- HK Amp Question (R50 vs R53)
- Whats the going price for a good HK amp from an R53?
- 06 Cooper non-H/k with NAV help
- CD PREP & USA SPEC Install Help
- Whats a fair price for my 06 HK head unit?
- need info please help
- HK audio system AM fades in and out
- Nav and Aux cable?
- 05 R53 With Boost = Alpine??
- After Head Unit Upgrade, No Turn Signals
- AUX turning off on stock R52
- Female harness for OEM wires
- Is using the battery's ground connection bad?
- How to add factory Nav to a non-nav R53?
- Navigation Issues
- Nav is 1/2 block off!?
- r53 HK amp same as r52 HK amp?
- OEM stero
- Any help with a JL Cleansweep issue?
- Help needed with suggestions for Audio upgrade.
- Please recommend easy to install bluetooth kit
- AUX Input for PRE-Jan '03 R53's
- Are the tweeters on or off axis.
- Are the 2005 tweeters on or off axis?
- Hardwiring an After-market Navigation Unit
- 12v to 5v ipod hookup
- Parrot CK3100 w/ Quick Connect harness
- Where to put a subwoofer?
- Installing aftermarket Sirius antenna in R53, Help!
- ok, thinking of ditching R53 hk headunit with factory sat, questions...
- Pioneer Introduces Pandora Radio Integration - iPhone App [VIDEO & PICS]
- OEM iPod Interface part numbers
- Will the steering wheel controls not work if..
- Is there a market for HK headunits and speakers?
- installing Sirius and need a quick sanity check from you experts
- Ipod Adapter, Ipod Touch and 'No Magazine'.
- Jabra BT3030 and Any Stereo enabled BT Wireless Phone
- Bluetooth & Ipod to base stereo
- Lets See Them Aftermarket Head Units!!
- My MINI reads USB: Empty!
- iphone/ipod hookup in 06 with sat. radio and HK...
- How many speakers can you fit in your Mini?!
- Car Mount for Sprint Evo 4G
- Audio/muting kit for aftermarket nav with factory stereo?
- Anyone upgrade the HU in a 2002 MC for XM?
- Need Ground Loop Isolator Help!!
- Buying an 04 with a dead HK Amp-- what are my options?
- Power for radar detector
- Remove the factory nav screen?
- Have an 04 MCS and an alpiine mrp f300 amp,
- Which Ipod adaptor?
- MFSW Adapter Question
- Mounting iPad in a MINI
- Radio Sockets Different on OEM Radios. What do to???
- Radio static sound
- My idea for a navigation/stereo upgrade
- Sirius OEM reciever install -Need some help
- Cheap upgrade
- Is there a Mini Cooper Clubman icon available for a Garmin GPS?
- Water Damaged Amp - Install under pass. seat & carpet = fail
- Aux inopt and Ipod adapter?
- Dice No Longer Plays
- Taking Out The Stock Radio Deck
- iPhone to mini question
- HK Amp Access and driver side rear hinge cover
- Explain to me switchable & constant power wiring for head units
- Cassette Manual
- Shark fin
- Combo- Serius/FM antenna
- SPEAKERS: And The Winner Is...
- Hard-wiring in a Nuvi 255W
- How do I test an amp?
- no sound - Please Help Me
- Subwoofer idea! (Pics)
- Auto Meter Gauge with Bluetooth Mic Mount
- H/K Head Unit doesn't work. Options?
