- while I replace an air filter.
- Need a clear bra installer in denver area
- 5 features I miss from my previous car
- Check out my new MINI :)
- HAtch button on fob?
- brake pad recommendation?
- Adaptive Light Control defect?
- Dealer recommendation for service in NJ
- Can I add heated mirrors?
- Were any R56's pre-wired for OEM front fog lights?
- I'm officially an owner!!!
- Anyone have window droop?
- My Baby is Dinged!
- Random sluggishness above 4500rpm?
- Mud Flaps (rally armor?)
- 07 R56 Clutch Problems
- RE: R56 Oil Hose for Turbo
- My Mini is even shorter now (accident)
- Mini Cranks over but wont start
- Advice on buying a used Mini
- PIAA 520 ATP Brackets
- oil pressure warning?
- Good Year
- Edge Insight CS Opinions?
- Rear Brake LEDbulbs
- Funky alarm (LED) behavior
- A close call MINI
- Brake light
- My JCW has no name because its a car - build thread
- Digital vs actual pic
- New steering wheel hook up?
- Roof Rack?
- Euro blind spot mirrors
- Automatic Transmission Fluid Change
- Wheel Of Fortune
- screeching sound while driving
- stock 16" conti runflats question
- Lamps in bumper, what are they?
- Random power loss
- Cooper Hatch Bra?
- Carbonfiber wrap dash trim
- Tires tires tires
- How do I remove the coolant bottle to change the oil filter?!!!!?
- HELP - '07 MCS Cold "not a death rattle?" noise
- heated lounge leather
- Couple electronic/stereo questions 07MCS
- no power when motor not up to temp
- Seat-sons Greeings Teaser!
- Mini Shop Needed-Bob Smith Area
- it's time to replace air filter
- For those of you who like to draw...
- Next Scheduled Service?
- A DIY Oil Change That's Worth the Effort
- Lowest lowering spring? H&R?
- Cold Weather Gas Mileage
- Checking Oil level
- Which OBD scanner
- The Beast's Build Thread
- Leaking thermostat...
- Oil Filter Question
- New Rear Brakes @ 23,000?
- 07 S exhaust
- buying TPMS
- Mitigating Long Term Maintenance Issues
- Driving Excitiment Application for MINI Connect
- 07 engine noise
- scan tool recomendations
- 2012 Mini Cooper S Harman/Kardon sound system upgrade
- Sport mode 24/7 or not?
- Normal Temperatures?
- Goodbye guys! (maybe a see you later?)
- My Cooper S doesn't see corners anymore!!
- Burping the Coolant System
- This is Samuel L....
- Removing trim pieces on steering wheel. How?
- OEM Shorty Antenna
- potential purchase need advice
- Question about winter tires
- new leather dash option? r56
- R56 Clutch Lifespan?
- London 2012 Limited Edition
- New tires for my 08 Hardtop
- vacuum leak coming from valve cover?
- OEM offset and compatible offsets for 2012
- Removing the fuel filler surround piece
- MINI AM2 CUP SPOILER KIT From Germany
- Loud grinding/squealing from driveshaft/transmission?
- Yah So Excited!!!
- union blackjack fuel door
- Rear mud flap = ANGRY
- R84 X-lites for R50 on an R56
- R56 2011 MC Hardtop Parts List?
- Union Jack on Roof?
- another vote for the "top side" oil change.
- "Ironically" I already got my my first warning light...
- 08 MC with Tailgate Issue
- 2012 MINI MC- Can it handle snow?
- Any Satellite Grey Owners??
- 09 MCS Rims
- Stripped Lugnut Threads
- The real scoop?
- Another One Saying Goodbye to Mini
- Horizontal headlight adjustment?
- R56 Clutch & Stuff: Options?
- What Similarly Priced Cars Compete with the R56 MINI?
- Re-wiring Driving Lights?
- Well, It's been real fun folks.....
- Do you always leave your roof rack on your R56?
- Rennline 15% OFF Holiday Sale - Now Valid!
- Who make the best runflat tire for the mini
- Navigation video playback
- So, how do YOU get treated on the road?
- Best place to sell your Mini?
- CTEK Battery Maintainer Won't Work?
- Black Jack OR Checker
- New Fix for Check Engine Light?
- Aftermarket Wheels Advice?
- Tire Sizes
- JCW rocker moldings.
- Modding Voids Warranties?
- Asymmetrical rear lights?
- Budget Navigation Possible using USB/iPod Adapter?
- Where to buy McGard Wheel Locks 27226 BLACK in USA?
- Power Steering Problem 2007 S
- Against my better judgment, I opted for the extended maintenance...
- JCW body kits installation
- JCW Aero Body Kit Installation
- Clear coat fail on wheels?
- 2 weird noises/ clutch life
- A coupla newb questions on Daytime Running Lights...
- Which retrofits make sense?
- Mystery cable at right rear
- i need rear caliper R56
- Seat cover for dogs
- Car won't start after rear brakes replacement
- what did you buy for mini on black friday?
- In Need of JCW Brake Duct Templates
- R56 Clutch recommendations?
- a how to replacing the rear bulbs?
- Can I convert rear fog lights into clear backup?
- Tape on engine wires???
- 1st Mod
- Which Short Throw Shifter?
- Rennline's Black Friday Starts Now!
- Clunking Noise
- Where is the engine build thread
- EPA-sticker
- Aftermarket headlight assy’s....
- 235 tire options...
- Opinions on the Sport Seat Option?
- anyone have this problem (pic)
- Feeler: Group Buy 07-12 projector headlight group buy?
- NM Engineering High Flow Intake - Blue Filter
- what intercooler has the radiused plate edges
- Which hitch?
- Engine cooling fan on all the time
- Should I be worried about someone stealing my spare tire? (non S)
- Retrofit questions
- Stealth bulbs 07 R56 not PY21W? Need 180 degree pins, anyone?
- All clean after all the blackout work
- West coast car trucking company help??
- talk me into or out of a mini
- R56 Water Pump Change Help
- weird sound
- Just picked up a 2012 MCS and had some modding ?'s
- when to replace belt?
- Windshield wiper size?
- Tire suggestions
- How To Do a Burnout ?
- Clutch Question
- iPod interface?
- When do I need to change spark plug?
- Service Manual Download?
- Check this out!
- Taking apart 2011 MCS auto gear selector knob
- Justa Cooper Getrag... Redline MTL or GM Synchromesh?
- New!!!
- Opinion Needed Please....
- how my mini knows when to change oil and brake?
- $5G reward offered in theft of one-of-a-kind Mini Cooper
- "noisy tires"
- '07 S Steering Failure
- Charlotte got rear ended by the biggest truck chevy makes
- New Mini Cooper Intake from AEM
- Mini Artwork
- TPMS Question
- R56 +35mm offset wheels question...
- ugly on my MINI
- Sold the MCS, happy motoring everyone!
- Looking For... Replacement Boot/Bonnet paint guards
- Bras - ins and outs
- odd engine behaviour
- Tire slipping crazy when breaking and...
- Mini Weight???
- Warranty warning!
- Paddle Shifting
- Help with brake squealing !
- Discounts on New 2012's?
- Extended Warranty?
- Replaced thermostat, can't fill with coolant???
- i dont know why?
- Help with Driving Light decision
- Break-in Period?
- my mostly useless rally lights
- Connected features that require cradle?
- spray paint mirror cap?
- *sad face* :(
- Higher mileage with no major issues post here
- Looking for pics of Minis with blue wheels
- CPO trans replacement question
- 2012 Mini Cooper S oil change
- JCW Upgrade or aftermarket?
- Check engine and low power issues
- what fluid evacuator do you use for oil change?
- Check Engine Light Woes
- Extended warranty or maintenance?
- Rattles identified, what's the permanent fix?
- What could be leaking?
- 3M carbon fiber vinyl
- My Weekend Project: Angel Eyes + Joey Modded Xenons
- Mouse winter snacks in dashboard?
- Home made Scan Gauge II mount
- Mini Cooper roof rack system key question
- when you drive downhill..
- OEM Carbon Fiber Rubbing Off 2012 MCS?
- Any regrets for Non S owners??
- Best engine mod for the money
- High Pressure Fuel Pump - Install at home?
- code p1417
- what kind of oil filter and engine oil do you use?
- coolant
- Arhhh I Think My Clutch Went
- weird sound...
- R56 dual pane sunroof
- Time for brake pads
- Best Floor Mats for Winter
- Lower Front Valence Difference?
- N18 BSH Catch Can help (2011 MCS)
- Vinyl stuff
- Mounting a portable nav
- Clutch Change On A Cooper Diesel
- What are my options for OEM tail lights?
- Oil change issues...and dealer screw up!!
- No cloth for 2012 hatchback?
- Traded my MCS for a Fiat500
- Code 0341: Cam Position Sensor
- Farewell (for now) friends...
- Cargo Liner Question
- Apparently I have CRS!!
- Worth it to extend the MINI Maintenance Program?
