- where can i find: 12V unswitched in the boot area? (right trunk area?)
- Passport SR7
- Help wiring new Halo Lamps (!)(?)
- Radio powering off every 20 minutes.
- Anybody have a Clifford Matrix Alarm with 2-way Responder Tranceiver in their Mini?
- Retrofit BI-XENONS for a 06 cooper S'
- Moving the Run Flat Button
- Mini Madness 2 Lamp Rally Kit?
- How can I add another Cig Adapter?
- RetroFit OEM Foglights into '04 MC
- 05 xenons for an 04?
- 8 Psi Boost
- ScanGauge II - Anyone ever tried one of these?
- Driver's side auto-up stopped working
- Does a light turn on when the bonnet is open?
- Factory fog light default on?
- Help needed on wiring OEM driving lights from Mini Mania
- How many Pulses per Mile is the speed sending wire?
- Audible Tone
- Parking Light Install
- Help, no air out of vents!
- Cig Lighter Plug
- Bluetooth and SIRIUS Radio?
- Where can I run the electrical from engine to cab?
- Aux Input
- Fast blinking with LED turn signal bulb
- battery rating for MCS
- Looking for switched power fuse to tap
- PIAA 19227 Extreme Whites to replace stock reverse light?
- Palo London Ubermini Light Bar & Harness
- Parrot Bluetooth Ck 3100 / Any Experience In The Mini?
- I won a door prize...
- Making a fog lamp bracket
- Problem after wiring red rear fog light
- reverse light bulb replacement with PIAA on a '04 MCS
- help needed with tach and speedo problem
- Buying an '05 Mini: windows won't roll down? help?!
- Has anyone installed an aftermarket Tach?
- Is the MINI Electrical system touchy like BMW?
- Which sunroof wire has switched power?
- Brake light question
- Rear 3rd brake light mod
- Moss Mini riding light "angel eyes"
- Where to tap Power?
- MFSW Button swap
- Can you replace an '04 steering wheel (premium) with an '05+?
- Using stealth bulbs in clear tail lights?
- Two Questions about my Xenon's.
- Flash2Pass
- Hacking steering wheel connections
- Boost Gauge Wiring
- Security
- retrofitting 05+ tailights? and additional mods
- Parking distance control switch
- Wiring lights question.
- Close windows & sunroof from key remote
- Whats better, Screamin demon or MSD coil pack????
- Antenna ripped out...
- A/C compressor no go
- turn signal prob
- OEM Driving Light Retrofit?
- Is there a kit to replace the front fog lights with driving lights?
- Replacing the horn
- Xenons not leveling
- Xenon headlights?
- xenon headlights?
- Relacing stock rally lights
- Ian's Window up mod
- MFSW, possible use
- Need bluetooth help
- Double-checking of the bulb size
- Rain Sensor retrofit
- Ignition switch hacking for remote close windows/sunroof
- Installing Aux Input by just splicing?
- I need DIY instructions for fitting HID/Xenon
- All electrical dead - need some help
- On/off switch
- Help on Side Fender reflector
- The yellow light at the end of my windsheild wipers flash when i start the car!
- Interior tube lighting
- Where to buyfind replacement sidemarker?
- Anyone use this gps?
- Aftermarket Security System
- Electrical shutdown...rant
- Defi HUD System?! anyone using it?
- Do I need to remove auto-up?
- Low Cost OBD II Reader and Resetter
- Bulb sizes for everything?
- iPod delay
- OEM Bluetooth Install
- radar detector recomendation
- Anybody using a battery cut-off switch?
- BC1 Module, driving lamps, rewiring, and old Porches...
- Questions about Ian's Auto up/DSC
- Lightweight Battery Box Fabricator???
- Using the boot power outlet for power tools
- will the oem xenon lights bolt up?
- Coolant temp warning light wiring
- Will these tail lights work on an '05?
- Retrofit pre '05 clock
- Install side-reflectors
- Question about a project I'm working on
- My rediculously complicated lighting project is almost done!!!!
- FYI adding a circuit - alternative to add a fuse ...
- Help - LED bulbs glowing faintly when car is off ??
- Radar Detector
- add a circuit
- Wireless internet in Mini S 24/7
- Wiring Question
- Bluetooth AND iPod
- Horn wiring - connector question
- Broke an oem driving light need advice.
- Blitz Power Meter
- Parrot install using newministuff harness
- i just install oem alram for 05 cooper s,
- Harman Kardon: could I fit one in my MCS
- Fabric over battery terminals ok?
- Removing snap splice wire connectors...
- Automatic Headlights- How do they work?
- Driving lights fuse blowing?
- Moisture invading my side lights!
- pass. side brake light not working.
- MCAW basic install
- Can anyone layout and fab a PCB?
- Replacing driving light bulbs
- Which fuse is for cig lighter???
- Dash harness ?
- Can both inside & outside auto-up modules be used together?
- Added some driving lights
- Battery harness Q, MCS->MC
- Another Bulb Question
- tb question
- help on routing a wire
- HELP! My stereo no longer recognizes my Aux Input.
- Extra 12Volt Plug
- Can someone help me with 2005 fuse layout?
- Thought of a use for dead button on two spoke mfsw
- WTK: H3 Driving Lamps
- Rear Seat Power Outlet Location
- 06 DIY Alarm System
- Not the usual BRAKE light mod
- Computer concerns
- Headlight Lamp Replacement
- code reset?
- iPod hookup in a 2002
- My first mod. Ever.
- Radar reads Ka band 100% of the time
- throttle body
- Another driving light install question.
- 8000k!!!
- Weird Speedo Thing
- Another rear fog light Q (and possible solution)
- Which yellow bulbs?
- 05/06 Rear fog mega mod EXTREME
- Engine Start button from Moss in a 2005 Cooper?
- Questions about iPod in a Mini!
- Chirp without alarm system?
- gauge led bulbs
- What fuse to tap for Cig/Power
- Driving Light Brackets
- Santa brought me OEM driving lights...
- Sunroof question
- Cigarette lighter doesnt work with compressor?
- Defi-Link meter help
- Schumacher 6000a battery charger, do you own one?
- BiM-COM
- What Are Those Bulbs!????
- Need pictures of PIAA fog light installs!
- Disable your Seat Belt warning chime!!!
- Bluetooth Basics?
- Harmon Kardon iPod Controller
- Nav System Question
- How do I replace side turn indicators?
- Lidatek LE-30...
- CK3100 or 3000EVO
- Factory Alarm Install...
- Fuse F-37?
- Black or smoked tail lights - pics pls?
- Convert from blinkies to strobe flashers
- Windows Up module
- Those two useless buttons
- Cigar Lighter / Power Outlet
- Interior Digital Camera Recommendations
- Factory iPod adapter- does it charge when the car is off???
- "New Autoup module"???
- Remote Control Auto Window Up Module
- LED Taillights
- Wiring a boost gauge
- Rear Brake light modification
- Terk XMDirect Smart Digital Adapter - Anyone Install Yet?
- Rear Fog Question
- help with fog lights ?
- Yellow fogs or super whites?
- Driving lights??
- Mirror Lights mod—JAPAN
- Xenon Fog lights?
- Digital Readout
- Satelite Radio/Car Alarm/Auto Starter
- Auto dimming mirror with Home Link retrofit?
- Retrofit Starter Button
- Just finshed installing my PIAA Driveinglamps
- HOW TO:Change H11 bulbs Fog light bulbs??
- Radar Detector Interference?
- Anyone upgrade their H/K speakers?
- Auto-lock stopped working after battery disconnect???
- Rally Grill Lights
- Don't you hate it when you get flashed?
- interior bulb sizes?
- piaa fog light question
- Valentine V1
- MINI Circuit 2.0 dea, I need help
- power tap for gauge lighting (Dimable)
- 05 Xenon bulbs
- PIAA LED side lights (white)
- Brake light mod add on?
- Hella ff200 wiring Question
- Solar Battery Charger (trickle)
- Tail light connectors - Where to get them?
- toggle switch question
- 2005 Rear Fog Brake light Kit
- Hi Beam wire?
- Power for Auxillary Gauge Lighting
- Switched 12 volt in trunk?? HELP!
- Programing a VW key for Cooper functions?
- Bi-Xenons: Where did you mount your ballasts?
- parking lights go in and out, fog lights out too
- Help where to hook up gauge lights.
- Brighter Lights?
- driving lights
- 100w globes in OEM driving lights???
- Burnt out H7s
- Fuse for the remote lock / unlock?
- Replacing globes in OEM driving lights
- Powerbulbs brand H7
- Which is the best Radar Detector.
- Alternate front signal blinker
- Fog Light Harness
- V1 install questions...
- think these actually work?
- Mini 2005 Current Amp Draw
- Grounding Wires
- How do I remove Right Kick Panel to get to Module?
- LED Brake/Taillights
- LED 3'rd brake light.???
- Question about guage installation (Electrical)...
- great air horn with compressor instalation!!
- Xenon Fogs
- Boot lock
- Factory alarm v. Hornet 727t
- Need Help
