View Full Version : Electrical
Pages : 1 2 3 4 [5] 6 7
  1. Electrical system in our new MINI's, is it Lucas?
  2. Illuminated Door Sills with Aero Kit
  3. Need a 12v power source...
  4. Rain Sensor Install?
  5. modifying the taillight circuit board...
  6. Question about our Horn(s) ???...
  7. HEAD LIGHT problem
  8. Stock Stereo--no power after fuse tab install
  9. Power Mirrors not working?!?!
  10. 12 VOLT POWER SUPPLY WIRE
  11. How to install factory fog lights
  12. Batt Cable and airbags
  13. HIR bulbs
  14. Wiring under the door sill?
  15. anyone install Xenons ?
  16. iPod Charger Wired Into Car?
  17. GBMINI Auto-up installation method
  18. Taking the Xenon Projector out ('05+)
  19. Hella w/chrome housing
  20. $12 turn-signal mod
  21. rear fog bulb size
  22. OEM dealer installed Driving lights. Can I put on PIAAs with no problems? X-post
  23. Electronic Water Pump?
  24. Driving light switch?
  25. bulb replacement ?'s
  26. Rear license plate lights distorting paint
  27. Dynamic Stability Control always off at start
  28. Dash Light Power Tap?
  29. Prewired for foglights
  30. Whoa. WTF is going on.
  31. need help about toggle switches
  32. New idea for a brake light mod
  33. Radar Detector recommendations
  34. Right side brake light out
  35. Garmin Steet Pilot c330 (pooped out)
  36. Memory Settings
  37. Sooo...one of the hellas has a crack already...
  38. Automatic Climate Control
  39. YD on another electrical mission
  40. O2 sensor wide or narrow??
  41. Stebel Nautilus - Can I blow my horn?
  42. Hella 500's on custom brackets install (warning- lots of large pics!)
  43. Do 02's without fogs still have wiring?
  44. questions - air conditioning
  45. auto-up/DSC auto-off and remote window circuits...can both be used?
  46. Hella 2500 Angel Eve vs PIAA 540 Cost
  47. DLR Bulb Size
  48. remote start
  49. keyless push button start
  50. 2004 Cooper Headlight Replacement..How?
  51. HID help
  52. is my MINI pre-wired for alarm?
  53. Boost gauge on the Dashboard
  54. where do i find yellow xenon bulbs?
  55. 2004 MC Tail Lights
  56. Where to buy factory alarm system??
  57. Do I have heated mirrors?
  58. Anyone have MyMini Gauge Bracket?
  59. what can I use to wrap/hide wires?
  60. Mini Cooper S - rear washer.
  61. Radar Detector Mounting ???
  62. Aux input for 2002 ?
  63. boost gauge
  64. iPod interface - what have I done?
  65. Changing H11 fog light bulb
  66. need a louder horn!
  67. iPod integration ?
  68. ECU/BC Connector Pins...
  69. problems with xenon aftermarket kit
  70. Automatic door closure and remote hatch?
  71. White side markers and "silver" front turns
  72. JL Audio XR650 - do they fit?
  73. I Need Help!
  74. horn wiring question
  75. After-market Driving Lamp wiring question
  76. Light bar and second button
  77. Higher wattage headlamp bulbs?
  78. Wanted: Right headlamp
  79. Air Bag Warning Light
  80. Heated Seats
  81. Toggle Switches
  82. Rear Fog Light Install... not finding
  83. Wiring Diagram
  84. Dealer Coding - any way around it/DIY?
  85. Power at taillight
  86. Additional Fog Lights wiring question
  87. Oil pressure sender size
  88. Ground
  89. Blitzsafe & XM Radio
  90. osram silverstars just installed......
  91. headlight problem
  92. Best place to buy PIAA 520
  93. What I am working on for Minis
  94. MCAW installed, finally!
  95. High beam & BC1 control module
  96. New Bulbs for Headlights
  97. PIAA H7 Extreme White Plus: Any comments?
  98. Amber Dome Lighting
  99. Problem with Factory Driving Light Install
  100. Factory foglights without the lights..
  101. Multi-function mirror & rain sensor wiring
  102. Alternatives to G-Tech's PASS Software?
  103. G-Tech Pro RR installation complete!
  104. New Halo Lights Install?
  105. Dealer Installed Stewart Warner Gauges too dim
  106. Ham Radio Installation
  107. Strange Radio Fuse Problem any sugestions?
  108. PIAA 540 Light Covers question: required?
  109. Custom Xenon Installation
  110. re: electronic limiter thread
  111. Stereo Wire Terminal Removal Help!
  112. Where can I get a 3rd brake light assembly?
  113. MyMiniParts aux backup light kit
  114. one new xenon = color mismatch???
  115. problem with UNICHIP
  116. One Hour
  117. Rear Fog Light
  118. Help with Unichip Installation
  119. Fog light switch
  120. Third brake light pulsar
  121. What if I replace my D2R's with D2S's?
  122. Xenon flicker
  123. Camera Installation
  124. Clear/Amber Side Repeater Bulbs (WY5W)?
  125. Escort SoloS2
  126. Boot light LED flickering when car is running?
  127. The ultimate guage?
  128. Xenon Match fog light bulbs from Visionbulbs.com - Poor quality
  129. Freakishness with trunk light - why is this happening?
  130. Pioneer CD Changer in 06 Mini
  131. PIAA 540 Driving Lights/Daytime Driving Lam
  132. F vc C????
  133. Rear Fog / Brake Mod on '06 Cabrio?
  134. MCS reverted back to auto-locking of doors..
  135. Alternative to OEM Alarm
  136. Plug and Play HID kits
  137. PIAA's as fog lights?
  138. Using LEDs in rear fog lamp. (question)
  139. is it safe?
  140. low-impact bluetooth audio mod?
  141. Is there a fuse for the OEM rally lights?
  142. Where does this go?
  143. MCAW window will not roll up
  144. How can I get the digital speedo with crono package?
  145. LED Taillight Bulb Questions
  146. future lightbar installation question...
  147. DCS, TPS, and ABS lights are all on....why?
  148. Automatic Wipers Retrofit: Is it possible?
  149. Defi boost gauge
  150. Motorola IHF 1000 Blue tooth
  151. Factory Blue Tooth...
  152. Xenon K's and color questions.
  153. CompuSTAR Remote Start - Anyone have one?
  154. Hands Free/Bluetooth kit
  155. A question for anyone with Cibie lamps installed on their vehicle.
  156. Clear 3rd Brake
  157. Bluetooth and MFSW
  158. Anyone have a bluetooth Adapter?
  159. DIY OEM alarm?
  160. 8000K HID kit installed
  161. Experience W/Valentine 1
  162. Driving light install - below bumper
  163. How can I make my Fogs come on with the parking lights?
  164. I want both doors and trunk to open with one press, possible?
  165. False X Band Alert from Valentine 1
  166. Clear Tail Lights for 06 S with fog lamp?
  167. getting the digital mph to work on 04 and back mcs
  168. Rear spoiler brake light flasher module
  169. Denso IK22 Spark Plugs
  170. MiniatureTrailers wiring harness woe
  171. MCAW Auto up / 1st mod complete!
  172. Installing OBC
  173. Need Help with OEM fogs on a cabrio!!!
  174. Cooper low beam bulb?
  175. Replacement xenon bulb?
  176. I want a Austin Powers novelty horn
  177. Retrofit Auto Dim Mirror
  178. What is a good High Beam match for Xeon lights?
  179. Luxeon LED Bulbs
  180. Modify Buttons on Multifunction Steering Wheel
  181. Thermocouple Uncertainty - IAT Gauge
  182. Detecting when car is moving?
  183. reverse beeper
  184. Battery Isolation Circuit.
  185. water temp.gauge
  186. Need advice on aftermarket lower bumber fogs
  187. repair advice on wire attached to rear window...
  188. Any fiber optic gurus out there? I've got some questions...
  189. Alarm Systems
  190. OEM fog light install
  191. PS2/TV Wired into car?
  192. need to make fogs stay on
  193. Door Switch Question: "Ground triggered or positive"?
  194. Cabin wiring
  195. OEM 04 HU for an 02 MCS
  196. Info on OEM interior lighting...
  197. g-meter on the cheap
  198. Speedometer Light
  199. Replacing foot well lamps with cathodes?
  200. Headlight Connectors?
  201. Not really a mod, but involves electrical...
  202. Asking the experts: I need a illuminated, 3-position switch - Help?
  203. DIY: Silverbulbs
  204. need wiring help
  205. Discrepancies with Aux Driving Light instructions
  206. Retrofit Chrono pack to a 2006 S
  207. Moss Running Lights w/Angel Eyes" - has anyone used these?
  208. PIAA light kits
  209. Amperage Draw when "Asleep" and how long..
  210. Installing on/off switch, do I use POSITIVE or NEGATIVE wire?
  211. aftermarket fog / driving lights in stock MCS bumper cutouts?
  212. Stereo placement question
  213. taking apart the license plate light assembly
  214. warranty question
  215. Anyone have StealthOne installed?
  216. XM is Two Letters
  217. Best route for wire / rear wheel to fuse box (cross post)
  218. 122 Degrees Farenhiet?
  219. which small battery?
  220. Map/Cabin light access
  221. Quick Question on parking lights/turn signals
  222. Anyone put aftermarket HID/Xenon on thier 02-04 MCS?
  223. Boost Guage Lighting
  224. how do you remove the 5w parking light
  225. Hella "Angel Eyes" and manual switch question...
  226. Mikey's Bluetooth Phone I/F - audio quality?
  227. Problem with passenger side Window
  228. Brakelight Mod Question ?
  229. MCSa horn is Neg or Pos connection?
  230. Installing a Remote Starter - 03 MC
  231. speedo gauge
  232. MCAW problem (big problem)
  233. clear side markers with silver bulbs
  234. Cigarette lighter plug help...
  235. question about brakelight wiring?
  236. Interior Light Wiring Diagram
  237. I need really bright highbeams...
  238. Anyone have Viper installed??
  239. Which taillights
  240. Headlights
  241. Center vent gauge install.
  242. Finally had to install a GLI
  243. Stewart Warner Boost Gauge for $70 need pix of oem gauge & knowledge of max boost
  244. Radar detector false signal
  245. Help! OEM iPod Adapter : self install or dealer?
  246. Radar Detector Fuse Add-in
  247. Need help with a circuit to turn on my carputer
  248. OEM alarm questions
  249. wierd v1 / throttle interaction in the dark
  250. Don't buy Rocky Mountian Radar Detectors! Just my advice.
