- Valentine One install
- shift light or turbo timmer install anyone?
- Radar/Laser Detectors/Jammers
- light question
- R53 OEM Driving Light Adjustment?
- Additional Switches
- Change A/C controls ???
- Brighter?
- Any Feedback for this item?
- Hella 500 - Blown Fuse???
- Hella 500 discrepancy?
- Thermometer Chime
- Are these Xenon Headlights aftermarket or oem?
- Air horn installation
- Led's help!!!!
- Optima Red top battery questions
- How do I access to factory fog locations
- Flash to pass garage door opener alt. version
- Looking for Antenna Connector
- Help wanted with OBD coding Fog light
- Corner Lenses - How To Install
- Retrofit Projector Fogs
- Emergency brake nightmare
- Need a little electrical help
- rangeline pod
- Parking lamp positive wire color
- Xenon on reverse
- changing temperature/speed reading
- D2R 8000K in a MCS 05
- ScanGauge II, gives the real values for speed and water temp?
- Has anyone added Fog lights to a MINI without them?
- prosport illumination problem
- Help with diagnostic codes...
- MCAW = No more convenience power to the windows?
- Horn Beep on Lock
- Does anyone have experience with these?
- Repositioning of OBDII connector?
- MINI Projector lights
- gauges not working?
- Battery Relocation??
- Spark Plugs - How cold can you go??
- Sirus & Ipod adapter
- Extending Range of Key Fob?
- Anticipated OEM Battery Life--05MCS?and Recommended battery to replace.
- 3-2-1...There goes plug #2 into the hood!
- Attn: track duty cars...RE: Airbags
- headlights
- HELP: tail lamp stay on when key is out
- How to wire PIAA's
- damn firewall.
- Light bulb replacement gone awry!
- Dead Wipers
- HID Ballasts/Bulbs
- MSD coil
- Remote windows up? Does this work?
- boost gauge install
- 6th gear dumb question...
- Autopia Fog Lights for Mini in Bumper?
- Anybody have these yet?
- Hella 500s
- How hard to replace module on driver door?
- wiring up new horns, need help with relays
- What size resistor for license plate new LED's?
- radio questions
- Retrofit questions
- Splitfire: torque rose with large popularity!
- D2R HID bulbs
- Headlight bulb size for 04 MCS w/ Xenon
- analog ScanGauge alternative?
- Fogs turn off w/ DRLs on. Help!!
- installing a shift light
- Bulb sizing help, wnat to replace stock with LED's!
- Driver door in DEAD! won't lock or unlock
- K2 Horn Relay location?
- MP3 CD
- Fitting Driving Light Switch in Parcel Shelf
- Angel Eyes/ Halo lights
- OEM auxilary boost gauge by itself?
- The OEM Halogens ---> OEM Xenons diaries
- Boost guage to match grey tach
- Driving Lights
- Xenons getting dimmer?
- Best source for OEM Driving Lights
- Grounding wire for gauges
- That was fast!!!
- Interstate MT-47 battery for MCS
- Scan Gauge II
- Another rear fog light question.
- Swap 55W H7 Hi Beam for 100W?
- Great Read... HID Retrofitters Guide
- Battery Storage Capacity Ratings
- coil harness question...
- #9 OBD pin...
- auto-on OEM foglights
- Plug & Play ECU upgrade
- Wire iPod to Stock Radio in 05 MCS?
- 2002 Cooper S with P0037 Code
- OEM Fog Light Query
- Driving lite brackets - rivets or screws?
- Apexi RSM-GP vs G-tech pro
- Another Boost Guage wiring question.
- Air Horn installation
- avg, kph, mpg, range displays built-in
- My light bar
- Installing OEM Driving Lights. How do you do the wiring
- Vacuum line location
- taking apart toggle switches?
- Better bulbs, need advice
- What are these?
- Superchips Problem
- aftermarket battery in my MINI?
- AutoMeter Gauges too dim
- driving lights wiring question
- R53 Bi-Xenon
- TSB for 02 PS fan & radiator fan sharing issues ???
- REAR FOG LIGHTS QUESTIONS
- iPod
- Rally lights to toggle bank?
- Two sets of hella 500's on one relay/wires?
- OEM White Tail Lights Top (3rd) Bulb Does Not Function?
- Aftermarket alarms
- Gauges installed in center vents
- SES Light but no OBD II codes?
- Want bluer xenons?
- Ian's vs MCAW
- Interior accent lighting.
- Change miles to km/h, how
- gauge wireing
- Can I add xenon lights???
- Coil Pack vs. Plasma Booster
- Mini Cooper Light Diagrams
- Autometer rocks !!!!!!!!!!!!
- FUSES! Headlight fuse for 05 Cooper S which one?
- Torx screw size for removal of the tach
- Any used Autometer "Marine" gauges?
- What component can I use to...
- Another ECU wiring diagram thread...
- Window doesnt go down. Motor or regulator ???
- Lights won't turn off?
- Help, Trouble shooting HK Stereo
- HELP, removed pass seat now have airbag code
- Third brake light pulsar installation
- Battery????
- 07 MINI S fuse box(panel) & car AUDIO
- O2 simulator experience??
- Am I missing something on the PIAA installs?
- Range shown on display
- Gauges - water temp vs oil pressure
- Gauges - electrical or mechanical?
- Which Apexi SAFC to get?????
- Interior Dimmer Switch
- Turn signal bulb size in front bumper?
- Boost Gauge Reading Expectations
- No power to EITHER 12v outlet!
- hid bulbs differences
- Green 'plug' of BCM
- HID problems
- $400+ for rear fogs on a 2003????
- EGR valve, where??
- Looking for a DIY to add power to boot of 03'
- 02 sensor problems..
- BC1 Module and X332 Plug ?????
- my clock goes to "0:00" now and then...
- Water Fall LEDs
- Digital plug-in voltmeter
- Headlight bulb replacement
- V1 Remote Mounting
- Tail lights.
- Tail-Gater Mod?
- Anyone installed the "italian horn" from Griots?
- ULTIMATE LIGHT MOD
- 3rd Brake Light Stayed On!
- V1 Hardwire via add-a-fuse: what am I doing wrong?
- digital AF gauge.... which one????
- Madness IC Temp Monitor
- MCS Battery Replacement
- Best way to run amp power wire in non-s to boot?
- How to install an In-dash DVD Player?
- bluetooth kit vs using tomtom's handsfree
- Boost guage Install?
- Laser Blinder Install
- Is there a good guide to remove the raido
- Electric window acting up
- replacing factory Driving lights
- Reprogram key, how???
- Parking light buzzz....
- FOG LIGHTS
- My power outlet is broken
- Toggle bank question
- Adding an MP3 Port by the toggle switches??
- power and dimmer for gauges
- Thoughts on the Hella 500 driving lights?
- vanity mirror light problem.. help!
- variable intermittant widshield wipers
- Airbag Help in R53
- trying to pick 2 guages...
- Zenon on all the time
- anybody tried yellow PIAA H11's?
- Interior Light Problem
- Adjusting speedo
- Oil Pressure Idiot Light Sender Thread Size?
- "Oogah" horn install
- Tire monitor and DSC light on--Help!
- OEM Fog Lights Melted?!
- Driving Light Install Question
- Stalling
- Seat belt tensioner, check???
- Remove chrono pack?
- Things I re-learned today
- anybody give these a shot?
- Keyless Remote Sunroof left open
- Hella 450/530/550/500 amber fog
- Simple Recording OBDII Device?
- RPM input for Traqmate Data?
- Driver door doesn't unlock but will lock with the remote
- What does these codes means??
- Mph to kmh, is it posible
- PIAA driving light brackets
- Reset "Service engine soon", how???
- Program key in R53, how?
- Question for owners with Angel Eyes Running Lamps
- Fog Lamp Retrofit
- Yet another Bluetooth question...
- Fuse Help Requested
- Clarification on Boost Gauge installation process...
- Aftermarket Rally Lights Closest to OEM?
- If you hardwired your radar detector....
- Help! Problem with Xenon headlights..
- Palo Uber 'PATENT INFRINGEMENT'?
- arc lights
- Cigarete lighter jack in back switched power??
- Wil this reader work?
- Airbag help, R53
- How to disable the airbag light w/ aftermarket seats?
- Charging Problem
- Gauge Dimmer wire
- Electrical Help
- splicing power
- stock oil pressure sender
- "Extreme Problems"...
- Is it My Head Unit? Or is it Worse?
- Power through the firewall?
- MSFW Buttons, 3rd Party HU?
- Power Steering EPS stopped
- Seat heaters TOO warm
- Footwell light tap (fade in fade out lights)?
- just installed the innovate motorsports LC-1 Wideband Controller
- OBD-II Shift Light
- Valentine 1 Mode?
- adding 4 aux. lights
