View Full Version : Electrical
Pages : 1 2 [3] 4 5 6 7
  1. O2 sensor replacement
  2. HK Headunit vs Non HK
  3. My MINI doesn't have xenon headlights but I want them
  4. 48 feet (or so) of LED's off of the power inverter?
  5. Nav Tach/Speedo in non-Nav car
  6. Right headlamp, where???
  7. What kind of light are the Driving lights?
  8. Heated rear seat mod. Is it possible?
  9. Need help re:rear washer wiring
  10. Autopia driving lights?/Driving lights help!
  11. Taillight Retrofit Kit for pre-05 S
  12. Check Engine light
  13. Hoen "Xenon-match" subjective-blueness
  14. Mod Ideas?
  15. Radio doesnt work...
  16. Cornering light modification
  17. Laser Jammers
  18. Is the MSD coil frying my Iphone
  19. Convert OEM Driving Lights to Fog Lights
  20. Tachometer trouble
  21. Garmin Nuvi GPS Won't Charge?
  22. cruise control defect
  23. Voltage?
  24. Battery Problem
  25. raptor shift light install
  26. High Beam Garage Door Opener Issue(14v and not 12v)
  27. Deka ETX14
  28. Help with idea...
  29. Airbag warning light! Help!!!
  30. Backup Light Not Working
  31. Speedometer Wiring Diagram
  32. Anyone sell the iride still?
  33. Installation and mounting of Escort 9500ci radar detector
  34. How to replace the side marker bulbs?
  35. Anyone have the Wolo Bad Boy or Stebel Nautilus Air horns?
  36. Battery almost gone, should I replace with OEM?
  37. How to Change BMW "spot light" Bulb
  38. Getting more out of the R53 MFSW
  39. LED Taillight Bulbs???
  40. Anything new out there other than Lojack?
  41. Best driving lights for twisty wooded roads?
  42. Urgent help. Got stuck with boost gauge install
  43. Boost gauges
  44. Add a circuit
  45. STRI Oil Pres Gauge, signal comes from...?
  46. Hella Driving Lights Help!
  47. Speedometer signal wire?
  48. LED fog lamp
  49. Weird electrical problems...
  50. Can this REALLY be possible?
  51. Strange Alta driving lights question
  52. FIAMM or other Air Horns for MCS
  53. Prosport Gauges of St. Pete Florida ROCKS!
  54. Info on A/f ratio gauge installation?
  55. Ultralight battery
  56. Alarm components
  57. DIY Non auto HVAC light bulb replace
  58. DIY Fog light install (in-bumper)
  59. eBay projectors and HID KIT on a 04 MCS???
  60. New lights
  61. Wiring diagram for rear turn signals 06 R53
  62. How do I disable the headlight beam adjustment
  63. D2S bulb replacement
  64. O2 simulator How-To
  65. 2004 Remote Key Fob
  66. Speedometer light in tach
  67. HELP - mod gone bad, want to fix before MTTS
  68. Light Bar
  69. MSD Coils Don't Use Stock Coil Bolts?
  70. Wipers on '06 MCS
  71. Wiring to mirror control panel help
  72. Help Install of Electronic Pro Sport Boost Guage
  73. Need help with PIAA driving lights
  74. New Sub and Amp
  75. '04 MFSW Question
  76. AUX input question
  77. eBay halo headlight adjustment
  78. what size bulb?
  79. Installed Autodim Mirror on '03 MC (not pre-wired) - Need Wiring help
  80. Angel Eyes Running Lamps Wiring Question
  81. Dechromed Lights Problem
  82. Undercar LED's
  83. A Mod I Wish I Had Done 2 Years Ago...
  84. Need Tutorial (DIY) for Fog Lights
  85. Help: PIAA 540s or Hella FF200s
  86. D2C 8000k
  87. low beam height adjustment
  88. White side marker blinkers/turn signals.
  89. HELP: How to install Hella Optilux 2500s
  90. stop automatic door lock
  91. Wiring diagram needed
  92. GBMINI is da Man
  93. green-yellow...yellow-green...AARRGGHH!
  94. Light bar install???
  95. Running new Blinder M45 Extreme
  96. Light Bar Help!!!
  97. Alarm on a 2004 Cooper S
  98. DIY Battery Disconnect (Peace of Mind)
  99. Newb Xenon questions
  100. Modding rear fog to also act with hazard lights???
  101. Help finding electrical connectors...?
  102. boost gauge flutter
  103. Switch Help
  104. iPod issues...
  105. Disconnecting battery before installing?
  106. tach problem
  107. Tire Pressure Sensor issue
  108. Full Toggle Switch Bank
  109. What bulbs do I use to change halogen to white bulb?
  110. Alta Gauge Pod
  111. Hydra EMS
  112. Help Needed - Electrical Gremlins
  113. Changing temperature reading on display
  114. Wideband
  115. Lower grill light bar question
  116. Hole in the firewall
  117. HELP! Which is the 12V constant for CD changer?
  118. iCarPlay Wireless FM Transmitter for iPod or iPhone
  119. Disable Tire and DSC lights?
  120. Rear Hatch Wiring
  121. Major Battery Problem!
  122. BMW alternator in MINI?
  123. EBay XENON HID Halo Projector Headlights
  124. 06 Projector to 03 Xenons
  125. Airbag warning light...
  126. Wiring 620w of Rally Lights
  127. Dry Battery
  128. Powering from remote keyless entry fuse?
  129. Random locking
  130. Xenon HID projector headlights on Ebay
  131. Boost Gauge Installed - Are These Numbers Right?
  132. De-chromed the tail lamps
  133. Need help, Mini won't start...
  134. Rear Fogs
  135. Need New Battery - Please Help!
  136. Failed MCS O2 Sensor
  137. MSD Ignition Coil set?
  138. Shift light
  139. Xenon Bulbs
  140. Toggle switch questions
  141. Starter kill switch install
  142. Driving and fog light wiring (Hella 500)
  143. Need help with gauge pod lighting problem
  144. Matching Lights
  145. Your SIRIUS [aftermarket] setup? Mine = Chaos
  146. Projector [Xenon] Headlamps & LED Tail Lights
  147. ff200 Xenon!!
  148. Looking For Boost Gauge
  149. Brake lights out ONE SIDE??
  150. headlight lense
  151. Question about break lights
  152. HID Fog Light Mod
  153. Wiring diagram, 2005, where??
  154. Help! Can't find a place inside the car to connect a ground
  155. Xenon High's and Low's
  156. Tire Pressure Light
  157. Flat tire switch polarities...
  158. Another Ignition Wire Thread
  159. VIP Driving Lights... pics?
  160. Autometer Air Fuel Gauge
  161. PIAA 540 Driving Light Install
  162. location of OBDII with respect to Euro Parcel Shelf?
  163. pics of the stock alternator
  164. Headlight problem?
  165. On board computer problem after installing aftermarket HIDs
  166. Installing backup camera
  167. stewart warner shift light
  168. Fog lights stay on with high beams
  169. Kind of a crazy question here
  170. Driving Light Wiring Problem
  171. Horns
  172. Optima Battery Help!! 34/78 red top
  173. Driving Light Rewire
  174. help with V1
  175. driving lights
  176. Plasma Booster
  177. Door Lock issue
  178. Clear (White) Side Reflectors
  179. Bulb List
  180. Mystery Dash Issues
  181. help with my fogs
  182. HIDS on an 03 cooper
  183. Which wire in '04 Overhead Clock Console?
  184. Driving light install... Without cutting up aero grill..
  185. OEM MINI Upper Gauge kit
  186. Problem - boost gauge install
  187. Which wire is the high beam wire?
  188. Speedometer Mileage Reading
  189. Bi-Xenon kits
  190. Replace weak OEM fog lights ?
  191. Power blip going into reverse
  192. On Board Computer question?
  193. Switching fog lights to driving lamps
  194. How To: Shiftlight-in-tach mod (R53)
  195. Major electrical problem. all input appreciated.
  196. PIAA
  197. Best Diagnostic Computer
  198. Best Diagnostic Computer
  199. Removing parking lights....
  200. Wiring clip question - stock white footwell lights.
  201. Interior Lights
  202. Electrical genius question
  203. Utilizing Scangauge Readings
  204. What am I missing? Retrofit list....
  205. 2004 mini cooper alarm wiring diagram, download link inside
  206. hid lights
  207. Air Bag Resistor - After Market Seat Replacement
  208. Lighting Questions
  209. Cradle for iPhone?
  210. Flashing Brake lights
  211. Installation instructions for OEM driving lights
  212. h4 vs h7 bulbs
  213. wiring for CD changer
  214. Philips H7 12v 80watts Rally Bulbs?
  215. Remote Start question
  216. 3rd brake light pulser
  217. power source for a A/F gauge
  218. dual alternator setup
  219. just got my valentin one
  220. where to buy immobilizer bypass kit for mini?
  221. Got a set of OEM Reflector HIDs but driver side not working
  222. internal antenna???
  223. Passport 9500i Install
  224. wiring diagram for aftermarket alarm, 04 mcs
  225. fog light toggle console part #
  226. Wiring Help
  227. Best HID Kit?
  228. HID lights
  229. Clear Tail Lights
  230. Side turn indicators
  231. What is this the orange box...
  232. Remote Start 06 MCS 6sp
  233. NEED AMP....NOW!!
  234. MFSW, does they work on any MINI??
  235. AFTERMARKET CD PLAYER WITH H/K SYSTEM??
  236. Boost Gauge Buzz/Vibration
  237. switch install question
  238. OEM Alarm Install- How much for the additional wiper switch?
  239. Thinking of adding a fuse box....
  240. MCAW Programming Question
  241. Problem: Boost gauge not reading...
  242. OBDII Codes
  243. Weird interior light issues...NE1 have this?
  244. Signal wire from Steering wheel Controls
  245. Yellow high beams???
  246. adding lights
  247. Installing fog lights
  248. Auto Meter Oil Temp Gauge
  249. Adding xenons
  250. Airbag light??
