- Stealth amber lamps
- AM radio and shorty antenna?
- how to reset service interval indicator?
- Driving Lights
- non hid cooper to hid cooper
- will the sprint booster from an r56 fit on my r53?
- LED interior overhead light
- Horn Alternative, European
- MINI Cooper S Switch-Key
- rally light replacement bulbs
- GAS GAUGE?
- Help!!! rally light install
- ECU Reset & Programming
- Alarm install Help!
- Bi-XENON in a Gen 1 ?
- Bypassing HK amp in 06 mini conv sport
- Interior door handle led
- interion light fuse place
- Devil in my wiring harness, multiple problems
- want to rewire factory fog lights. HELP!
- Taillights
- Can I connect 2 add-on 12v cigarette lighters...
- Seat airbag light tricks?
- Liberator "Sniper" RE-Flash tool?
- OBD problems
- Another switch bank question
- What amp and speaker harness?
- Tuning options for R53 MCS
- Stereo Problem?
- 06 R53 fog bulbs - help
- Air Bag Seat Switch
- iPod help?
- Negative Ground?
- After Market Headlights
- Rear Fog or Back Up Load
- Wire a toggle to LED???
- How does the key battery really recharge?
- Is my mini pre-wired for alarm?
- PLX Kiwi Wifi
- OBC speedo clock option / info readout help!
- Fog Light Swap
- 6 switch toggel panel pinouts and wiring diagram
- LED "Audi Style" light questions
- Any Interest in a ready to hack I-Bus/Arduino interface?
- Tuning my own ECU?
- Fuel Gauge Broken?
- Map lights
- OBD II port has no power or signal
- ACS - Dashboard function
- Do I have to buy a separate ...
- Anyone using an Optima Battery in their Mini S
- Led Wiring Help!
- help with boost gauge please!
- Adding obc dispaly to navigation dual cluster
- no hazard flash after pushing key to lock
- What are these cables?
- Powered horn
- Chrome Halo projector headlights
- 03 MCS HID to Halogen conversion?
- Scangauge: A/F Ratio for R53
- Fog light bulb size
- Scangauge: what kind of computer does mini have
- Tach wires
- Interior Dash Light Change?
- Wiring schematic, for the Dimmer switch.
- Battery? Alternator?
- HID ballast mount location?
- Third Reverse Light Help.
- remote start..
- Wiring for power under dash?
- Decent cheap rally lights?
- Some truth regarding HID kits
- R53 Navigation - Onscreen Volume Control
- Adding Auto Headlights - Convenience Pkg
- Key issue. will not program
- Sunroof will tilt but not open
- 2006 S Cabrio Battery?
- What bulb is the daytime running light and the ones next to front turn signals
- HID fog lights
- '03 Cooper S Xenon Headlight Help!
- Cruise Control
- Yet another HID Retrofit Question...
- Joey Mod-No Xenons now help!!!
- Alta rally light bar ambitious wiring
- Alta light bar- can't get lights to aim higher
- Passport radar detector goes off when I floor it.
- Does anybody have experience with NCR?
- Audio Upgrades?
- Outside temp sensor failure
- OBD wires + boost/volt gauges = no power?
- LED Dome Light - Autolumination
- MINI WDS back online
- KPH displayed on R53?
- Aftermarket HIDs Gone Terribly Wrong
- 2004 Mini Cooper S HID HELP!!!
- Exterior Bulbs
- Alta light bar ideas
- Hid help needed asap!!
- Projector Headlights
- Aftermarket radio
- MSD coil mounting bolts
- Headlight Verticle Adjustment Screw
- Does the Factory alarm add on have its own remote or is it intergrated into the key
- OBD port cover
- Bluetooth function?
- Post Cat Wiring Schematic Help Needed
- HID Help R53???
- Aftermarket HID previously installed, help!
- Sporadic but Severe Speaker Static?
- removing bulbs
- Aftermarket HID Ballast Mounting Point??
- Multi Function 3 spoke Wheel
- MAS POWER? What is this picture.
- mfsw
- Battery died now Headlights don't function properly
- boost and a/f gauge help please!!
- How many idiots does it take to screw in a light bulb?
- Ambient temp sensor & harness...
- Wire colors - anyone have a wiring diagram?
- Rear fog Light Install
- Replacing 05+ tail lights with 02-04
- speedo needle sticking
- 05 cooper s window dip
- Rear drivers side bumper repaired-tail light non functioning
- Driving light OEM switch, whats it look like when installed?
- Help Me Identify and help with Driving Lights
- What is the typical current drain when the car is off
- Reccomendations on a good battery?!?
- Losing Charge - grounding issue or battery?
- Autel MaxiDiag eu702
- Tapping circuit:Which one is the power supply that is only activated by the ignition?
- obd
- LED Bulbs for Autometer Gauges
- Installed H11 fog bulbs instead of H7. doh! Is this fatal?
- HELP! Small fire, now OBD port not working
- Garage door remote Mod
- Xenon replacement housings
- Innovate LM-2 anybody using it?
- DRIVER SIDE LOW BEAM OUT! HELP!!
- Rear Fog Enable/Program - info needed
- quick question -- wires to clock
- Driver Window Stuck in "UP" position
- OBDII pin identification
- two questions=footwell/boot
- Car doesn't start after bad driving lamp install, need help/advice!
- please delete
- replacing the factory switch console to control hood mounted lights?
- where to find foglight xenons?
- Digital/Analog boost gauge
- Sunroof, instrument lights and heater not working. Help!
- key remote not working
- Secret Ian Cull Single Click Mode!
- Electrical issues
- Need To Find A Headlight-Activated Power Source
- Potentially serious wire harness problem... need help.
- Output voltage lead tps wire...
- Speedometer backlight always on...
- MM tapless adapter 4 oil press > temp?
- Xenon help
- center brake lamp for MC 2005 cabrio
- Calculating fuel economy
- homelink custom install
- Early 2005 R50 Halogens to OEM 02-04 Projector Xenons
- Fuse Grounding Screw, please help! 2005 MCS
- Clear Tail Lights mod.
- Any possible rear window installs for RD?
- Power Steering Fan Mod.
- Chrono Pack Oil Temp Sender Location?
- AirBag seat switch connector
- Replacing Factory AM antenna, with NMO mount?
- Egg Yolk Bulb Blew out. R53
- Interior light randomly coming on?
- Electrical Mayhem; Locks Windows and Lights
- Spark plug gaps
- Driving lights instead of fog lights
- can someone HELP ASAP?
- Install MSD coil
- Osram Nightbreaker bulbs mini review
- location and color of e break line for nav install
- Horrible AM reception
- Aftermarket radios
- How to wire up a tow trailer?
- D1S Bulbs
- Lambo MCS
- Trying to get HID projector and light..
- Adding a switch to the FIAMM air horns...
- Xenon alignment mechanism broken...
- Rear fog light wiring
- Help on Unichip installation
- Where to tap for gauge lighting under toggle switches
- Need help finding vac line for boost gauge
- Spark plug removal
- Hand brake light flicker
- Oil filter adapter plate
- AC power
- Raptor Brand 35W HID Kit for $40 ???
- LED conversion for gauges?
- My Stebel Nautilus airhorn install, stock location
- OEM driving lights - center console switch position
- Need fuse help!
- AC low pressure switch and AC wiring diagram
- Programming the key fob
- Airbag passenger seat sensor failure '05 MCS
- M7 Tuning car fog lights.
- Found this great DIY
- Brake lights always on...
- The easiest and best connector ever!
- HID lights installation
- Tricking the MRS
- Optima Red Top 34R in 2002 MCS
- ProShift Street shift light
- Xenon to Halogen headlights
- Need help in detail on hardwiring a radar detector
- Airbag problem, faultcode 06
- Help with stereo install!!!
- Amperage to the horn?
- Bulb conversion chart for the MINI Cooper S
- Function of plastic battery box?
- USB howto?
- European turn signal
- Colder plug really necessary?
- Does our Coops have keyless start?
- 05-06 Key Programmed to an 03?
- Hidden radar install
- DME Connectors how to remove
- iPhone hard-wire installation question
- New battery install?
- R50 and R53 starter
- How do you replace a Xenon bulb???
- Xenon headlight out and/or flickering
- Fiberglass Headlamp ring
- Bypassing Clockspring for Remote Mount Cruise Control Buttons
- Main engine wiring harness trouble
- 1st Gen TMAP Pressure/Voltage response
- What kind of switch for folding mirrors?
- Have Halogens and want HID/Xenon? See inside.
- Will Not Start.
- Optima Red Top 34R in 2003 MCS —*Installation Question
- Interior light question
- Headlamp issue
- PLX DM-100 Gauge experiences?
- Passenger side mirror auto down
- fog light help
- Driving lights
- Interior electrical completely OUT?!?!?
- Need help on the JOEY MOD!!!
- Mysterious ticking from the boot
- Grill light MC
