MINI Cooper MINI Cooper specs
MINI Cooper MINI Cooper Forums MINI Cooper Pictures
Mark Forums Read MINI Cooper radio MINI Cooper latest news
Welcome to North American Motoring, the North American MINI Community of owners and enthusiasts!
You are currently viewing our boards as a guest which gives you limited access to view most discussions, articles and photo galleries. By joining our free community you will have access to post topics, communicate privately with other MINI enthusiasts (PM), respond to polls, upload your own photo gallery and access many other special features. Registration is fast, simple and absolutely free so please, join our community today!
If you have any problems with the registration process or your account login, please contact our support team.
Go Back   North American Motoring > MINIs in General > MINI Camera and Video
Not a member? Register now!
Welcome to North American Motoring !
» Main Menu
Upgrade Garage
» Latest Main Topics
another tire replacement...
MAF
O2 sensor failure
iPhone 3G snap-in adapter...
HELP! Seeking used engine...
300hub hp on a M45.... it's...
Can I add iPhone/Bluetoot...
No problems here...
P 0171 with RMW Header
Find a mechanic in Central...
Advertisement
Vendor
 Aftermarket vendors
Thread Tools Display Modes
Old 12-29-2005, 09:54 AM
JeffS JeffS is offline
Gallery
Anyone do product photography? Need help with lens choice
[edit] Decided to go with the 100mm macro (along with the 24-70). Need to decide on lighting and spend some time getting used to the camera now.
I'm getting ready to pick up a 20D and I need help deciding on a lens for some product photography. Items will be jewelry - indoor in a light tent.
Considering
- EF 100mm f/2.8 USM Macro - $469.95
- EF-S 60mm f/2.8 Macro - $399
Or... do I really need a macro lens as opposed to something like:
- EF 50mm f/1.4 USM - $319
Not trying to be cheap... just not sure.
I'm trying to get in on the tail end of the canon triple rebate, so considering canon lenses only. Will be buying two lenses for now, one for the product shots, and one general purpose, maybe a EF 24-70 f/2.8L
I'm obviously a photo noob, but my wife's business has grown to the point that we can't continue to pay someone to photograph everything (sounds backwards, I know). I'll learn as I go, but figure I should at least start out with pretty close to the right lens. Any help is greatly appreciated.
'02 MCS
'05 Tuono Factory
'02 Futura
FS: Cooper S engine/transmission swap
Old 12-29-2005, 10:21 AM
davidwhitt davidwhitt is offline
Gallery
Hi
I do a lot of photography work on the side and consider myself a semi-pro. I use Minolta so I can't really comment on the quality of the lenses. The macro lenses in general will allow you to get much closer to the subject. The size of prints is something to consider, as you could probably get by with the 50mm if you can crop a lot, meaning you won't be able to print as large. If I recall correctly the USM simply focuses faster and more quietly, not supremely necessary for this type of work. The field of view would probably be best somewhere between 70 and 110mm (though 50 is not too bad). Good lighting, set up, background etc (and use a tripod) will probably make up for most lens deficiencies.One good place to ask this question is in the canon forums at dpreview.com.
David Whittingham
Old 12-29-2005, 10:27 AM
10851CS 10851CS is offline
Vendor
Gallery
Jeff,
My daughter has a D20 and uses the EES 17-85 Macro that came with her kit. She got it from B&H Photo in New York.
Their site is: http://www.bhphotovideo.com/ . She has bought a lot from them and they seem to always have the best deals around.
Earl
Old 12-29-2005, 11:38 AM
tsukiji's Avatar
tsukiji tsukiji is offline
Gallery
The 100mm macro would be the better of the two.
Old 12-29-2005, 11:43 AM
theroyalwe's Avatar
theroyalwe theroyalwe is offline
Gallery
there are a few great options... there is the 50mm 2.5 macro usm from canon here
or the 60mm f2.8 macro here
they are 239 and 399 respectively. also consider getting the 'life size' converter for the 50mm and you'll be doing pretty good.
like davidwhitt said, the lighting and setup are more important than the lens. you can get excellent product photos with most lenses with the right setup.
- You can call me TRW if you're into the whole brevity thing -
Old 12-29-2005, 12:07 PM
hoopi's Avatar
hoopi hoopi is offline
Gallery
I have the Canon 20D and the 50mm 2.5 macro lens. It's somewhat slow focusing at times, but it does a great job. Remember that the 50 mm 2.5 also has a "life size converter" that adds extra elements. I have some samples from this lense if you are interested.
Old 12-29-2005, 12:16 PM
hoopi's Avatar
Gallery
Also, as a reminder, doing product photography, your subject isn't "moving" so a slow lens really isn't a problem. You might consider using a zoom macro lens to get the best flexibility. Usually clarity is the reason people go with a prime lense. But if you take a zoom macro and use a highe f-stop, a tripod and a flash, you should get some good results.
As an example, I had to take some pictures for my sister for Ebay, and the only lense I had available with me was a 35-80 mm, not a very good lens really (it was an old free lens). But I used the flash, placed the objects in a makeshift light box, and used a higher f-stop and the photos really surprised me. And that lens wasn't even a macro lens.
Old 12-30-2005, 08:52 AM
hoopi's Avatar
Gallery
I found a sample. This was the first day I got the lens, so I hadn't figured out the depth of field just yet.
Old 12-30-2005, 09:22 AM
theroyalwe's Avatar
Gallery
are those grains of rice?
Old 12-30-2005, 09:44 AM
hoopi's Avatar
Gallery
Quote:
Yep, that's rice! I didn't have a good flash at that time, so it's not the best picture, but it does show you what the 50 mm macro + life size can do.
Old 12-30-2005, 02:30 PM
MarkS MarkS is offline
Gallery
I agree with the comment that lighting is really critical. The light tent is definitely a good idea. I have a friend who makes and sells jewellery and does her own photography; she's gotten very good at it. Some shots here.
As for lenses, the usual complaint about relatively short focal length macro lenses (50 or 60 mm) is that the working distance is short; there's not much room between the front element of the lens and the thing you're shooting. With the 1.5x crop factor going on (at least I think that's what it is with the 20D--I'm a Nikon guy) it's not quite so bad but, depending on the size of the jewellery, it might be a problem. Something to consider, anyway.
Two alternatives to dedicated macro lenses are extension tubes and closeup lenses. Extension tubes are just hollow tubes that move the lens out from the camera body and allow closer focusing distances. Closeup lenses screw on the front of the lens like a filter. The Canon 250D and 500D closeup lenses have two achromatic lens elements and work quite nicely.
Focusing speed should be a non-issue. Focus manually.
Mark
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
First Try: In Car Photography ThePritchett MINI Camera and Video 13 09-11-2007 01:05 PM
Wedding Photography UKDragon Off-Topic 23 04-26-2007 05:00 PM
Photography Attempt Rick-Anderson MINI Camera and Video 16 11-26-2004 11:24 PM
Fuel saver product. Snakeoil or good product? wainair Drivetrain (Cooper S) 4 10-07-2002 04:46 PM
MINI CooperMINI Cooper PrivacyMINI Cooper Terms of UseMINI Cooper Guidelines MINI Cooper Advertising The North American MINI Cooper Community
  MINI Cooper news, forums, FAQs, and reviews for enthusiasts and owners of the North American MINI Cooper
 Copyright © 2002-2008 North American Motoring. All Rights Reserved.     Powered by vBulletin and vBulletin Plugins by Drive Thru Online, Inc.
Search Engine Friendly URLs by vBSEO 3.2.0
