JCW Anyone add a power module to their N-18?
A lot of F56 JCW owners rave about adding either an NM or Dinam power module under the hood. I haven't seen hardly any R56 owners claim the same, maybe 1 or 2. I think Burgertune or something makes one too. I'm told that Dinam does not. They cost $300-400 and add like 20-30 BHP. I'm kind of interested. Any comments about these easily installed boosters? I'm not talking about a tune, just the clip on power module. Thanks in advance.
Yeah I've seen lots on the MCS forum, just not on the JCW forum. I was wondering how much it helps that car. I think my JCW is pretty fast as it is, esp. compared to my 2007 MCS.
Buy a Burger Tune for your N18. You don't seem to be a believer for as long as you post here. Spend the $300.00 and you will see.
If you are not happy or afraid of the performance improvement, just remove it. As far as I am concerned, this is a major one for the JCW engine.
Not sure for just the base S spec engine.
This is simple and you don't need to be a tech to do it.
Vendor
Sorry you won't get 20-30hp out of a plug in module, or even close to that. We've played with them and never really been satisfied with the gains, especially since we can do a real tune and gain huge power. So my suggestion would be use the $300 toward a real ECU tune as that will actually gain you boost and real power. Also you will gain throttle response you will notice.
https://www.waymotorworks.com/perfor...-cooper-s.html
There's a reason you always see the plug in modules for sale used, ask those owners how the two really compare as they usually get a tune and ditch the plug in.
Vendor
A JCW is an MCS so the tuning still works, the files are different as they will be based on the programming numbers in the ECU.
With a JCW you will actually net more power with the ECU tune
Thanks, so how much does an ECU tune set you back? And who can do that, it's not anything like clipping on the JB+ I'm sure.
Burger is the safe way to go and cheaper before major upgrades.
By the way, the JCW engine is not the same as the S. Review your data.
Vendor
A Plug in module is actually less safe than a proper tune. Reason being that it is a module that plugs into a sensor then gives the ECU a false signal to keep making boost. When you do this you are actually moving more air than the ECU thinks it is. So the ECU is then using a table for fuel and timing based on less airflow than you actually have. Using a real tune we can change the set points and adjust the tables to have the proper fuel and timing relative to the boost and airflow we will now program it to have.
I never said a JCW and MCS have the same engine. I was saying a JCW can be tuned just like an MCS, but they require different files based on ecu#. Because in the previous post TheBigNewt said he didn't have an MCS, he had a JCW. All the JCWs are Cooper S, they are just a Cooper S JCW if we want to be specific. And depending on the year of the JCW will depend how different it is. The 07-09 N14 JCW has the exact same engine as a standard Cooper S. In 09 they started to build factory JCW cars which the engine was different along with a ton of other parts like turbo, injectors, pistons, and so on.
I don't drive on a racetrack and see no need to buy a new and/or reprogrammed ECU when there is an easier way to improve performance for less.
The JB+ works fine for me and for many other satisfied owners.
No...... I simply go for less trouble in the long run, believe me.
MarioKart is a Manic tuner in LA area, very active on this site. I contemplated manic tune a while back and he says his out of state customers ship him their ECU, he tunes it the same day it arrives and sends it back overnight shipping. Minimum turnaround is probably 2-3 days, Arizona is fairly close. There are other manic dealers around the US too: http://www.manicmini.com/dealer-map/4586066233
Looks like there's one in Phoenix if you're in that area.
Nope, I was planning on going Stg 2 with my 08 but then plans changed, I sold it, and the new JCW is still under warranty for another year. So far I like the JCW with stock power, and I have the pops/burbles already which was one reason I wanted the Manic tune for the 08
There is no reason to mess up to reprogram again the ECU from a tuner unless not being anymore on the warranty and/or going to the racetrack every week.
I am partial to the JB+ because my MPG is better on Sport mode. Maybe it is related to better overall air quality from where I live.
