6 speed manual transmission
Usually good to start from the top and work down. Maybe remove the shifter boot and check for some small object adrift blocking the way. Here's a step by step. Next step would be linkage.
http://www.redlinegoods.com/MINI07install.php
Is your car a 1st or 2nd gen car? This is a 1st gen forum.
Being a 2007 Coupe I would say that you need to do the following:
You may need to remove some intake components to get to the shift weight on the trans, clean the connections up and grease everything in the shift linkage on the trans.
We've had multiple cars that we have had to do the same with.
Sandijs Shifers
03-23-2016 02:13 PM
JWA
03-20-2016 04:29 PM
NYTransplant
03-13-2016 11:10 AM
