JCW Garage Interested in John Cooper Works (JCW) parts for your 1st Generation MINI? This is where JCW upgrades and accessories for the Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs are discussed.
JCW components
Old 03-29-2014, 03:32 PM
Striped Toad's Avatar
Striped Toad
Striped Toad is offline
JCW components
I have an '06 JCW (tuning kit, brakes, springs), and need to replace the front struts. The part numbers I was given by the dealer through my vin: 31-31-6-780-521 and 31-31-6-780-522. I'm curious if there's a difference between JCW struts vs non, since the description I came across mentioned nothing about John Cooper Works. I'm wondering if my MINI was fitted with the suspension kit after port, would the standard Cooper components be listed under my vin, or the JCW?
Old 03-30-2014, 05:06 AM
ashchuckton's Avatar
ashchuckton
ashchuckton is offline
JCW suspension was not factory installed on your car. Either at port or at the dealer. Do your struts have red springs all JCW struts do.
Yes the JCW struts are different. I think putting normal sport struts on the front will give you an unbalanced set up.
ECS can get you the correct parts. They are a sponsor here.
Old 03-30-2014, 07:49 AM
Striped Toad
Thank you. Yes, the springs are red.
Old 04-04-2014, 06:03 AM
ECSTuning is online now
Received 1,964 Likes on 1,764 Posts
I am here. Just saw this post.
Yea those are for the JCW Suspension Kit with the red springs.
Those look like the correct part numbers:
John Cooper Works Strut Front - Left
http://www.ecstuning.com/Search/SiteSearch/31316780521/
John Cooper Works Strut Front - Right
http://www.ecstuning.com/Search/SiteSearch/31316780522/
Based on my theory is that the JCW struts are made to pair with the springs and are tightest dampeners out of the suspension offered.
They might still have the JCW logo stickr on them if it has not worn away or fallen off over time.
Old 04-04-2014, 06:15 AM
Striped Toad
Thank you. Any thoughts on Koni FSD? Would they be a "better" or not perform well vs OEM? -I'd replace all 4 if I went with them.
Old 04-04-2014, 06:18 AM
The Koni FSD are not suppose to be used with lowering springs which the JCW red springs will lower the MINI. I would stick with the JCW struts as they at matched to the springs and would perform the best.
Old 04-18-2014, 03:52 AM
Striped Toad
Thanks. Ordered some from you couple days ago.
01-04-2019 12:51 PM
08-12-2015 01:24 PM
08-11-2015 11:58 AM
PelicanParts.com
08-04-2015 02:45 PM
Quick Reply: JCW components
