JCW Belly Pan
Old 07-09-2015, 07:44 PM
BennyF's Avatar
BennyF
BennyF is offline
I see this belly pan is so close to the cat converter and exhaust
any heat issues or heat retention in the engine compartment. I wonder why Mini did not include this with all the CM. Seem to be a no brainer for protection.
You can see how close it is to the exhaust. yipes...anyone..
  #52
Old 07-10-2015, 04:06 AM
spiney's Avatar
spiney
spiney is offline
Belly Pan
Everything I have read says that due to the magic of aerodynamics it actually reduces underbonnet temperatures by managing airflow better. I know what you mean about proximity though, but there's a heat shield on there and at least on my Roadster I haven't seen any effects on the belly pan.
  #53
Old 07-10-2015, 04:31 AM
bmwr606's Avatar
bmwr606
bmwr606 is offline
Belly Pan
mine has been on for a year now, just had it off for an oil/filter change and saw no effects from heat of downpipe or exhaust
before i reinstalled the bellypan i went for a quick spin to make sure there were no leaks and really noticed the difference in noise
  #54
Old 07-10-2015, 05:13 AM
BennyF's Avatar
BennyF
BennyF is offline
Thanks. I will get one for sure.
  #55
Old 07-10-2015, 05:14 AM
BennyF's Avatar
BennyF
BennyF is offline
I know my mom gets free oil changes, I think if i get this, I will remove it prior cause I feel the dealer is lazy.
Did you notice a cleaner bay...
  #56
Old 07-10-2015, 05:26 AM
ECSTuning is online now
Received 1,965 Likes on 1,765 Posts
Thanks for the update.
  #57
Old 02-09-2018, 11:32 AM
Hello,
The pan just has to be dropped for an oil change, it very light in weight. Much like the JCW GP 2 Belly pan kit.
Also there are little plastic washers on the back of the speed screws so when you undo they , they say with the tray, and don't fall to the ground.
We include all the additional hardware ( which does not come with just the pan ) so all you do is hold it in the middle and with a quick turn 1/2 of the phillips head screw , it comes out. You can see the speed screw on the corners of the pan.
Countryman / Paceman JCW Belly Pan Kit for the ALL4 and the JCW Countryman for the US , which was not a stock item. 51759809304KT 51759809304
http://www.ecstuning.com/Search/SiteSearch/51759809304KT/
Not hard for oil change.
Thanks and hope that helps.
The Euro JCW Countryman / Paceman Belly pan is back in stock.
  #58
Old 02-09-2018, 03:07 PM
vetsvette's Avatar
vetsvette
vetsvette is offline
Moderator
Wish they would make one of these to replace the cardboard one on the F56.
  #59
Old 02-15-2018, 07:01 PM
PureWorks's Avatar
PureWorks
PureWorks is offline
Still can’t justify the $500 plus tag for plastic....but what else is new with Mini OEM parts
  #60
Old 02-15-2018, 07:40 PM
PureWorks's Avatar
PureWorks
  #61
Old 02-16-2018, 05:06 AM
They were much cheaper when we found them before (only stock on euro models), then MINI caught on to what we were doing as its a mod in the US and they raised the prices dramatically. Happened the same way with the GP2 belly pan, we were like the first people in the world to figure out it would fit all the normal R55-R59 cars and what hardware was actually needed, then about 8 months later the price went way up.
bratling (07-10-2018)
  #62
Old 02-16-2018, 05:11 AM
vetsvette's Avatar
vetsvette
Moderator
Yep. I remember thinking about ordering one for my R56, and while I was thinking about it the price skyrocketed.
  #63
Old 02-16-2018, 06:48 AM
spiney's Avatar
spiney
spiney is offline
My GP2 pan was $260 from ECS in 2014, and now I see it for $360. Glad I got in when I did.
  #64
Old 07-01-2018, 04:26 PM
one73ronin's Avatar
one73ronin
one73ronin is offline
whaaah... mine wont fit
the clips for number 1 and 2 are too small and just fall into the hole. the same clip is used for 3 and 4. my original little "pully cover" was missing the clips it was supposed to go into as well, held on by one speed screw. either way, the belly pan i have(which i bought off the forum) is either old and heat warped, or the whole front end of my car is tweaked (which wouldn't surprise at this point...) disappointing really, i wanted the extra protection when i lowed the car. but my previous attempt to lower the car didn't go well either....maybe this is all a sign....
  #65
Old 07-02-2018, 06:32 AM
spiney's Avatar
spiney
spiney is offline
The pan I got from ECS for my Roadster came with some clips to turn those holes into places that the speed fasteners would work with. You clipped them over the structure first and then it fit perfectly. If you bought it used those clips are probably still on the other car.
  #66
Old 07-02-2018, 06:38 AM
Yep, you need to have the clips with our kit. From the factory, only some of the clips are there and we have a kit with the skid plate that includes those. PM me with a picture of what you are missing and i can help.
  #67
Old 07-02-2018, 10:05 PM
PureWorks's Avatar
PureWorks
I just bought a brand new ECS belly pan off of EBay...great price...thank you!! I’m waiting for my next oil change <1000 to go to install. I’m hoping for reduced noise, obviously under carriage protection and maybe even a little better mpg...
  #68
Old 07-02-2018, 11:35 PM
one73ronin's Avatar
one73ronin
take pictures of your process please.
i'll take some of my issues here soon to show, just got to get to the 4th first.
  #69
Old 07-03-2018, 06:07 AM
Its not hard to do oil changes with it my Gp2 pan you just hold in the centerand a quick couple turns and its off.
Did you just get the pan for your countryman, if you got the kit es2678451, then you got the whole kit with the needed extra clips.
  #70
Old 07-05-2018, 08:04 PM
one73ronin's Avatar
one73ronin
figured out how i was putting the clips in wrong on position 1 and 2. i was trying to go into the rectangle hole left-right instead it needs to go front to back. even figuring that out and fixing a clip that was too bent, the pan wouldnt stay on, by either poping the clips out when locking or wouldnt lock at all. its just not for me, that's all.
  #71
Old 07-06-2018, 05:29 AM
Thats weird, it should work. Take pics and I can help you.
  #72
Old 07-10-2018, 07:10 AM
bmwr606's Avatar
bmwr606
bmwr606 is offline
pureworks,
definitly quieter than without on my 2012cms all4
  #73
Old 07-10-2018, 08:20 AM
Yep, thats what i could tell on my r58 JCW with the gp2 version
  #74
Old 07-10-2018, 10:46 AM
bratling's Avatar
bratling
bratling is offline
Super Moderator
Hit up Rennline! http://www.rennline.com/Skid-Plates/products/925/
I was up there for prototyping earlier this year; amazing workmanship:
View this post on Instagram
ECSTuning (07-10-2018)
  #75
Old 07-10-2018, 11:07 AM
Yep, we have it also. Part #U06
https://www.ecstuning.com/b-rennline-parts/v-mini/
Looks great on your F56 Glad you had offered up your F55. We needed this option.
Quick Reply: JCW Belly Pan
