I have a 2006 MCS JCW convertible. I bought it with about 66,000 miles on it and now it has around 75,500. I have had no problems at all since I bought it, except what appears to be the endemic "running hot" business. But as long as I check periodically to be sure there is enough fluid in the reservoir, that is not a problem either.
By the way, I paid $15,500 for it, in perfect condition inside and out, every package except navigation. I thought it was a good buy when I bought it, and think so even more now.
One reason why I took mine into the shop was due to an oil leak that was noticed about 4 months ago.
So since it is in the shop for service 2 we are pulling the sub frame to get to the leaky seal, pulling the control arm bushings, the starter, and replacing the clutch.
I need my car tip top for work and the upcomming winter.
Just had my 2006 JCW in the dealer for the last warranty work (over 48K now). New clutch, flywheel, front exhaust, motor mount, coolant leak repair...= $2200
BTW, superchargers are covered by smog laws in CA, and must be warrantied for 70k miles.
__________________ 2006 MCS-JCW No. 15543, BRG/W, Sport Pack, Chrono Pack, M7 SRP I love deadlines. I love the "whooshing" sound they make when they go by. - Doug Adams ambientpixel@mac.com
Very expensive tune-up, clutch, starter, and bushing replacement.
I try to do my own work so it frustrates me to see high repair costs that are probably 65% labor.
2006 MCS JCW GP #1405: Adj Front Camber Plates, 19mm Rear Sway Bar, MM Front Lower Brace, Milltek Cat-Back, TCE 13" Front/11.75" Rear BBK, 15mm Spacers, Wheel Studs, JCM Modified Intake, MM Filter, Gauges
