MINI Cooper MINI Cooper specs
MINI Cooper MINI Cooper Forums MINI Cooper Pictures
Mark Forums Read MINI Cooper radio MINI Cooper latest news
Go Back   North American Motoring > 1st Generation MINIs > JCW Garage
Sign in using an external account
Register Forgot Password?
Welcome to North American Motoring !
Welcome to North American Motoring,
» Latest Main Topics
Advertisement
Thread Tools Search this Thread
Old 09-29-2009, 03:45 AM
KandyRedCoi KandyRedCoi is offline
Send a message via AIM to KandyRedCoi
Gallery
S to GP...how?
well at first i was thinking about selling or trading in my 06 Cooper S for a GP, but there are those days that i need the back seats
so i just convinced myself to get my cooper S as close to a GP as much as i can
as of now for performance i have: Alta V2 pulley/belt, short shifter, HR springs, 5zigen wheels, oneball exhaust
questions is as far as engine and suspension performance is concerned what would i need to change/upgrade from my S to make it at least somewhat comparable to a GP version?
thanx in advanced
-Coi- For Sale:2006 Royal Grey Mini Cooper S
Unique Custom Watch Straps--> www.CTDesigns.us
Old 09-29-2009, 09:28 AM
JIMINNI's Avatar
JIMINNI JIMINNI is offline
Gallery
Your already close with just the pulley, I'm assuming the Alta is a 15%? Get a cam and a tune and you will be past it in performance. Get some kind of under stut system and your handling will be fine also. Since you are in SoCal, I would give Mynes Performance a call and get yourself over there a set up a tune.
Old 09-29-2009, 10:23 AM
Gallery
^do they have a website?
Old 09-29-2009, 10:33 AM
JIMINNI's Avatar
Gallery
Quote:
PMed you.
Old 09-29-2009, 01:22 PM
quikmni quikmni is offline
Gallery
As Jiminni, noted an ECU tune is key. You might also need larger fuel injectors to go with the tune, especially if you go with a different cam.
On the engine side the GP is pretty much a JCW engine kit (see below) with a couple upgrades:
- Larger intercooler
- GP specific ECU tune
On the suspension side the GP is again pretty much a JCW suspension (JCW yellow stripe springs and matching shocks) with one upgrade:
- Aluminum rear trailing arms
On the brake side the GP uses the R53 JCW front brakes and different pads.
To reduce weight the GP does not have a sunroof, rear wiper, HID headlights, rear seats, or rear insulation. The GP also has aluminum trailing arms and relatively light 18" wheels.
The JCW engine kit includes:
- Match Ported Head (not a big deal)
- 380cc Fuel Injectors
- Air Intake
- 12% Pulley
- Colder Spark Plugs
- JCW ECU Tune
- JCW Cat-Back Exhaust
2006 MCS JCW GP #1405: Adj Front Camber Plates, 19mm Rear Sway Bar, MM Front Lower Brace, Milltek Cat-Back, TCE 13" Front/11.75" Rear BBK, 15mm Spacers, Wheel Studs, JCM Modified Intake, MM Filter, Gauges
Old 09-29-2009, 02:27 PM
MoxieMini MoxieMini is offline
Gallery
For those, you can just get some R56 trailing arms and lower fitment bushings. They'll run you about $300/arm, I think.
Old 09-30-2009, 02:35 AM
Gallery
great thanx for all the 411 peeps, i think i got the bases covered for the engine and suspension parts
how about the "looks" department, mainly the exterior body pieces to make my car as close to a GP as possible?
thank you!
Old 09-30-2009, 09:56 AM
JIMINNI's Avatar
Gallery
thank you!
M7 makes a rear spoiler that is close to what the GP has.
Old 09-30-2009, 11:12 AM
Gallery
From what I understand it is a little difficult to obtain the GP aero kit panels from Mini unless you have a GP. The GP kit has the wing, front bumper, side skirts, rear bumper, and flat belly pan panels.
With the addition of the Wing, Mini also moved the Third Brake Light to a lower position on the GP.
One alternate option would be to go with the normal Mini Aero kit. It can be purchased from Mini or aftermarket vendors.
Old 09-30-2009, 11:18 AM
Gallery
Quote:
i will def give that a look
do you mean the JCW body kit?
Old 09-30-2009, 11:50 AM
Gallery
Well it was not specifically called the JCW body kit.
The Aero Kit was a dealer installed option available for any Mini.
It included a front spoiler, black front grills (3 pieces), rear valance, and side skirts. I believe it was a $1200 option plus dealer paint and install.
Here is a link to the OEM kit from Mini Mania:
http://new.minimania.com/web/Item/NMX2006/InvDetail.cfm
Old 09-30-2009, 11:56 AM
Gallery
^ok gotcha, thanx!
edit: just ordered a tensioner stop from alta before i install my pulley and belt and before going to mynes for a tune :D
Old 09-30-2009, 04:09 PM
Gallery
another thing, i just noticed that MYNES is in AZ, is there a SoCal shop that offers the same perf packages?
thanx!
Old 09-30-2009, 04:16 PM
Gallery
I believe MYNES also has a shop in SoCal.
RMW is in SoCal, I believe Irvine.
Either of these two tuners would be good.
Old 09-30-2009, 05:35 PM
Gallery
^sweet, you peeps are good, i look forward to starting my build up and sharing with all of you as i go along
thank you!
Old 09-30-2009, 05:58 PM
JIMINNI's Avatar
Gallery
thanx!
Dang I'm sorry, I had thought Mynes updated their site. Yes they have relocated to SoCal. Lake Forest, which is next to Irvine. I actually called them today to see if you called Call them and talk to Mike, at (714) 240-8970 Tell him Jim sent you M7 I belive is near Chatsworth?
Old 09-30-2009, 06:09 PM
Gallery
^ok gotcha, ill try and call em tomorrow
yes M7 is local, i keep seeing that one sick grey mini with the aggressive wheels and big spoiler rollin around :D
Old 09-30-2009, 07:24 PM
Gallery
This is true, but I've seen it done. I'll try to find out who to talk to about getting it done. If I recall correctly, it really depends on the dealer. Some seem to be more stringent than others.
Old 09-30-2009, 10:11 PM
mackedmini mackedmini is offline
Gallery
well, i'll be honest i tried acquiring the inner quarter panel plastic pieces(pricey!)... and my service advisor was completely cool about it, he said he'd contact one of his customers with a gp to see if he could use his vin number, he was cool about it but the service manager was the one person who **** blocked that transaction : ( i still dont quite get why, his dealership woulda made money on the parts! people now a days, such haters
Old 09-30-2009, 10:16 PM
Gallery
ps a gp is over priced, or atleast was when it came out limited production... i know some people gonna hate, but seriously an s you can make into a gp performance easily, all it is, is "special" in my opinion... limited in one word, like a true ss impala from the 60's with numbers matching
Old 09-30-2009, 11:01 PM
howsoonisnow1985's Avatar
howsoonisnow1985 howsoonisnow1985 is offline
7th Gear
Gallery
I ordered bumper, lower apron and under tray and besides VIN dealer made me either bring in the GP in or take pictures of pothole damage, to place order. Radiator mounts did not require pics, its a normal MINI part. They even knew I had a GP before the pothole damage, cause I had brought it in to show them peeling paint on bumper, that they agreed to fix.
BTW: Also GP has LSD and basically zero options other than MFSW and heated seats. That means no sat nav, no rear speakers, auto air, etc.
Yo Jimini I thought they were in Lakewood??
2006 MINI Cooper JCW GP0019
RMW tune & cams*17% pulley*ITG filter*Brisk plugs*H-Sport Comp RSB*KMac camber plates*resonator delete*TSW studs/jack pads*H&R 5mm spacer*CT AX6 pads*Motul RBF600*RedLine*15x7 Motegi TrakLites2*Nitto NT01 205/50-15
BRG/W 2003 MINI Cooper S R.I.P. Sheila
Old 10-01-2009, 12:31 AM
Gallery
if its too much of a hassle to do the GP kit, i can always just get the JCW kit and get the M7 spoiler
my car is royal grey so i dont even have to paint the entire car unless i want to do a color change
as far as engine performance i might just go with the MYNES pkg#2
thanx for the 411 peeps!!!
Old 10-01-2009, 09:04 AM
Bigshot Bigshot is offline
Gallery
Another great option is Revolution Mini Works and MINICorsa.
Please give them a call for more info.
Old 10-01-2009, 09:14 AM
JIMINNI's Avatar
Gallery
Quote:
Nope, it's Lake Forest. Right off Lake Forest Dr. I've been there
Old 10-01-2009, 01:14 PM
Gallery
^i think he meant M7 might be in Lakewood???
links?
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
MINI CooperMINI Cooper PrivacyMINI Cooper Terms of UseMINI Cooper Guidelines MINI Cooper Advertising The North American MINI Cooper Community
  MINI Cooper news, forums, FAQs, and reviews for enthusiasts and owners of the North American MINI Cooper
 Copyright © 2002-2008 North American Motoring. All Rights Reserved.     Powered by vBulletin and vBulletin Plugins by Drive Thru Online, Inc.
North American Motoring is an independently operated web site supporting MINI owners and enthusiastsworldwide. As such it has no official relationship with MINI USA, BMW AG, or BMW of North America.All original artwork and design is Copyright © 2002-2004 North American Motoring.
Admin Account Passwords
Search Engine Friendly URLs by vBSEO 3.5.2
