MINI Cooper MINI Cooper specs
MINI Cooper MINI Cooper Forums MINI Cooper Pictures
Mark Forums Read MINI Cooper radio MINI Cooper latest news
Go Back   North American Motoring > 1st Generation MINIs > JCW Garage
Sign in using an external account
Register Forgot Password?
Welcome to North American Motoring !
Welcome to North American Motoring,
» Latest Main Topics
Go to first new post My lifted mini is done!
by Moby911
38 Replies, 850 Views
Go to first new post NM Engineering torque arm...
103 Replies, 9,298 Views
Go to first new post Head Unit Upgrade
11 Replies, 1,714 Views
Advertisement
Thread Tools Search this Thread
Old 09-23-2009, 12:39 AM
jasmith001's Avatar
jasmith001 jasmith001 is offline
Send a message via Skype™ to jasmith001
Gallery
What should I do about a JCW brake job on R53 JCW?
Had a PPI done on the R53 JCW I am considering buying. Everything checked out with the exception of the brakes. They're original JCW brakes.
The front pads are low, almost to the sensor. And the rears are just about there, too.
The MINI dealer I did the inspection at recommended replacing the rotors, pads and sensors on the front ($706) and maybe the rears ($575).
I've factored this into the price of the car, but I've got another question for you JCW experts...
Since I'll be doing a brake service anyway, is there something else you'd recommend at the same time?
Fit different pads than the JCW ones?
Stainless steel brake lines?
Different brake fluid than usual MINI stuff?
Old 09-23-2009, 06:42 AM
-=gRay rAvEn=-'s Avatar
-=gRay rAvEn=- -=gRay rAvEn=- is offline
Modder-ator
Gallery
Garage
I would opt for the upgrade of the front disks to the JCW drilled rotors- Item # 34 11 6 777 826 for about $95.00 each...
I have had no issues with the stock JCW front pads and the JCW upgraded rear pads which would move me to other makes.
They can be purchased at a vendor here: Morristown MINI at:
http://www.trademotion.com/partlocat...catalogid=3751
And then there is always the ss brake line kits available from www.Outmotoring.com ( May even be a set for sale today in the Marketplace )
Brake Fluid MINI uses here at Inskip also comes with a 2 year warranty on brake parts/labor......They will do a flush of the system same time. IMO I would stick with what they use.
2003 R53 - DS - 135K + Miles
Parts of MINI NOT Modded ( A Shorter List ) Block/Head/HK Stereo.
Old 09-23-2009, 08:00 AM
cct1 cct1 is offline
Gallery
That's a ridiiculous price. For 1200 bucks, which is the total of what you're paying for front and rear, you could get an entire (and better) BBK.
If you track the car, don't get slotted rotors. They're just bling, don't add anything for performance (slotted is more debatable), and, more importantly, prone to cracking. If you're just driving it on the street, drilled is fine.
Stainless steel lines don't improve braking ability, but they do improve brake feel. If you track the car, it's worthwhile, if not, I wouldn't bother. (I recently had a brake line rubbing on the track--had it not been stainless steel, it probably would have been toast. So there is a safety measure there too.).
If you're in the least bit handy, I'd recommend doing the work yourself. Better than OEM rear rotors can be had for less than a hundred bucks (TSW), it's an easy installation. Fronts for the JCW are a bit more, shop around, but you're going to save so much money on what's a relatively easy job, it's worth it (Many DYI's on brakes here).
Pad choice and brake fluid really depends on what you do with the car.
Old 09-23-2009, 08:18 AM
Jeffsmashkot Jeffsmashkot is offline
Gallery
I recently did my front brakes. I bought Centric Rotors and Hawk HPS Street pads from Tirerack, plus I picked up a new sensor from Rockauto. I think everything in total cost me around 240 including two shipping fees.
Rear Centric rotors and Hawk HPS Street pads would run 135 + shipping.
The rears require some additional work since you need to rotate the piston while compressing, but you can get a tool for ~20.00 to do the job.
You might want to take the car elsewhere and get the brake fluid flushed and bled properly as it's a tough 1 man job.
1200 sounds like a HUGE rip off
2006 MCS JCW - Alta JCW Filter, Alta Short Shift Kit, GP Intercooler, Bilstein PSS9s, Camber Plates, Hotchkis Rear Control Arms, Joey Moded Xenons, Blacked-out Belt Line, Aero Grill, DT BBK, DT SS lines, DT Rear Caliper insersts, Ireland poly motor/gearbox inserts, Silicone Radiator Hoses
Pending - Boost gauge, Wireless Auto-Up Sunroof/Window controls.
Old 09-23-2009, 10:43 AM
Gallery
Actually bleeding the brakes is a piece of cake with a motive pressure bleeder, they cost about 60 bucks, with a pressure bleeder it's an easy one man job. On the other hand, any brake shop should be able to flush the brake lines for a reasonable price, just stay away from the dealer....
Old 09-23-2009, 11:20 AM
MINIdave's Avatar
MINIdave MINIdave is offline
Gallery
I put new pads and rotors on my '03 JCW last week, and since I've done several of these jobs for other club members I'm pretty used to the procedure. I swear, if I had a lift to get the car up off the ground I could change all 4 in less than 2 hours, easily. I spent as much time carefully jacking the car up and down on each side and removing/replacing the wheels as I did changing the pads and rotors.
This is one of the easiest jobs to DIY there is on the MINI, but it does require a few tools and techniques. For example, the Torx screws that hold the rotor in place (just a locator, the wheel nuts acturally hold the rotor on) tend to rust in and you need the right size Torx driver to remove them. I used my impact wrench set on low and they came right out (I did put some antisieze on them on installation for the next time) but if you don't have one they can be tough to remove if they're rusted badly. Soaking overnight with rust penetrant usually works tho......
You also need a 7mm allen to remove the caliper pins, and the aforementioned Harbor Freight tool to turn the rear pistons back in, plus various and sundry other metric sockets and such. However, it's very do-able, and I never have a problem buying new tools!
'09 LB/LB Clubman S
'69 Jaguar XK-E
'04 Audi Allroad Twin-Turbo
MMC#580
Let's Go Clubbin!
Old 09-23-2009, 11:49 AM
quikmni quikmni is offline
Gallery
You might want to check minimania.com because they are having a sale and if you call they might be able to give you a deal. If you go to their website, go to the suspension/brake upgrade section and then look for JCW Brakes (towards the bottom of the page of all their brake items). They have about 5 different JCW brake options (all 4 wheels) ranging in price from $660 - $825. I would call to see what price reduction they will offer.
2006 MCS JCW GP #1405: Adj Front Camber Plates, 19mm Rear Sway Bar, MM Front Lower Brace, Milltek Cat-Back, TCE 13" Front/11.75" Rear BBK, 15mm Spacers, Wheel Studs, JCM Modified Intake, MM Filter, Gauges
Old 09-23-2009, 08:01 PM
gmadeja gmadeja is offline
Gallery
MINIdave knows
+1
2005 CR/W MCS JCW, Aero kit, JCW suspension, LSD, JCW brakes w/ss lines & ATE Super Blue, H-Sport 19mm rear sway bar, SPC adjustable camber plates, O.Z. Superturismo GT 17x7 wheels, Yokohama ADVAN Neova AD08 205/45-17 tires, M7 front grilles, PIAA 1500 driving lights, Alta intercooler air diverter, Alta JCW air filter, Alta inlet hose, HK, MFSW w/aux gauges, Euro parcel shelf, Ian Cull auto-up circuit, MOMO shift knob, rear seat delete
Old 09-23-2009, 08:20 PM
MKIR53 MKIR53 is offline
Gallery
Hey MINIDave,
This is a tad off-topic but i have looked everywhere for an answer to this. (and according to gmedeja- "MINIDave knows")
i am having a JCW brake kit installed on my 03 MSC next week. I have been told that with the correct spacers and lugs i can still use my 15" snows. Would you happen to know what size spacers and lugs to use?
Or can you at least point me in the right direction?
03 MCS::BORLA RACE EXHAUST::ALTA CAI::17%HELIX PULLEY
25mm HOTCHKIS REAR SWAYBAR::AERO GRILLS::HELLA-500's
Old 09-24-2009, 06:30 PM
Modder-ator
Gallery
Garage
Maybe you should have read his post first
If you bothered to read his first sentence before spouting off your nonsense about Brembo's......which are terrible on the track btw....
The MINI he is writing about is one he is LOOKING AT TO PURCHASE which ALREADY HAS JCW BRAKES IN need of service....
Try reading the OP again.
Old 09-24-2009, 06:39 PM
Gallery
Still, he was quoted $1200 for OEM JCW Pads and Rotors... Which is ridiculous IMO
Old 09-24-2009, 07:54 PM
bratling's Avatar
bratling bratling is offline
Gallery
For context for the Dealer's (outrageous) quote, you can find a pair of front & rear brake wear sensors for $17 on eBay. And in general, disk brakes are one of the easier things to do on any car.
If you can get the seller to take off the $1200 the dealer quoted you from the selling price, awesome. But you can replace all the rotors, pads and the inexpensive sensors for far, far less than that, in just a couple hours of work in your driveway.
You should bookmark this list of how-tos, which includes:
Brake Pad (front pads) How-to (By OctaneGuy)
Brake Pad (rear pads) How-to (new by OctaneGuy)
(and as others have mentioned, for $1200 you can buy a very, very nice set of high-performance big brakes -- oversized rotors, pads and calipers with steel brake lines, which combined with some decent tires will suck the eyeballs right out of your face when you step on the brake pedal! )
((as much as i hate to admit it, i'm sometimes wrong. corrections are welcome!))
Old 09-24-2009, 09:34 PM
Rich.Wolfson Rich.Wolfson is offline
Gallery
Quote:
Originally Posted by jasmith001 View Post
.....Since I'll be doing a brake service anyway...
Here's a suggestion that you should consider. Purchase a set of jack stands, impact screwdriver for the stud, a set of Harbor Freight caliper tools and the key for the pins. Buy the OEM rotors and get either OEM JCW pads or Hawk HPS pads which are similar but give off less dust. I also like the SS speed bleeders to make bleeding easier. Use ATW blue fluid and next time get the gold. A pressure bleeder is nice if you think you'll do the brakes again.
Read the directions. Start in the morning on a nice day. Take your time. Find someone local that you can call in an emergency or pay him/her to sit watch and help if necessary. A beer or lunch would be the requisite payment.
The feeling you will have mid afternoon when you are done will be priceless. And the next time you do it, you'll have it done in less than two hours. It should be said brakes are the most straightforward easiest job to do. Rotate the tires while you are at it.
Where do you live? You may have a Mini or BMW club that will lend you the tools and the expertise if you ask.
Rich
Old 09-25-2009, 07:14 AM
Gallery
Never did I say anything about Brembo's...Maybe you should read MY post a little more clearly before spouting off nonsense about my posts?
Yes, I clearly understood he already had the setup--my point was you can get a brand new BETTER setup for the price of the replacement parts for the JCW kit. Should be an obvious point, but I guess it needs emphasis. I then recommended he just buy the rotors and install them himself, I don't recall recommending he buy a whole new kit. I don't recall that because, well, I didn't recommend that at all....
As for the track, I've run the JCW setup before going to what I have now, I know what it can (and can't) do. What I run now is not even in the same league.
Next time maybe try taking your medication before posting?
Old 09-25-2009, 08:47 AM
go_mini_go's Avatar
go_mini_go go_mini_go is offline
Send a message via Yahoo to go_mini_go
Gallery
Why are Brembo's terrible on track?
You could also consider using Ford HEAVY DUTY brake fluid. Works just as well as the more expensive stuff (on track too!) and you can get it at any Ford dealer. It comes in a blue metal can.
2005 MCS Jet Black
Old 09-30-2009, 08:52 AM
#20Works4me's Avatar
#20Works4me #20Works4me is offline
Gallery
Anyone have a part # for the Hawk HPS front pads? And rear for that matter...... I've been on a couple of sites and they list the same part # as a regular MCS . I've also considered Carbotech ceramic bobcats. Thanks in advance
2006 MCS JCW #20/64 Competiton Edition (Canada's version of the GP but only 64), JCW Suspension, JCW Brakes, JCW Body kit, JCW Engine & exhaust with JCW header, ITG Filter, Brisk Plugs, RMW Tuned @ 196WHP, JCW CF dash, shifter and ebrake handle. English Panther Leather, full load, JCW R112 Challenge wheels summer and R98 webspokes winter {sig pic by COOPERation}
Old 09-30-2009, 10:00 AM
Gallery
OEM Rear pads for the JCW are the same size/shape as the regular R53 brakes, just a different pad compound I believe.
Try these:
Hawk HPS Street Front: HB560F.677
Hawk HPS Street Rear: HB445F.610
Hawk HPS Front: HB560Z.677
Hawk HPS Rear: HB445Z.610
Old 09-30-2009, 10:40 AM
Gallery
Yep, the only difference on the rears for the JCW's is the pad material, the brake caliper itself is exactly the same, so the Hawk's would be the same on the rears regardless of wether it's JCW or not.
I haven't tried the Hawk's, but I can vouch for the carbotech's--they are a bit pricey, but very gentle on the rotors (although rear rotors are pretty cheap), and low dust. I currently use XP 10's or 8's on the rear (depends on the track), and I just leave them on during the summer, and put street pads (bobcats) back on after track season. Even the track pads are gentle on the rotors, the bobcats are low dust too, it's my favorite street pad that I've tried so far. In fact I'm going back to carbotech for both street and track pads for the fronts next year as well (TSW BDM brake kit). You can get carbotechs for the JCW kit (front brakes) too, I believe Dustin (autoxcooper) has them.
Old 09-30-2009, 11:05 AM
Gallery
For the Hawk HB560x.677 pads, x can be various letters, which indicate the different compounds:
F is the HPS Performance Street
G is the DTC-60 Race
N is HP Plus
Z is Performance Ceramic
Old 12-06-2009, 02:31 PM
Capt_bj Capt_bj is offline
Gallery
back to something on point....
if the dealer said the price included new sensors but the wear was "pads are low, almost (sic) to the sensor" then you should go someplace else for an evaluation cuz they is blowing smoke up your tail pipe.
The sensor is a consumable. If the warning light for brake wear has not come on, which it would not for wear ALMOST to the sensor, then there is nothing wrong with the sensor and it does not need to be changed. btw there is only one sensor per axle - front left and right rear wheels.
I realize this is an old post and info for OP is prob'ly OBE but for other readers FYI . . .
Capt BJ '79; 02 S {02 - 09}, 07 S
Old 02-02-2010, 09:43 AM
creseida's Avatar
creseida creseida is offline
Gallery
The problem is oftentimes the sensor gets broken while removing it. not every time, but often enough... you should include replacements in your estimates just in case...
Old 09-05-2010, 06:15 PM
Motorrr Motorrr is offline
Gallery
Most effective and least expense brake upgrade for ANY Mini, JCW or not;
EBC Yellow pads. Super Blue Brake fluid. If you track your Mini-I recommend Stainless brake lines for incredible brake modulation. Stock brake lines on the track are like having sex with a condom....no feedback.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
MINI CooperMINI Cooper PrivacyMINI Cooper Terms of UseMINI Cooper Guidelines MINI Cooper Advertising The North American MINI Cooper Community
  MINI Cooper news, forums, FAQs, and reviews for enthusiasts and owners of the North American MINI Cooper
 Copyright © 2002-2008 North American Motoring. All Rights Reserved.     Powered by vBulletin and vBulletin Plugins by Drive Thru Online, Inc.
North American Motoring is an independently operated web site supporting MINI owners and enthusiastsworldwide. As such it has no official relationship with MINI USA, BMW AG, or BMW of North America.All original artwork and design is Copyright © 2002-2004 North American Motoring.
Admin Account Passwords
Search Engine Friendly URLs by vBSEO 3.5.2
