MINI Cooper MINI Cooper specs
MINI Cooper MINI Cooper Forums MINI Cooper Pictures
Mark Forums Read MINI Cooper radio MINI Cooper latest news
Go Back   North American Motoring > 1st Generation MINIs > JCW Garage
Sign in using an external account
Register Forgot Password?
Welcome to North American Motoring !
Welcome to North American Motoring,
» Latest Main Topics
Advertisement
Thread Tools Search this Thread
Old 09-02-2009, 12:38 AM
lovethecorners lovethecorners is offline
Gallery
R53 JCW Suspension adjustment pin?
I thought I remember reading about some mythical "pin" on the JCW suspension that performed some adjustment (front camber perhaps?) I could be completely making this up, but wanted to check and see if anyone has any idea what I'm talking about.
Old 09-02-2009, 07:20 AM
-=gRay rAvEn=-'s Avatar
-=gRay rAvEn=- -=gRay rAvEn=- is offline
Modder-ator
Gallery
Garage
I have the JCW Sport Suspension too but never heard of any special adjustment pin.... ?
Maybe you are thinking of the Steering Angel Stops MINI purports to be needed for running JCW 18" rims ?
Part No. 32 11 0 303 293. ?
Although I have found these steering stops to be totally unnecessary, they are recommened by the dealer.
2003 R53 - DS - 135K + Miles
Parts of MINI NOT Modded ( A Shorter List ) Block/Head/HK Stereo.
Old 09-02-2009, 01:10 PM
quikmni quikmni is offline
Gallery
The rear camber is also adjustable at the lower control arms.
I do not know of any "pin".
2006 MCS JCW GP #1405: Adj Front Camber Plates, 19mm Rear Sway Bar, MM Front Lower Brace, Milltek Cat-Back, TCE 13" Front/11.75" Rear BBK, 15mm Spacers, Wheel Studs, JCM Modified Intake, MM Filter, Gauges
Old 09-02-2009, 02:30 PM
andyroo andyroo is offline
Gallery
You might be thinking of the free camber mod for R56 Minis.
2005 BRG MCS
Old 09-02-2009, 02:35 PM
Gallery
I wasn't thinking of the steering wheel stop limiters, although the R56 "slightly-adjustable" camber might be what I was thinking about. Damn. Thanks for the thoughts!
Old 09-02-2009, 03:54 PM
howsoonisnow1985's Avatar
howsoonisnow1985 howsoonisnow1985 is offline
7th Gear
Gallery
I read this under R56 threads, so not sure if this is only applicable to R56. Maybe pm the Dr. and let us know. I remember that in GRM got a small amount of camber somehow on R53, shifting the sub-frame or something? I'll go to garage to re-read article. But here is some of the R56 posts.
Quote:
Originally Posted by slinger688 View Post
Bump steer or suspension hop seems to be a rather common problem in the R56.
The last is to increase negative camber to make sure the tire contact patch is optimized in turns. This seems to work OK for camber around -1.4 (with adjustable camber plates). I think the pin removal method to get -0.5 may help.
Quote:
Originally Posted by Dr Obnxs View Post
Slinger688:
I think the pin removal method to get -0.5 (front camber) may help.Matt
Quote:
Originally Posted by jrs66 View Post
Matt,
Thanks for the well constructed synopsis... Lot of valuable info that people will undoubtedly will google for...
I've dropped the run flats... interested in what 'Pull pin and get a bit more negative camber.' means... does this mean i have to install some aftermarket camber plate? Will it violate my warranty? Dont mind paying for an aligment if it will help stabalize a bit.
thanks
that locates the top of the strut guide to the strut tower. You can pull this out with some pliers, looseing the three bolts, and move the strut guide plate in a bit. Basically, you're moving all the slop over to one side to get the top of the struts a bit more inward.
I honestly don't know how much of a difference it will make, but if you're going to get an alignement, might as well do that first.
Personally, I'm a very big fan of camber plates. It was my very first mod on my car long long ago. I do live in hills so a lot of my driving is on curvy roads, so more camber didn't increase my tire wear, it actually almost doubled tire life...Matt
2006 MINI Cooper JCW GP0019
RMW tune & cams*17% pulley*ITG filter*Brisk plugs*H-Sport Comp RSB*KMac camber plates*resonator delete*TSW studs/jack pads*H&R 5mm spacer*CT AX6 pads*Motul RBF600*RedLine*15x7 Motegi TrakLites2*Nitto NT01 205/50-15
BRG/W 2003 MINI Cooper S R.I.P. Sheila
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
MINI CooperMINI Cooper PrivacyMINI Cooper Terms of UseMINI Cooper Guidelines MINI Cooper Advertising The North American MINI Cooper Community
  MINI Cooper news, forums, FAQs, and reviews for enthusiasts and owners of the North American MINI Cooper
 Copyright © 2002-2008 North American Motoring. All Rights Reserved.     Powered by vBulletin and vBulletin Plugins by Drive Thru Online, Inc.
North American Motoring is an independently operated web site supporting MINI owners and enthusiastsworldwide. As such it has no official relationship with MINI USA, BMW AG, or BMW of North America.All original artwork and design is Copyright © 2002-2004 North American Motoring.
Admin Account Passwords
Search Engine Friendly URLs by vBSEO 3.5.2
