1. I do not know about the rotors but I like the Hawk HPS pads. Better performance and less dust than stock pads. Your plan should be better than OEM.
2. I just installed Hawk HPS pads on the rear and there was a slot for the wear sensor however I did not install the sensor (I just have it tie-wrapped up out of the way) because I have a Big Brake Kit (BBK) on the front with Hawk HPS pads that do not have a slot. There are no metal squealer tabs on the calipers to rub the rotor when the pads are worn.
3. Since you have worn through one of the two sensors (opened the circuit causing the light to turn on) you must replace the sensor or solder the wires together to close the circuit. I wore through my front sensor and since I was not going to use the sensor with the BBK, I solder the two wires together. Once the brake wear light is on, you must replace the worn sensor or solder the wires together (if not using the sensor), then you can reset the light and it will stay off. If you only wore through the front sensor the rear sensor will still be good to install in the new rear pads or you can tie-wrap the sensor out of the way if using pads without a slot.
4. I do not no of any other one time use parts. If you do not already know what sensor wore through (front or back) you might want to determine which one and order a new sensor or just order both sensors if you are not sure.
You might also want to buy a tool to compress the rear caliper piston because it must be rotated while being compressed. You can do it with a c-clamp and needle-nose pliers but the tool makes it easier. I brought the tool from Harbor Freight Tools for $20. http://www.harborfreight.com/cpi/cta...emnumber=40732
2006 MCS JCW GP #1405: Adj Front Camber Plates, 19mm Rear Sway Bar, MM Front Lower Brace, Milltek Cat-Back, TCE 13" Front/11.75" Rear BBK, 15mm Spacers, Wheel Studs, JCM Modified Intake, MM Filter, Gauges
