MINI Cooper MINI Cooper specs
MINI Cooper MINI Cooper Forums MINI Cooper Pictures
Mark Forums Read MINI Cooper radio MINI Cooper latest news
Go Back   North American Motoring > 1st Generation MINIs > JCW Garage
Sign in using an external account
Register Forgot Password?
Welcome to North American Motoring !
Welcome to North American Motoring,
» Latest Main Topics
Go to first new post Best FMIC
0 Replies, 1 Views
Go to first new post I did it!!!
3 Replies, 61 Views
Advertisement
Thread Tools Search this Thread
Old 08-23-2009, 12:29 AM
mini_mi mini_mi is offline
Gallery
R53 Brake Upgrade... so many choices
Hello,
I’m looking for help deciding on a break upgrade for my 2004 MCS. This is my daily driver and does not see any track time, however, I do drive it fairly hard. I've been eyeing the JCW big breaks sold by out motoring for $800. The look of these on the cooper is great and reading the forum postings it seems they are a fairly decent upgrade. Also read a couple postings stating that I could get these cheaper at a mini dealership.
What seems like a better deal is a brake upgrade kit that has 2 sets of rotors, pads, ss lines and fluid for $600. The kit in particular I was looking at contained EBC sport rotors and EBC greenstuff pads.
Thoughts on the 2 options? What about other options? Don’t have a problem spending money on a good braking system. What I do have a problem with is spending money on a system that is not going to be utilized.
Thanks in advance for all advice.
Old 08-23-2009, 01:37 AM
howsoonisnow1985's Avatar
howsoonisnow1985 howsoonisnow1985 is offline
7th Gear
Gallery
Not sure if you need pads and rotors? Or just want to upgrade, if the later I would just check out some "Auto-X" type pads like the Carbotech AX6 or Hawk HPS Plus pads, much better stopping power fro pads. If you need to replace rotors and pads, then JCW kit is hard to pass up considering they come with everything minus the rear rotor for only $598.00
JCW Brakes at Morristown MINI $598.00
http://www.trademotion.com/partlocat...catalogid=3751
Oh, I thought the EBC Green pads were more of a lateral move from stock, not and upgrade.
2006 MINI Cooper JCW GP0019
RMW tune & cams*17% pulley*ITG filter*Brisk plugs*H-Sport Comp RSB*KMac camber plates*resonator delete*TSW studs/jack pads*H&R 5mm spacer*CT AX6 pads*Motul RBF600*RedLine*15x7 Motegi TrakLites2*Nitto NT01 205/50-15
BRG/W 2003 MINI Cooper S R.I.P. Sheila
Old 08-23-2009, 08:14 AM
Gallery
Thanks for the reply!
Would the JCW kit fit with the following wheels?
16" wheels MSW type 16
Offset: +37mm
Backspacing: 5.51"
Bolt Pattern: 4-100
Rec. Tire Size: 195/55-16
Old 08-23-2009, 08:42 AM
DAVESTER's Avatar
DAVESTER DAVESTER is offline
Gallery
i have the EBC kit and love it. very little brake pad dust. just paint your calipers and have a very good looking and functional brake kit---
Deuce is a 2012 S Coupe CR/SLV JCW package, Cold weather ,and Premium packages. Rooser red color line, White turn signals, Piano black dash, Xenons, Black headlights, Black driving lights, Rear fog light
Old 08-23-2009, 09:19 AM
kazlot's Avatar
kazlot kazlot is offline
It's the journey...
Gallery
R53 Break Upgrade...so many choices
Offset: +37mm
Backspacing: 5.51"
Bolt Pattern: 4-100
If those wheels will fit a 2007 or newer MCS the answer is yes.
Hope this helps...
2006 BRG/W Works MCS
Old 08-23-2009, 12:47 PM
silversmoke06 silversmoke06 is offline
Send a message via AIM to silversmoke06
Gallery
Honestly I would just do the R56 Brake kit or the R53 JCW its the same thing.
its Low cost, in relation to other options
and with a set of stainless lines and high grip pads you really wont be able to claim you need more.
My R56 brakes will lock the wheels at pretty much any speed.
I can find the limit of traction quickly easily and safely.
its a very progressive kit.
the only thing i would reccomend on top of that
is removing your fog lights if you dont use them and putting brake ducts on them.
Jan from RMW ran his 262 hp stroker on the track like this and said he never found a limit to the brakes.
Danny of Mini Corsa also has 285 hp and still runs the R56 brakes.
Just my oppinion here
Old 08-23-2009, 02:17 PM
AutoXCooper.com's Avatar
AutoXCooper.com AutoXCooper.com is offline
Location: Car Nut Since 1987, Owner Since Fall 2005, Vendor Since Fall 2007
Gallery
I agree with Colin, the R53 brakes are fine with or without JCW setup for 99% of MINI drivers.
One thing I have learned is that braking "Style" as much more to do with braking performance then the hardware installed. I like to talk with MINI owners about braking style and demand in helping them pick a set of pads.
Old 08-23-2009, 02:30 PM
Gallery
I like that mine appear factory
Not yet has someone wandered over to my car and said nice brakes.
Though i do keep my aluminum calipers clean! and i have my centers painted factory gray.
Old 08-23-2009, 02:54 PM
Capt_bj Capt_bj is online now
Gallery
no one's said
"Nice brakes?"
'demz da breaks
Capt BJ '79; 02 S {02 - 09}, 07 S
Old 08-23-2009, 04:05 PM
Gallery
Nah and thats how I like it.
I may be somewhat persuaded to powdercoat them body color when i put nicer more open wheels on the car till then. Im just fine with them
OH and i havent added im still on factory R56 pad compounds
I cannot wait till i get some quality in there
Thanks to autocooperx for the lines though.
I need some rears now.
Old 09-19-2009, 11:16 AM
Motorrr Motorrr is offline
Gallery
If you don't track car, why spend the money for a "big brake upgrade"?
Yes, they look cool, but why dump money toward a purchase you won't use or appreciate?
Stock "S" brakes are very good. Even for spirited driving and autocrossing.
Like you, I spent countless hours researching Brake Upgrades for my S/JCW after experiencing brake-fade during a HPDE-BMWCCA School. Money was not an issue. What I discovered was EBC Yellow brake pads. Recommend by a UK challenge cup racer. I followed her advice. I have 20K on the front pads-two more HPDE schools and four track days. Exceptional stopping power, absolutely no fade, no noise, easy on rotors, and typical/stock brake dust.
I replaced the front pads only. Replaced stock brake fluid with ATE Super Blue. You will be so amazed with the difference from the stock brakes-and so happy with all the money you will save. $104 for the fronts and $14 for ATE Super Blue fluid at Moss Mini.
You won't be disappointed.
Regards, Motorrr
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
MINI CooperMINI Cooper PrivacyMINI Cooper Terms of UseMINI Cooper Guidelines MINI Cooper Advertising The North American MINI Cooper Community
  MINI Cooper news, forums, FAQs, and reviews for enthusiasts and owners of the North American MINI Cooper
 Copyright © 2002-2008 North American Motoring. All Rights Reserved.     Powered by vBulletin and vBulletin Plugins by Drive Thru Online, Inc.
North American Motoring is an independently operated web site supporting MINI owners and enthusiastsworldwide. As such it has no official relationship with MINI USA, BMW AG, or BMW of North America.All original artwork and design is Copyright © 2002-2004 North American Motoring.
Admin Account Passwords
Search Engine Friendly URLs by vBSEO 3.5.2
