I was going to pick up the rotors locally, to make sure they fit but after ordering the pads... I realized that they may not be right for the front set of JCW brakes I have.
Here's a picture of the front tires:
Here's a picture of the rear tires:
So, I guess my questions are this:
The front rotors... can I assume they're 294 x 22 JCW front rotors? If so, is any place going to stock them or should I go back to Tire Rack?
Are the front/rear pads I bought going to fit these brakes?
Should I replace the sensors too? Do I need to replace the entire sensor? If I don't replace them, will the yellow light ever turn off?
I am just trying to save some money.... local place wanted $1100 + tax for just the normal brake work... that's without them even knowing that I had JCW...
I don't like my dealership's service either so I'd rather pay more and go to Midas than them.
The JCW pads and rotors are larger than stock R53. The rear pads and rotors are stock R53 size. You need to verify that you have front pads for R53 JCW brakes (I suspect you do not have the correct front pads).
You should also figure out what sensor triggered the light, could be front or rear. You only need to replace the sensor that has worn through the contact.
2006 MCS JCW GP #1405: Adj Front Camber Plates, 19mm Rear Sway Bar, MM Front Lower Brace, Milltek Cat-Back, TCE 13" Front/11.75" Rear BBK, 15mm Spacers, Wheel Studs, JCM Modified Intake, MM Filter, Gauges
I got in touch with OutMotoring who was really helpful and they confirmed that the JCW brakes on R53 are exactly equal to R56 (S) brakes.
So I need the 294mm rotors for the JCW and R56 (S) pads... so yeah, the pads I have here are wrong.
