It's made to just clip on the opening of the JCW aero lower grill. It's a larger opening. I'm sure with a dremel and some imagination, you could probably make it work. I had to do some dremel work on it with the JCW aero bumper to get it to fit around the Alta IC...AND work with the M7 Ultimate Grill....but it looks great. I have pictures I will post soon.
__________________ http://www.sceniccityminis.net - 09 JCW-"MYSPHIT" - DS/BLK | JCW Areo & Brake Duct Kit | 30% Tint | Alta FMIC, 22mm Rear Sway | IE Fixed Camber Plates | TD Pro-Race 1.2 | TSW Springs | M7 JCW Ultimate Grill, CF Shift Knob | DoS CIA | NM Torque Arm Inserts, Charge and Discharge Pipes | 43et Kosei Racing Wheels (track setup).
Has anyone tried to build their own yet? I seem to remember a picture of the Challenge cars using the fog lights and 3" or 4" standard brake duct hoses. Could the aerokit ducts be used with better piping? I've seen one in person and I didn't have much time to check it out. I did see the lousy duct in the wheel well.
I looked into this quickly last year. On one side, can't remember it is the left of right, but right behind the fog light there is a tank/reservoir of some sort.
__________________ ''You can always get more money, but you'll run out of time"
