MINI Cooper MINI Cooper specs
MINI Cooper MINI Cooper Forums MINI Cooper Pictures
Mark Forums Read MINI Cooper radio MINI Cooper latest news
Go Back   North American Motoring > 1st Generation MINIs > JCW Garage
Sign in using an external account
Register Forgot Password?
Welcome to North American Motoring !
Welcome to North American Motoring,
» Latest Main Topics
Go to first new post MINI's on TV!!!
129 Replies, 4,320 Views
Advertisement
Thread Tools Search this Thread
Old 03-14-2009, 09:12 AM
Sorensen Sorensen is offline
Gallery
Camber,question???
I have a 2006 R53 JCW with adjustable camber (front). But I can´t find anywhere how much the camber on frontwheels should be. Right now they are on negative 1.60 degrees, but a normal Cooper S approx 0.40 degrees negative as standard measure. Can anyone give me approx measure on the frontwheels, how much is normal measure. The car is not for racing.
Old 03-14-2009, 11:26 AM
quikmni quikmni is offline
Gallery
Depends on how you want the car to handle vs. a little more tire wear. Most people with adjustable camber plates do not set the camber at a normal/stock setting. For best handling, most people run around -2.0 degrees on the front. However, that amount of negative camber will tend cause more wear on the inside edge of the tires especially depending on the amount of toe and how often you rotate tires (less toe = less wear). With or without negative camber my tires last less than 20,000 miles so a little extra wear due to negative camber does not make a big difference. I feel that the better handling is well worth a little less tire life.
I run -2.2 camber and slight toe-in on the front.
I run -1.6 camber (least I can get with stock adjuster) and slight toe-out on the rear.
My car is daily driver.
2006 MCS JCW GP #1405: Adj Front Camber Plates, 19mm Rear Sway Bar, MM Front Lower Brace, Milltek Cat-Back, TCE 13" Front/11.75" Rear BBK, 15mm Spacers, Wheel Studs, JCM Modified Intake, MM Filter, Gauges
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
MINI CooperMINI Cooper PrivacyMINI Cooper Terms of UseMINI Cooper Guidelines MINI Cooper Advertising The North American MINI Cooper Community
  MINI Cooper news, forums, FAQs, and reviews for enthusiasts and owners of the North American MINI Cooper
 Copyright © 2002-2008 North American Motoring. All Rights Reserved.     Powered by vBulletin and vBulletin Plugins by Drive Thru Online, Inc.
North American Motoring is an independently operated web site supporting MINI owners and enthusiastsworldwide. As such it has no official relationship with MINI USA, BMW AG, or BMW of North America.All original artwork and design is Copyright © 2002-2004 North American Motoring.
Admin Account Passwords
Search Engine Friendly URLs by vBSEO 3.5.2
