I want to get the JCW 3-spoke steering wheel. I have a two spoke with controls in my R53 and my question is- what to do with cruise control? I dont really care about not having radio controls but I do need cruise. Has anyone tackled customizing the the steering wheel or relocating cruise buttons and wireing ect...
I assume you want the carbon inserts then? Otherwise you can take the silver 3-spoke controls, they will work with an extra wire readily available from the dealer. See here for a DIY and numbers
I have made the original JCW carbon inserts fit with the MFST controls but is is tricky and a lot of work:
03 EB/W MCS - 255 bhp, Quaife dif, watercooled intercooler, M7 flywheel, big valve ported head, MTH manifold, R56 Superspint straight exhaust, Gruppe M CAI, 17% Alta V2 pulley, Bilstein PSS9 suspension, Tarox big brakes, all the JCW carbon and more, original GP dials, Helix camber plates, BBS rims with semi-slicks, ScanGauge II, Innovate EGT, AFR and Boost gauges, Powerflex mounts, MM PSA. Wiechers rollcage.
"I have made the original JCW carbon inserts fit with the MFST controls but is is tricky and a lot of work:"
I think it sounds more like a 2 spoke to 3 spoke conversion question.
If that's the case I think it's just a matter of ordering the parts and finding the matching plug, but I'd have to check RealOEM and confer with the Bentley manual before I'd say yes
good thread. I'm curious as to how you made the controls work on the cf spokes. I'm thinking of doing the same. Since I'm also going from 2 to the 3 spoke jcw. Either that or maybe it's possible to take the stock 2 spoke controls and attach them to the back of the jcw wheel ? I use my radio controls all the time and almost never use the cruise
__________________ Dinan S2 package, HRE's and too much more to list ! ;-)
I would suppose a paddle bit in a drill press would be the be method of drilling those holes. Prolly a pilot hole first with a small bit to get the center marked.....just guessing. Did you check out the DIY link Berthil posted?
There's more to it than just making the holes in the CF blends with a dremel.
The silver buttons are one with the silver blends, they have to be separated first. Here is a Google translation with pictures of my Dutch website of how I made the holes.
BTW, while I had them both in my had I measured, and the outside diameter is the same as the stock S wheel.
Aside from the stitching pattern, the only difference from stock wheel is that it is slightly thicker, and leather, rather than plastic.
"You can fool some of the people all of the time, and all of the people some of the time, but you can not fool all of the people all of the time." - Abraham Lincoln
