i would like to know if I take an R56 JCW SHIFT lights for my R53, I need another wire or not because in the first post I can read thanks
best regards
No problem and thanks for asking! If you order the Shift Indicator from us, we will include the necessary hardware, instructions and wiring details to allow you to install it on the R53 with success! PLEASE let me know how I can help in anyway further!
Thanks Adam got it installed wednesday, it is flush with R53 plate. I completly cut the little plastic protruding nipple off with a toe nail clipper, to make it flush. While at it added Start Button Panel, JCW Steering Wheel, and GPS. This Gear Shift Indicator is 10 times better than the old light, I set it at just 7k rpm, I figured by the time I shift it would reach close to redline.
__________________ 2006 MINI Cooper JCW GP0019
RMW tune & cams*17% pulley*ITG filter*Brisk plugs*H-Sport Comp RSB*KMac camber plates*resonator delete*TSW studs/jack pads*H&R 5mm spacer*CT AX6 pads*Motul RBF600*RedLine*15x7 Motegi TrakLites2*Nitto NT01 205/50-15 BRG/W 2003 MINI Cooper S R.I.P. Sheila
NICE!!! Glad that worked out! Thanks for the business!
Hi, i would like to order the JCW R56 shift indicator to my R53, should i order from the web page? and does the package comes with all the things needed to fi the R53? no other things must buy i mean
thanks
thanks
It's all you need parts wise, it will come with some wire taps. for tools you'll need something to cut it off of the old plastic and a Phillips head screwdriver.
ok thank, But i called alta and they send to Europe but the shipping is very expensive, so do you know what i need if i buy here the shif indicator to install it to my R53? do i need some wires or something like Alta provides?
Contact your local dealer, and just get the JCW shift indicator for he R56, it's all BMW/MINI factory parts. You may need to do a little parts research, but the dealer should be able to look it up without much issue.
I want to do it myself, because here there isn't BMWQ dealer because i live in an island, is why i asked, i saw on the ALTA SHIFT that they provide a T-taps and some males, nothing else i think, is it easy to install?
PM me your details. I am thinking we can sharpen our pencils a bit on the shipping. I have an idea to save you some money. Thanks!
