MINI Cooper MINI Cooper specs
MINI Cooper MINI Cooper Forums MINI Cooper Pictures
Mark Forums Read MINI Cooper radio MINI Cooper latest news
Welcome to North American Motoring, the North American MINI Community of owners and enthusiasts!
You are currently viewing our boards as a guest which gives you limited access to view most discussions, articles and photo galleries. By joining our free community you will have access to post topics, communicate privately with other MINI enthusiasts (PM), respond to polls, upload your own photo gallery and access many other special features. Registration is fast, simple and absolutely free so please, join our community today!
If you have any problems with the registration process or your account login, please contact our support team.
Go Back   North American Motoring > 1st Generation MINIs > JCW Garage
Not a member? Register now!
Welcome to North American Motoring !
» Main Menu
Upgrade Garage
» Latest Main Topics
Excessive carbon build-up in...
Show me your painted or BBK...
How-To Seafoam Treatment...
Stratosphere VMAXX?
Tis the season - Where can I...
300hub hp on a M45.... it's...
Bluetooth compatibility list
225/35/18 td 1.2 18x8 et 45
17x7.5 et35 pics
could BMW decide to kill off...
Advertisement
Vendor
 Aftermarket vendors
Thread Tools Display Modes
Prev Previous Post   Next Post Next
Old 10-02-2007, 08:41 PM
ADAMSALTAMINI's Avatar
ADAMSALTAMINI ADAMSALTAMINI is offline
Vendor
Gallery
ALTA / JCW shift indicator DIY for the R53/GP
folks, well Giusseppe was dying to get some mods to match his stablemate Howard! So one of the first things was the JCW shift indicator! Now at first this may seem like a simple task, but if you have looked at what JCW offers for the R53, you will see the problem. It is a dash mounted single sided indicator, that looks like dog-doo-doo vs. the R56 version that mounts on the column. SOOOOOO not content to stay with the norm, I decided to mount the R56 version on the R53 column. Here we go!
First call ALTA or go online to www.altaminiperformance.com and order up the JCW R56 Shift Indicator. Then indicate you have an R53 and you get the proper instructions, hardware etc. to match.
Second, when the package arrives you will get the indicator mounted on top of the R56 column plate. To begin, hack this piece apart. (I know sounds rough! Don’t be scared!) Remove the two screws that secure the indicator to the plate. Then pull the indicator away from the plate.
Then do this:
I used a set of dykes to simply open up a slot in the plate to release the wire.
Now, with the JCW indicator free from the clutches of the R56 plate, grab a set of wire cutters or similar and carefully cut a small slot in the side of the tube that protrudes from the bottom of the indicator. The slot is necessary to allow the wire to fold over instead of go down. (So this makes more sense, the end of this grey wire has a LARGE plug on it. As a result you can’t feed the wiring through the R53 plate. Instead we will run the wire under the indicator, then under the OEM tach or tach/speedo combo.) See photo below.
Disconnect the battery.
Remove the tach (or tach/speedo combo) from the column plate cover in your R53. Then remove the plate.
Now using the R56 plate as a guide, mark two small holes to be drilled into the R53 plate. (Don’t make these too big!!!!!) Then use the screws removed above to mount the indicator to the plate. And it will look like this photo below (note the new ALTA Gauge Pod/Gauge combo mounted as well!)
Ok! Now remove the lower knee protection panel from under the steering column. It has two small screws and two rather sturdy pop-it type fasteners at the top. PULL HARD!
This allows for mounting of the white control box for the indicator. Using the supplied wire ties strap it to the substructure under the dash.
Finally, locate the OBDII data port under the dash. Release it from the mount to get better access to the wiring leading away from it.
Using the ‘T-taps’ provided by ALTA, tap the following wires:
Green with Blue Stripe
Brown
White with Red Stripe.
Then using the supplied male ends supplied by ALTA connect the three wires leading away from the control box to the following:
Green wire on Indicator goes to Green with Blue Stripe
Brown to Brown
White to White with Red Stripe.
Using the BMW instructions flip the dip switches in the control box to 4-cyl, then choose a redline point. These are variable. On the GP I chose 7000 RPM.
Then re-install the top plate, tach etc. Re-connect battery.
Start engine. If the indicator is working, it will flash etc., then leave one green LED illuminated in the center.
Then steadily bring the RPM up toward the redline chosen to watch how the lights move from the inside out.
For a YouTube video go to ALTAminiperformance.com click on JCW OEM parts, then the indicator, then on videos.
Double check that everything is re-connected and bolted tight and enjoy!
Thanks!
Adam
ALTA MINI Performance
adam@altaminiperformance.com
NAM Handle ADAMSALTAMINI
FOR PHOTOS CLICK THE LINK FOR THE .PDF BELOW!
CLICK HERE FOR WEEKLY SPECIALS
Adam Taft: CEO ALTA Performance™
503.693.1702 Ex. 110
WWW.ALTAPERFORMANCE.COM
WebsiteBlogYoutubeFaceBookE-mailAIM
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
JCW gear shift indicator? gotmoxie JCW Garage 1 05-01-2008 07:10 PM
FS: JCW Shift Indicator System for R56 & R53/GP Hwydsgnr All other MINI parts and items for Sale (archive) 6 12-30-2007 03:59 PM
ALTA R56-R53 JCW SHIFT INDICATOR HOW-TO HERE! ADAMSALTAMINI Interior/Exterior 0 10-02-2007 08:44 PM
JCW Gear Shift Indicator minimaximini JCW Garage 2 05-16-2007 12:19 PM
JCW Shift Indicator Jersey_Bill JCW Garage 7 12-04-2005 01:19 PM
MINI CooperMINI Cooper PrivacyMINI Cooper Terms of UseMINI Cooper Guidelines MINI Cooper Advertising The North American MINI Cooper Community
  MINI Cooper news, forums, FAQs, and reviews for enthusiasts and owners of the North American MINI Cooper
 Copyright © 2002-2008 North American Motoring. All Rights Reserved.     Powered by vBulletin and vBulletin Plugins by Drive Thru Online, Inc.
Search Engine Friendly URLs by vBSEO 3.2.0
