Interior/Exterior Seat question - Airbag light?
I am considering changing my driver's seat for a race seat when I go lapping, or for for some Solo events. I am assuming that the Airbag lamp will go on, but my concern is that when I re-install the factory seat, will I have to re-set the airbag lamp, or will the car be able to do it for itself?
Any thoughts?
Any thoughts?
Get the same connector that is on the air bag harness on the seat. Solder a 3.9 ohm resistor to the pins. When you install the race seat, plug in the 'jumper'. When you're done with the race seat, remove the seat, unplug the 'jumper', install the factory seat and plug in the stock harness. If you do this with the car turned off, you shouldn't trip the SRS light.
07-16-2020 12:54 PM
DWooderson
R60 :: Countryman Talk (2010-2015)
08-10-2015 09:12 AM
quality_sound
08-07-2015 09:36 AM
