MINI Cooper MINI Cooper specs
MINI Cooper MINI Cooper Forums MINI Cooper Pictures
Mark Forums Read MINI Cooper radio MINI Cooper latest news
Go Back   North American Motoring > 1st Generation MINIs > Modifications > Interior/Exterior
Sign in using an external account
Register Forgot Password?
Welcome to North American Motoring !
Welcome to North American Motoring,
» Latest Main Topics
Go to first new post New CooperS Owner
1 Replies, 2 Views
Advertisement
Thread Tools Search this Thread
Old 09-03-2006, 06:46 PM
creseida's Avatar
creseida creseida is offline
Gallery
HT Remove Handbrake Handle?
Can anyone tell me how to remove the handle from the emergency brake? Thanks
Old 09-03-2006, 06:48 PM
Motor On's Avatar
Motor On Motor On is offline
Community Servant
Gallery
Garage
MINI2 has the detailed DIY basically 4 clips on the base of the E-brake boot push down they come of slide up boot and release tabs on the handle covered by boot tseparates into 3 pieces. Will post link soon.
Edit: Can't find link I can put together someinthing more detailed later tonight if need be.
-Drew MMC#282
Follow NAM on Facebook
Old 09-03-2006, 09:20 PM
creseida's Avatar
Gallery
That would be great if you could post the how-to. The ebrake boot is already off (made a new leather one to replace the stock vinyl) I want to remove the handle itself and cover that in leather too.
Old 09-03-2006, 09:44 PM
Motor On's Avatar
Community Servant
Gallery
Garage
Well seeing as no body else responded I'll go get some photos. I swapped out the silver for a chrome handle so it would match the shift knob, the tip broke so it's been half silver half chrome for a while. I'll fix it and post the pictures in a few minutes.
-Drew MMC#282
Old 09-03-2006, 10:27 PM
Motor On's Avatar
Community Servant
Gallery
Garage
uploading pics now
-Drew MMC#282
Old 09-03-2006, 11:40 PM
Motor On's Avatar
Community Servant
Gallery
Garage
Okay there are 6 tabs squeeze in and lift out the base of the boot, then cut the zip ties and slide the boot up and off.
as for the handle itself, I usde a small screwdriver and pushed the side tab off the pice closet to the button in and removed that section then pull the bake as far up as possilbe
there are two tabs that need to be depressed a small screwdriver can help with this as well, tonight I couldn't get them to budge and ended up pulling the whole thingstraight up by accudent, I broke off some of the guide tabs, but on reassebly I didn't hurt anything that will interfere with function. Also a screw driver and a little leverage and the plastic with the leather pattern will slide off at this stage, so you can do a direct replacement with the leather.
Note the sperated piece on the seat.
Assembly is pretty much opposite of install.
Hope this helps, any questions and I'll do what I can to answer.
-Drew MMC#282
Old 09-04-2006, 12:06 AM
rkw rkw is online now
Gallery
I've taken the handle off when I installed a leather e-brake boot. I used the instructions at OutMotoring.com: http://outmotoring.com/How_to_ebrake_boot.htm. motor on's photos and instructions are also very good.
Old 09-04-2006, 12:13 AM
Motor On's Avatar
Community Servant
Gallery
Garage
That may have been what I went of fof the first time. I did it 6 months ago with instructions from somewhere so tnioght I just went off of memory and did what worked. And was motivated to fix something! Wohoo!
-Drew MMC#282
Old 09-04-2006, 06:36 AM
creseida's Avatar
Gallery
Thanks guys!
Old 02-12-2010, 02:30 PM
lhoboy lhoboy is offline
Gallery
The link to outmotoring is broke. Can anyone provide instructions how to remove e-brake handle?
SPUD:['02 JCW (210hp) - PS/B], '05 6 sp.trans/LSD, aux. gauges, driving lamps, fr/rr fogs, NAV, PDC, DSC, iPod Adaptor, Sport Link, GP IC, JCW susp., brakes & brace, 15% , LDG tune, short shifter, DT-BPV
Buzz: ['09 JCW - MY/B] Prem. Pkg., Cold Weather Pkg., IPod/B-tooth, JCW Susp., Xenon, HI-FI, Rear Fogs, Nav, PDC, JCW Brace & Side Scuttles, Driving Lamps, Alarm, Pulsar
Old 02-16-2010, 04:52 PM
TX1911fan TX1911fan is offline
Gallery
Try this
http://www.mossmotors.com/graphics/p...01_102-710.pdf
Old 02-17-2010, 03:44 PM
sddave's Avatar
sddave sddave is offline
Gallery
I replaced the boot on mine from the vinyl one to a leather one when I first got my MINI. It is really easy, it took me about 5 minutes to change mine out. I have a pictogram on how to do it. Let me see if I can find it and I will post as soon as I can find it.
If I remember correctly, the metal ring twists off and the handle then slides off...but I am remembering from 3 years ago...I have a hard enough time remembering what I had for breakfast today.
Old 02-18-2010, 04:29 AM
Gallery
Let me know if you find the pictogram. The MINI service advisor quoted an absurd figure to replace the worn boot with an OEM replacement, also claiming that 9 times out of ten that the plastic handle would break during the process and require replacement as well. I decided to go with a leather boot as well and do it myself, but would like to avoid the purchase of a new plastic handle.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
MINI CooperMINI Cooper PrivacyMINI Cooper Terms of UseMINI Cooper Guidelines MINI Cooper Advertising The North American MINI Cooper Community
  MINI Cooper news, forums, FAQs, and reviews for enthusiasts and owners of the North American MINI Cooper
 Copyright © 2002-2008 North American Motoring. All Rights Reserved.     Powered by vBulletin and vBulletin Plugins by Drive Thru Online, Inc.
North American Motoring is an independently operated web site supporting MINI owners and enthusiastsworldwide. As such it has no official relationship with MINI USA, BMW AG, or BMW of North America.All original artwork and design is Copyright © 2002-2004 North American Motoring.
Admin Account Passwords
Search Engine Friendly URLs by vBSEO 3.5.2
