Interior/Exterior No Holes License Plate Bracket
Hi everyone:
My newly purchased R53 is currently in the shop for a new valve body but I am thinking about buying this no holes license plate bracket when I get her back. https://www.amazon.com/Cooper-HOLES-.../dp/B00F8O9ESC
How does this look? Unfortunately I live in a state where a front license plate is required. Sure looks better than drilling holes though.
Thanks!
Thanks!
Thanks! I will most likely order it. Can't wait to get the car back! The F55 (I think) loaner I have has a nice smooth ride but I totally miss my R53.
if you are the least bit handy you can make one for about $10 in bits from ACE Hardware. Start with a BIG bolt that matches the diameter and thread pitch of the towing hook .... you want something 4 inches long or so. Then a couple of washers and nuts .... maybe a flat piece of metal to form a backing plate.
Easy!
I decided to move to a no front plate state however ....
Easy!
You can also get a twofer on the Craven tow hook and fab a plate from some mild steel to reuse the stud - super easy, just cut a tab to angle it and drill the mounting holes. On the track/show just pop off the plate and install the hook - no need to unthread the stud, so you can locktite it solid.
Thanks, everyone. As an update, I ended up just buying the Platypus one on Amazon because I am not the most handy. Sounds like it won't arrive until Wednesday but that is fine considering my plates haven't even arrived yet.
Also ordered a set of floor mats that should arrive today.
The car is running much better than before. Replacement valve body seems to really help.
STX (Street Touring X) r53 JCW daily driver/STX build
ojannen
SCCA Solo and ProSolo
59
09-11-2018 05:50 AM
