Interior/Exterior Where to pick up 12v ignition in engine compartment
Old 11-15-2014, 09:12 AM
roadrunner255's Avatar
roadrunner255
roadrunner255 is offline
Hello all, I am trying to find a 12volts switched ignition source in the engine compartment for the power source on my LED fog lights (parking light and not the actual fog light).
Cant see to find one.
Cheers!
Old 11-15-2014, 11:30 AM
cerenkov's Avatar
cerenkov
cerenkov is offline
You can tap the DME connector.
It is the #2 pin on the X60004 plug (red with white strip IIRC). The third connector closest to the radiator.
Old 11-15-2014, 12:58 PM
roadrunner255
left or right side?
I'm looking in the manual for the connector.
Attached Thumbnails Where to pick up 12v ignition in engine compartment-20141115_155328.jpg   Where to pick up 12v ignition in engine compartment-20141115_155348.jpg
Old 11-15-2014, 01:22 PM
cerenkov's Avatar
cerenkov
cerenkov is offline
The connector is under this cover.
WARNING: Tapping into this connector is at you're own risk and is not for the faint of heart.
Attached Thumbnails Where to pick up 12v ignition in engine compartment-image-3776359901.jpg
Old 11-15-2014, 01:37 PM
roadrunner255
Thanks I'll take a look, other option is doing the add a circuit to the fuse box to the right.
I saw some posts on that.
Cheers!
Old 11-17-2014, 07:13 AM
roadrunner255
So I decided to tap off a fuse in the fuse box with the add-a fuse, any suggestions on which fuse is better to tap off of?
Thanks all!
Old 11-17-2014, 07:48 AM
Capt_bj's Avatar
Capt_bj
Capt_bj is offline
you know, your safest bet is to use a relay and then you have no worries about the load added to an existing circuit ...
get your 'full power' by running a line from the fuse panel 'hot in' cable, thru an inline fuse to a relay ... then power out from the relay to your added goodie. Get the power for the switch side from a switched circuit via the add-a-circuit or just tapping something simple line the cig' lighter / aux power port.
basically this:
led should not draw much power but this isolates the new load . . .
Old 11-17-2014, 01:04 PM
roadrunner255
Thanks, I am just looking for a switched 12v source, LED light has a relay incorporated. F2 is the headlight washer which I do not have. I will check to see if there is power.
Cheers!
Old 11-23-2014, 11:15 AM
roadrunner255
Thanks all!
Has anyone had an issue using the add a tap and not being able to get a switched 12V source?
I verified that the radio did not have power after removing the fuse. But, when I add the add a fuse, the added circuit always has power even with no key in the ignition.
Very strange, all fuses behave the same way and I have tried another add a fuse.
Anyone know what the blue connector is on the left of the fuses in the attached photo? I maybe able to find a switched 12v there.
Any help would be great!
Cheers!
Attached Thumbnails Where to pick up 12v ignition in engine compartment-inside_fuses_mc.jpg
Last edited by roadrunner255; 11-23-2014 at 12:13 PM. Reason: added comment and photo
07-16-2020 12:54 PM
alistaircookie
10-08-2015 10:52 AM
Shane Wendel
Electrical
08-20-2015 06:50 AM
milkrun49
Factory JCW Talk (2009+)
08-13-2015 06:01 AM
SDMini_me
08-07-2015 08:10 AM
Quick Reply: Interior/Exterior Where to pick up 12v ignition in engine compartment
