Interior/Exterior Scangauge II vs PLX DM-100
Hi guys. So I Seafoamed my MCS about 2 weeks ago and on the 3rd treatment the car threw a CEL most likely from the o2 sensor. Apparently the CEL would go away on its own after a while according to other members but it still has not. So I was thinking of buying an OBDII scanner just to clear it but for a bit more I can get the ScangaugeII or the PLX DM-100 and have other useful data readouts. I live in California btw, where Autozones, Kragens etc. no longer check or clear CEL's.
Does anyone have any info regarding the Scangauge vs the PLX DM-100? Are both of them simply plug-and-play through the OBDII? Thanks!
Hi guys. So I Seafoamed my MCS about 2 weeks ago and on the 3rd treatment the car threw a CEL most likely from the o2 sensor. Apparently the CEL would go away on its own after a while according to other members but it still has not. So I was thinking of buying an OBDII scanner just to clear it but for a bit more I can get the ScangaugeII or the PLX DM-100 and have other useful data readouts. I live in California btw, where Autozones, Kragens etc. no longer check or clear CEL's. Does anyone have any info regarding the Scangauge vs the PLX DM-100? Are both of them simply plug-and-play through the OBDII? Thanks!
Answer my own Q: After more investigating looks like the plx dm100 uses a cigarrette lighter adapter for power thus, i dont think battery drain would be an issue.
Mach V Dan
07-25-2007 10:07 PM
