MINI Cooper MINI Cooper specs
MINI Cooper MINI Cooper Forums MINI Cooper Pictures
Mark Forums Read MINI Cooper radio MINI Cooper latest news
Go Back   North American Motoring > 1st Generation MINIs > Modifications > Interior/Exterior
Sign in using an external account
Register Forgot Password?
Welcome to North American Motoring !
Welcome to North American Motoring,
» Latest Main Topics
Go to first new post R53 issues
11 Replies, 472 Views
Go to first new post SHOW us your MINI stripes
586 Replies, 114,802 Views
Advertisement
Thread Tools Search this Thread
Old 12-01-2003, 11:15 AM
mexminime mexminime is offline
Send a message via Yahoo to mexminime
Gallery
I´ve been searching but haven´t found if there´s any DIY instructions for the roof decals.
I just ordered the UJ roof decal from my dealer, but really don´t want to pay extra to get it installed, they rip you off with the labor.
My car doesn´t have a sun roof.
Is this something easy to do? What tools do I need and what prep should I do before the install?
Old 12-01-2003, 11:29 AM
MotorWorf's Avatar
MotorWorf MotorWorf is offline
Gallery
Try this site:
DIY Decals
_________________
Fix it 'til it breaks
Old 12-01-2003, 11:52 AM
kenchan's Avatar
kenchan kenchan is offline
Gallery
a good rubber squeegee and some dishwash soap solution light mixture in a
spray bottle will do the trick. :smile: wax your roof after it dries (minimum 24hours).
try not to use your fingers to squeegee the decal as it can swirl it.
Old 12-01-2003, 11:57 AM
Cnbyates Cnbyates is offline
Gallery
I would also suggest getting a friend to help out! And, be patient!
Cyndy
Old 12-01-2003, 12:46 PM
Griswoia Griswoia is offline
Gallery
so lets say that you have a few (like three) small bubbles after application. What is the best way of gettin ghtem out? This is in a sunroof cover. They are all under 1cm diameter, so no biggie, but is there a fix?
Old 12-01-2003, 04:00 PM
kenchan's Avatar
Gallery
under 1cm dia? that's a pretty big bubble. but you could pierce it with
a needle and squeegee the solution out, or see if the sun can do the job.
usually the sun can take out small bubbles and shallow/short bubbles.
it depends on how bad the bubble is and where it is.
when i apply decals on the car and if for some reason i really screw it up,
i usually peel it off while spraying more fluid before the adhesive settles.
but, if the adhesive is already attached to the surface, don't pull as it will
stretch the decal. either wait for the sun to do its thing or pierce it and squeegee.
worst thing to do is heat it and squeegee'ing at the same time. permanent
ripple.
_________________
03MCS IndiBlue/Blk
<a href="http://hometown.aol.com/t
Old 12-02-2003, 06:47 AM
doomsdaybob's Avatar
doomsdaybob doomsdaybob is offline
Gallery
Cooper Flags has a DIY kit now w/ instructions for thier products but should work w/ factory too. Give Matt a holler.
Honey, do you have my keys again? Honey? Hon? Where are you? WOMAN, If I wanted to drive this Honda I would have bought my own!
Old 12-02-2003, 10:11 AM
Gallery
Thanks for all the help. How exactly am I supposed the soap/water solution?
I just waxed my car, should I do anything to it to remove the wax layer?
Old 12-02-2003, 10:18 AM
kenchan's Avatar
Gallery
yah, you should take the wax off with the soap/water solution before
you start.
what i do is get a small spray bottle and put 2 drops of dish soap
(Dawn or Ivory) in the bottle and fillup the bottle with tap water.
some guys like to use distilled water as it takes out any chances
of rings between the decal and panel (specially tint guys)...but
usually the soap takes care of that.
Spray the soap/water solution on your waxed panel and wash
off all the wax, dry. then re-spray the panel with the same soap/water
solution. then spray your fingers (both hands), then remove the
backing off the decal while you spray more solution on the decal
itself. the trick is to keep your fingers wet at all times while you
handle the decal.
afterwards, towel dry lightly and let dry for 24hours... then wax.
_________________
03MCS IndiBlue/Blk
Old 12-05-2003, 03:14 PM
Gallery
So the roof has to be wet with soapy solution when I apply the sticker, right?
I´m guessing this allows you to move it around before the sticker glue dries out.
Old 12-05-2003, 03:45 PM
kenchan's Avatar
Gallery
right, both the roof and the adhesive backing needs to be wet. and your
fingers as well while handling it. yep, you will be able to move it around while
the backing is wet.
Old 12-08-2003, 11:57 AM
Gallery
Thanks so much Kenchan,
I´m waiting for the decal to arrive at the dealer, supposedly tomorrow.
I´ll post pics, promise
Old 12-10-2003, 08:44 AM
Gallery
The directions with mine said no solution so I didn't use any. Thus the bubbles are air only. I am hesitant to pierce, but it's damn winter and the sun aint doin' nuthin'. . .
Mom's a nurse so maybe I'll pierce with a 25 gauge hypo and syction it out. . . anyone try this?
Old 12-10-2003, 09:14 AM
resmini resmini is offline
Gallery
Griswoia,
You were able to but a roof decal on with no liquid? That's amazing, where did you get the decal and how bad are the bubbles you're speaking of?
Cooper flags says to use denatured alcohol to remove the wax before applying, at least for the stripes. I'm sure the same would apply for the roof decal. I was kind of hesitant to put the suff on my paint. But I did and it worked OK. When applying my stripes I noticed the wetter the surface the better. My window tint guy uses baby shampoo instead of the dish washing liquid. He says there's something in the dish washing liquid that over time reacts with the glue in a bad way. Two or three 3 second squirts from the baby shampoo into a 16 ounce bottle should be about the right mix. Anyway, as has been said, make sure both the decal and the roof are very wet before applying and squeege from the center out.
Get a good helper and good luck. :smile:
R.E.
Old 12-11-2003, 10:52 AM
kenchan's Avatar
Gallery
the sun won't do much than to expand theat airbubble inside the decal, probably.
the sun/heatlamps work well to rid solution between the panel and decal,
but air bubbles are kinda tough to get out. may take weeks before the
air dissepates through the material. i would perce it before it snows or
something and you accidentally touch it to make a crease.
yah, baby shampoo is a good solution too. ive yet to have problems
with the dish soap solution, but it could be because the mix is very light
(lots of water vs soap). as long as the solution dries completely, i don't
foresee any problems.
_________________
03MCS IB/Blk: 123, Aerokit, R90 17x7, TK5 16x7, 6CDMP3, and a few more.
Old 12-11-2003, 01:22 PM
Gallery
I use to do mounting in a print shop so there are only about three bubles in the sunroof. Each under 1cm. The roof has been on for a while (like three weeks) and I guee that I will get a syringe. . . I'll tell you later.
Ian
Old 12-11-2003, 04:39 PM
Gallery
I just picked up the decal at the dealer. It is a flat cardboard package the size of the MINI´s roof, yet to my surprise when I opened it (of course that huge piece of cardboard was never going to fit inside the MINI unless bent) I discovered that ...
THE UNION JACK COMES IN PIECES!
Only the center cross section of the flag comes in one piece. All other parts are individual stickers.
Guess it´s going to be quite a challenge to install (I´ll have to measure and calculate all the distances so it will look simmetrycal.
I´ve got myself something to do for my next week vacations
Old 12-11-2003, 05:16 PM
kenchan's Avatar
Gallery
Griswoia - im impressed! just 3 little airbubbles installing it dry.
mexminime- goodluck with it.
i use masking tape to measure and kind of layout the
decal first so that it would be real easy to aim where the
decal should go after taking off the backing. (i dont have
the roof decal though).
Old 12-12-2003, 08:49 AM
Gallery
Last night I studied the whole thing and I think I was freaking out with no reason.
The most important thing to measure is the center cross, and it will probably be wise to install it first and let it dry completely before installing the rest.
The other parts come together into four pieces that match exactly with the edges of the cross.
Its like those comic books that came with stickers (rembember those?)
Hopefully by Monday everything will be in place. Promise to post pictures
Old 12-12-2003, 06:21 PM
Minimad Minimad is offline
Gallery
couple things,
auto parts stores carry wax & grease remover by 3M, or another called Prep-All. this will strip all wax off the surface & assure adhesion.
you were told how to float it on with a soap solution, but what if you want it to lay down immediately & adhere?
Then you should have another solution bottle of 50/50 h20 & rubbing alcohol. That will make it stick right away. but be sure you have it placed right!
Old 12-12-2003, 09:37 PM
Gallery
Thanks for the tip.
I feel more comfortable now that I found the oem installation instructions down on MINI2.
Old 04-05-2004, 12:07 AM
miniredeye miniredeye is offline
Gallery
Does the antenna get in the way? I haven't gotten the car yet but I will have the shark fin.
Old 04-05-2004, 03:07 PM
Gallery
Don´t know about the shark fin, but I guess it works the same as the standard one. The antena actually works to center the red cross in the Union Jack. first you just unscrew the antena. The base is easily removed by turning it 45 degrees to any side and popping it out.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
MINI CooperMINI Cooper PrivacyMINI Cooper Terms of UseMINI Cooper Guidelines MINI Cooper Advertising The North American MINI Cooper Community
  MINI Cooper news, forums, FAQs, and reviews for enthusiasts and owners of the North American MINI Cooper
 Copyright © 2002-2008 North American Motoring. All Rights Reserved.     Powered by vBulletin and vBulletin Plugins by Drive Thru Online, Inc.
North American Motoring is an independently operated web site supporting MINI owners and enthusiastsworldwide. As such it has no official relationship with MINI USA, BMW AG, or BMW of North America.All original artwork and design is Copyright © 2002-2004 North American Motoring.
Admin Account Passwords
Search Engine Friendly URLs by vBSEO 3.5.2
