Interior/Exterior Summary of R55, R56 light bulb types
Old 01-10-2011, 04:07 PM
minimike21's Avatar
minimike21
minimike21 is offline
that helps alot! thanks
  #27
Old 01-29-2011, 03:49 AM
wxviewer's Avatar
wxviewer
wxviewer is offline
Hello,
According to your picture, the tail light/brake light is a W5W? (#7)
Just wanted to make sure that was accurate. That bulb needs to be a double filiment doesnt it?
And thanks again for the Bulb guide.
  #28
Old 01-29-2011, 04:02 AM
DjR53's Avatar
DjR53
DjR53 is offline
great guide! gotta love the bulb conversion too
  #29
Old 01-29-2011, 08:54 AM
gagamel's Avatar
gagamel
gagamel is offline
Originally Posted by wxviewer
Hello,
You're correct. It is P21W. Bulb #7, #8, #9 are all P21W...
I just updated.
Thanks a lot!!!
  #30
Old 01-30-2011, 06:53 PM
minimike21's Avatar
minimike21
does anyone know if nokya sells a yellow W5W bulb... for some reason i cant find any yellow w5w bulbs for my driving lights to match the fogs i got.... am i missing something?
  #31
Old 02-11-2011, 03:29 PM
MNMLST's Avatar
MNMLST
MNMLST is offline
Load resistors
Are load resistors necessary for this mod?
My tail lights are smoked and I'm considering a 5- or even a 7-watt LED for my brake lights. Perhaps, combined with a pulser.
  #32
Old 02-12-2011, 08:51 AM
rederik's Avatar
rederik
rederik is offline
great guide!
  #33
Old 05-03-2011, 02:39 AM
ontoama's Avatar
ontoama
ontoama is offline
r56 Leds
Which vendor(s) did you get them from, will the bulb warning go on when you replace the tail lights? Mine are all just going so I would like to replace the ones on my R56 MCS instead of getting incandescent ones.
  #34
Old 11-14-2011, 06:54 PM
walk0080's Avatar
walk0080
walk0080 is offline
Are there more interior bulbs in a 2011+ R56?
Checking out Coopersport/Bimmian and their kits indicate R55/R56 2007-2010 have 13 bulbs, 2011+ R55/R56 have 15 bulbs. 13 bulbs looks correct for an R55 but where do the extra 2 bulbs go I wonder?
  #35
Old 12-03-2011, 01:10 PM
d@g's Avatar
d@g
d@g is offline
Thanks for posting the reference list. I was shocked (ish) to see that my owner's manual had it wrong. It listed a W5W for the brake/tail lamp.
  #36
Old 12-05-2011, 10:55 AM
walk0080's Avatar
walk0080
walk0080 is offline
Nevermind - I didn't realize the 2011+ cars have two extra interior lamps on the ceiling for rear passengers I assume.
  #37
Old 12-05-2011, 10:58 AM
walk0080's Avatar
walk0080
walk0080 is offline
Has anyone figured out what bulbs are used in the sun visors? They are so yellow they are almost orange - and practically useless.
  #38
Old 01-21-2012, 02:17 PM
MiniAJ's Avatar
MiniAJ
MiniAJ is offline
Bump. For an old but good post.
Kstenson728 (05-12-2022)
  #39
Old 01-28-2012, 04:10 PM
bksmith76's Avatar
bksmith76
bksmith76 is offline
according to the PDF the R56 license plate bulbs are 6411 but I just bought some and they are 1/4" longer than the oem and don't fit... any idea what the true size is?
#### just found out the real size of the license plate bulb on R56 is C5W ####
  #40
Old 05-15-2012, 12:23 PM
Hubs's Avatar
Hubs
Hubs is offline
I agree C5W is what is on my 2007 MCS . Just pulled the two bulbs out and looked at them. Having the error message light bulb with exclamation point ! the last couple of days and at first could not find a exterior bulb out till looked closely and license plate .
Picked up some bulbs at my local auto parts store paid $2.90 for 2 bulbs . GE Standard 12v (6418) C5W/BP2 . I believe the C5W is the C for size and 5W stands for 5 watts.
  #41
Old 09-01-2012, 09:22 AM
walk0080's Avatar
walk0080
walk0080 is offline
  #42
Old 11-12-2012, 02:28 PM
xJamesP's Avatar
xJamesP
xJamesP is offline
Originally Posted by gagamel
Hello folks,
I have changed most of yellow stock bulbs to bright white SMD LEDs on my 2010 R55 Mini Cooper Clubman.
All LEDs were ordered from Ebay sellers in USA or Hong kong.
Total cost was around $60 (including license plate and driving light. No bulb-out error. only $30 without license plate and driving light).
and
I made a list of light bulb types for R55 and R56 with pictures. Lamp replacement guide from Sylavania.com is so confusing and sometimes shows wrong bulb type(like 9003 for Mini cooper clubman headlight!!).
This list explains how many bulbs and what type of bulbs are installed in our Mini.
Let me know if there is any error on the list.
LED is the light of the future. It will replace our headlight soon^^
gagamel
Thanks for this!!
Just send this to a friend is that ok?
  #43
Old 08-15-2013, 12:58 AM
easypop's Avatar
easypop
easypop is offline
Awesome job!!
Thanks a lot
  #44
Old 08-15-2013, 03:59 AM
danjreed's Avatar
danjreed
danjreed is offline
I realize this is an old post. But I thought I'd add that for 2013 I used 11 w5w/194 LEDs for my interior. $10 from eBay. You don't need CANBUS LEDs for the interior. I did not bother to swap the glovebox.
Not sure where more bulbs could possibly go..
  #45
Old 09-23-2013, 07:24 AM
r56Ter-Bow's Avatar
r56Ter-Bow
r56Ter-Bow is offline
So which ones require the canbus bulbs?
  #46
Old 09-23-2013, 07:30 AM
walk0080's Avatar
walk0080
walk0080 is offline
  #47
Old 11-07-2013, 06:18 PM
walk0080's Avatar
walk0080
walk0080 is offline
  #48
Old 11-14-2013, 01:06 PM
FIRESTARTER's Avatar
FIRESTARTER
FIRESTARTER is offline
Any idea what bulb is in use on the R56 hatch reverse light? I have the JCW Aero kit with a single reverse light.
921 bulb
  #49
Old 05-10-2014, 09:49 PM
Rub0's Avatar
Rub0
Rub0 is offline
Great help thank you very much i just have one question i looked at the 5w5 lights on ebay and some of them are bigger than the other how would i know which one will fit in my courtesy, glove and map
  #50
Old 11-30-2014, 06:48 AM
Lex2008's Avatar
Lex2008
Lex2008 is offline
Sylvania bulb 7506 for r56 rear turn signal is better choice
Dude you are a good and decent human being! Thanks for putting in the effort. Sylvania's web site does indeed bit the big gherkin.
For the REAR Turn signals on R56, the Sylvania 7506 (clear bulb) fits better into the socket than the 7507 (yellow bulb). They also give slightly different light, but its subtle.
7506 is a better choice.
Much appreciated.
Quick Reply: Interior/Exterior Summary of R55, R56 light bulb types
