MINI Cooper MINI Cooper specs
MINI Cooper MINI Cooper Forums MINI Cooper Pictures
Mark Forums Read MINI Cooper radio MINI Cooper latest news
Go Back   North American Motoring > 2nd Generation MINIs > Modifications > Interior/Exterior
Sign in using an external account
Register Forgot Password?
Welcome to North American Motoring !
Welcome to North American Motoring,
» Latest Main Topics
Go to first new post My lifted mini is done!
by Moby911
39 Replies, 900 Views
Advertisement
Thread Tools Search this Thread
Old 11-10-2009, 01:00 PM
gmarch gmarch is offline
Gallery
Adding a mechanical boost gauge
Hi all!
Just got my 2010 JCW on Friday, and I'm loving it!
I've been searching through the forums, but I guess I just don't understand how the search engine works - the results are never really what I'm looking for. Even putting things in quotes or using +'s doesn't work. If someone can educate me off line, I'd appreciate it.
I'm looking for a mechanical boost gauge that will complement the three gauge cluster (I have the "relative torque" and "coolant temp" gauges straddling my tach). An a-pillar mount would be fine.
Alternatively, I'd give up the relative torque gauge for a matching boost gauge.
Can someone point me to resources I can look at for coming up with a solution? I've seen references to some "$70 boost gauge install", but can't actually find the reference. There was something from a website called "s-w", but the links are broken.
Also, that Rev2 app for the iphone sounds cool, but I just got the Driod... And, I'm not too keen on an electronic boost gauge. I learned that lesson when overboosting an Eclipse back in the 90's. :-) But, I'd be interested in other apps like that for monitoring engine stats.
Thanks...
/greg
Old 11-10-2009, 04:46 PM
pilotart's Avatar
pilotart pilotart is offline
Gallery
Best way to search NAM is to put something like this into your Google Search Block:
boost gauge site:http://www.northamericanmotoring.com/forums
"boost gauge" or whatever keyword/s you want.
On my last car, I ordered a Boost Gauge (believe it was 'SW') from JC Whitney @ $29.95 and mounted it in the dash,
it had an internal light (choice of color) that had to be connected to dash lites and a vacuum line that could be plumbed into almost any manifold source.
Worked great.
http://www.northamericanmotoring.com/gallery/data/500/Rt-Rear_Thumbnail_Web_view1.jpg28April2008, 'Trixy' Cooper Automatic+Sunroof+AutoAir+HiFi+CruiseControl+15" Rotator Six Spoke
Mods: European Center Armrest+Wet Okole w/Lumbars over 4" Memory Foam(see Gallery)+XM-Radio+ScanGauge II
Old 11-10-2009, 05:10 PM
Thomas S's Avatar
Thomas S Thomas S is offline
Gallery
Matching gauges for your Mini
Quote:
Originally Posted by gmarch View Post
Hi all!
Thanks...
/greg
Hi Greg -
Start here:
http://www.northamericanmotoring.com...ry-gauges.html
Tom S
Old 11-12-2009, 05:56 AM
Gallery
Thanks Guys...
Wow. What a long winded thread just for a boost gauge. :-)
Still haven't quite found what I'm looking for, but I'll keep at it. When I did this last time around, it was basically a simple "here's your options, pick and choose". I guess there are a lot more options now. Then again, there was a really strict moderator on that list, and he didn't let any noise get posted. Not that I'm sayin' there's a lot of noise here, or anything. Just reminiscing. :-)
Cheers!
/greg
Old 11-12-2009, 09:12 PM
Rowdy Rowdy is offline
Gallery
Im a fan of the marshall gauges. My mech. boost gauge looks very close to the factory tach/speedo combo and you can get in on the group buy for ones that are a perfect match if you like too. The reason they get expensive is based on mounting. A lot of mini motorists do not want to drill holes or cut up dashes or pillars. I have the craven speed bracket and cups. Works fantastically. Theres also the problem of a vaccum/boost source for the gauge. You're pretty much stuck puying one of the sandwhich adapters that fit between the Map sensor and the intake manifold and tee off a line.
Best of luck
Winston - 2009 chilli red MCS
Old 12-08-2009, 10:00 AM
SRTech SRTech is offline
Vendor
Gallery
Marshall Gauges Group Buy
The Group Buy is still on through the end of December. New items in RED.
Group Buy Prices:
Vac/Boost, 30" Hg - 30 PSI (mechanical) $47.50
Vac/Boost, 30" Hg - 30 PSI (stepper) $102.50 (now with peak recall and warning)
Oil pressure, 0-100 PSI (electric) $59.50
Oil pressure, 0-100 PSI (stepper) $83.50
Water temperature, 100-260°F (electric) $53.50
Water temperature, 100-260°F (stepper) $77.50
Dimmer for stepper gauges $25.00
Oil temperature, 140-310°F (electric) $60.50 (only a few in stock)
Oil temperature, 140-310°F (stepper) $84.50
Voltmeter, 0-18V (electric) $48.50 (only a few in stock)
Voltmeter, 0-18V (stepper) $63.50
Oil pressure, oil temperature and water temperature gauges include the sending unit with 1/8" NPT connection.
Stepper motor gauges have peak recall and warning functions.
Shipping is $10 in the lower 48 states. Hawaii, Alaska and non-USA destinations will be determined individually.
The CravenSpeed mounting and adapters are going to be 10% off list price for this group buy. If you have any other CravenSpeed requests, I will offer 10% off those items during this group buy. Anyone with existing CravenSpeed mounts should be aware that the new mounts are powder coated instead of anodized so they won't match perfectly. I still have a few anodized pieces in stock so let me know.
Gauge Cup (52mm) gen1 and gen2 $49.00
Gauge Cup (dual 52mm) gen1 and gen2 $71.00
Bracket X (gen1) tach mount for cups $30.00
Bracket ZL (gen1) cup mount for chrono/nav $40.00
Bracket ZR (gen1) cup mount for chrono/nav $40.00
Bracket A (gen2) cup mount $45.00
Bracket R (gen2) single cup mount $40.00
Cup Caps (52mm) caps for back of cups $26.00
Tapless Adapter (gen1) oil pressure adapter $44.00
Tapless Adapter (gen2) oil pressure adapter $67.00
Hot Link (gen2) water temp adapter $54.00
PSIClone (gen2) vac/boost adapter $35.00
Please e-mail your billing and shipping addresses to gaugegb@blackoaks.com. Be sure to include your phone number and the gauges and mountings you want to buy. I will e-mail you an invoice for you to OK and then you can call me or vice-versa for the CC info. Some have e-mailed me the CC info which is OK if you are comfortable with that. I do not bill until I ship. You can call me if you have questions at 559.320.0004 Thanks.
Steve
2005 EB/W MCS - M7: 16% pulley, DFIC, AGS (V3), OCC, USS, STB, APD, Coilovers; Cosworth head, Schrick Cam; Alta: 2% pulley; Bosch 400cc Injectors; MSD Coil; Kingsborne Wires; Brisk DR12S; Wilwood 11.75"; 17x7.5 SSR Comps; Helix Control Arms (4); B&M SS; Hotchkis comp. swaybar, camber plates; PowerGrid endlinks; CMS Exhaust; Mynes Tune; 202k miles. custom mini shop
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
MINI CooperMINI Cooper PrivacyMINI Cooper Terms of UseMINI Cooper Guidelines MINI Cooper Advertising The North American MINI Cooper Community
  MINI Cooper news, forums, FAQs, and reviews for enthusiasts and owners of the North American MINI Cooper
 Copyright © 2002-2008 North American Motoring. All Rights Reserved.     Powered by vBulletin and vBulletin Plugins by Drive Thru Online, Inc.
North American Motoring is an independently operated web site supporting MINI owners and enthusiastsworldwide. As such it has no official relationship with MINI USA, BMW AG, or BMW of North America.All original artwork and design is Copyright © 2002-2004 North American Motoring.
Admin Account Passwords
Search Engine Friendly URLs by vBSEO 3.5.2
