MINI Cooper MINI Cooper specs
MINI Cooper MINI Cooper Forums MINI Cooper Pictures
Mark Forums Read MINI Cooper radio MINI Cooper latest news
Go Back   North American Motoring > 1st Generation MINIs > Modifications > Interior/Exterior
Sign in using an external account
Register Forgot Password?
Welcome to North American Motoring !
Welcome to North American Motoring,
» Latest Main Topics
Go to first new post New CooperS Owner
1 Replies, 16 Views
Advertisement
Thread Tools Search this Thread
Old 04-14-2009, 01:47 PM
mscmagno mscmagno is offline
Gallery
Spray paint 6 pc dash.
hi. do any tried painting ther dash? i'm think to spray paint my dash to a glosy black with design to it, and im not sure what kind of paint should i use?
do i have to sand the dash first before spray painting it? so the paint will stick or just spray it. and what kind of spray paint should i use, any suggestion?
Old 04-14-2009, 02:24 PM
ChrisMCS04's Avatar
ChrisMCS04 ChrisMCS04 is offline
Peace Keeper
Send a message via AIM to ChrisMCS04
Gallery
Well, when I did it I fully removed the dash(obviously) then I took some of the green scotch brite pads and used them to sand away the stock paint(it is surprisingly thin) and then I used alcohol to clean it. After that I used tac cloth to take away any dust that had settle. Next is the priming paint. Any neutral color will work or the same color of what you are putting down(depends on the effect you are looking for). Let that cure, then tac cloth it again. Spray the first layer.(then how ever many corresponding layers you are desiring). Let cure. Lastly, tac and spray with clear to protect.
I used the exact paint code to my exterior paint and bought a pint from NAPA. I wanted some nice stuff because I did a reallly nice paint job. I spent a week on it.
But, to each their own and how ever complicated you want to make it is up to you...this was my Christmas break project
Old 04-14-2009, 02:30 PM
MINIdave's Avatar
MINIdave MINIdave is offline
Gallery
I'd think if you're just going for black, some of that Kyrlon made for plastic would work well, just follow Chris' intructions above to the letter and you should be good to go....
I'm seriously thinking of brightening up the interior of my Clubby too......
'09 LB/LB Clubman S
'69 Jaguar XK-E
'04 Audi Allroad Twin-Turbo
MMC#580
Let's Go Clubbin!
Old 04-14-2009, 04:41 PM
nabeshin's Avatar
nabeshin nabeshin is offline
Functioning Lunatic
Gallery
Garage
I would love a Piano Black dash, but I think that's a 3 piece.
On a related note, some interior parts of my car are meant to look like brushed aluminum. Has anyone thought of trying to get real brushed aluminum for these parts? I don't know how you'd cover the dash parts or if you could make new aluminum parts that are direct replacements, but It should add class.
9/29/2002 EB/W MCS Broken - temporarily retired
Original owner since 2002.
Old 04-15-2009, 02:48 PM
Gallery
GOOD TIPS guys, i really do apprciate your reply. just one more question, you said "Next is the priming paint. Any neutral color will work or the same color of what you are putting down(depends on the effect you are looking for)." if i want a glosy or mirror like effect what primer paint should i use?
Old 04-15-2009, 04:11 PM
-=gRay rAvEn=-'s Avatar
-=gRay rAvEn=- -=gRay rAvEn=- is offline
Modder-ator
Gallery
Garage
Instead of Primer, I use Adheasion promoter for all plastics. Really works awesome, but is clear, but should not be a problem with black.
I have also used a 2000 grit wet sanding on plastics as well. Nothing too corse as it will come up on the newly painted surface.
I would clear coat any painted plastics too. It will make it look like the piano black finish.
Dupont Clear Acrylic Lacquer is available from professional paint retailers and works awesome. I coat all my mirror caps with that.
Just don't breathe it in, and make sure you have plently of fresh air where you do it. It's about 16-17 bucks a can.
2003 R53 - DS - 135K + Miles
Parts of MINI NOT Modded ( A Shorter List ) Block/Head/HK Stereo.
Old 04-15-2009, 05:01 PM
ChrisMCS04's Avatar
Peace Keeper
Gallery
The primer is more of a concern when you will have it make an effect "through" the other layers of paint...like with a "candy" paint job...
for yours, you can just use a black primer.
The mirror/glossiness will come from how well you do your layer of "normal" paint after the primer and how well you do the clear coat...
Just take your time and it will be nice and shinny!
Old 04-16-2009, 12:10 PM
CrazyIvan's Avatar
CrazyIvan CrazyIvan is offline
Send a message via Yahoo to CrazyIvan
Gallery
If you have the alloy patina there is a film on top of the actual plastic that can and will bubble up after you primer or paint it. After i seen this I let my dash pieces soak in a plastic safe paint remover called easy lift off. Take a scotch bright pad to remove the film. Major PIA. the door panel pieces didn't seem to have the film.
But afterwords it looks 100% better
Ramius 02 MCS, 05 trans with Torsen LSD, Act C/FW ,Alta intake, 15% S/c pulley,2% M7 Crank pulley, Bmp header, Magnaflow CB, Alta IC,PSRS,end links, rear control arms. Eibach front and rear sway bars and Megan Coil overs and Swift Springs.
Old 04-16-2009, 01:05 PM
MINIdave's Avatar
Gallery
What about just wrapping them with vinyl?
'09 LB/LB Clubman S
'69 Jaguar XK-E
MMC#580
Let's Go Clubbin!
Old 04-16-2009, 04:05 PM
Fatherdeth's Avatar
Fatherdeth Fatherdeth is offline
VILLAIN
Send a message via AIM to Fatherdeth Send a message via Skype™ to Fatherdeth
Gallery
Garage
Thanks Ivan. I too have the Patina Alloy and want to paint the pieces black. Your wisdom will now show me the way.
~Lilith~ 2005 MINI Cooper S **Enjoy Your New Home**
Old 04-16-2009, 05:13 PM
CrazyIvan's Avatar
Gallery
No problem.
Old 04-21-2009, 01:50 PM
Gallery
need help removing the air bag piece cover, i was able to remove the other piece but when it come to the air bag part, im having trouble, can you guys tell me what i can do, i already removed the 3 screw holding the bottom part, but when i try to lift it somthing is holding it inside the top part is some how attach to somthing inside when i look at it. im scared if i put to much force to it my air bag will deploy or i wont be able to put it back the same way.. i'm all ready to sand the other piece and pait it, its just i cant do it due to the air bag part wont come off...
Old 04-21-2009, 02:14 PM
CrazyIvan's Avatar
Gallery
Need to remove the upper dash pad. There are two bolts you need to remove. before you can pull the airbag cover off. Be careful the metal pieces a very sharp.
Old 04-21-2009, 02:34 PM
Eric_Rowland's Avatar
Eric_Rowland Eric_Rowland is offline
Gallery
Quote:
Get a torx driver and a bit of patience.
You need to remove three screws from the bottom of the airbag cover (don't confuse them with the two or three screws for the glovebox, which are in close proximity) Then remove the top of the dash (two torx on either side, underneath plastic panels which just pull off.) From there there are three more torx on the top, as well as two nylon retention straps that require a 10mm socket - the one on the right is tougher to get to - use an extension.
After ALL the screws are out, lift up on the bottom (if you get any resistance, check for more screws) and the cover will pivot out. Note that in the top are three green plastic screw retention pieces. These just LOVE to fall out and subsequently fall in behind the glovebox as you wriggle the cover out. Be warned!
Note that it is a breakaway cover, so don't force anything, or you can find it breaking away unexpectedly. Only handle the frame where the screws go through.
'04 IB/W MCS w/all the goodies, Ian's auto-up/GDO, MMC#I69/MID CURV169; power folding mirrors
"You can't save the world unless you're willing to make other people sacrifice." - Dogbert, via Pendergast
Old 05-04-2009, 05:16 PM
Gallery
okay i'm planning to get my dash painted by proffesionals since i want ti piano black effects, but now i want to know how to take the ring trim for teh speedometer and oddometer? any idea, isit only a twist or pry or is their a screw i have to take it out, if i succecefuly removed the trim do i need some kind of glue or somthing to put it back?
Old 05-05-2009, 02:43 PM
chaseabryant chaseabryant is offline
Gallery
It sometimes depends on your year. Mine was able to be pried away from the front, however, other years are actually glued in place, so you will have to remove your trim that surrounds the speedo and air vents.
-Chase
<a href=http://i4.photobucket.com/albums/y119/chaseabryant/MINISignature11.jpg target=_blank>http://i4.photobucket.com/albums/y11...ignature11.jpg</a>
RIP 2003 MCS DS/B
Old 05-05-2009, 03:55 PM
Gallery
well what years is yours? mine is 2003 MCS.. do you think i can pry it out? cuz im scarded that im might have problem putting it back after i paint it..
Old 05-05-2009, 05:58 PM
MLPearson79's Avatar
MLPearson79 MLPearson79 is offline
Moderator
Gallery
Garage
I don't believe the speedometer trim ring comes off, at least not in my 06. It's attached to the whole big black face piece behind it.
Here is a thread that should help you - it's actually a DIY on changing gauge faces but it tells you how to get to and remove the pieces you're talking about.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
MINI CooperMINI Cooper PrivacyMINI Cooper Terms of UseMINI Cooper Guidelines MINI Cooper Advertising The North American MINI Cooper Community
  MINI Cooper news, forums, FAQs, and reviews for enthusiasts and owners of the North American MINI Cooper
 Copyright © 2002-2008 North American Motoring. All Rights Reserved.     Powered by vBulletin and vBulletin Plugins by Drive Thru Online, Inc.
North American Motoring is an independently operated web site supporting MINI owners and enthusiastsworldwide. As such it has no official relationship with MINI USA, BMW AG, or BMW of North America.All original artwork and design is Copyright © 2002-2004 North American Motoring.
Admin Account Passwords
Search Engine Friendly URLs by vBSEO 3.5.2
