How To R53 Drivetrain :: Oil Catch Can How-To
Old 11-01-2007, 08:58 PM
polizei's Avatar
polizei
polizei is offline
Like Scottinbend said, it would probably be fine, but I clamped mine down just to make sure. I would advise you to do the same.
-Cody
  #27
Old 11-02-2007, 07:57 AM
MiNi_MaC's Avatar
MiNi_MaC
MiNi_MaC is offline
Originally Posted by ScottinBend
It should just slide into the OCC line and then you can use a small hose clamp to keep it in place. It is under vacuum so it would probably stay in place without it. Are you going to hook-up the other line to the can also?
Thanks... no im just doing the gray line... i thought it was not the best set up
-Cody
Old 11-02-2007, 04:57 PM
ScottinBend's Avatar
ScottinBend
ScottinBend is offline
The set-up you have will work just fine......you will still get a bit of watery-oil into the IC with just the grey line connected, but it isn't as big a problem as the oil from the grey line is.
  #29
Old 12-15-2007, 04:23 AM
Marwan's Avatar
Marwan
Marwan is offline
Now pops up a question, do we really need OCC? I do street race generally and never tried autocross. Does the OCC make any performance defference?
  #30
Old 12-15-2007, 08:54 AM
polizei's Avatar
polizei
polizei is offline
From my findings, honestly...no. Now, that being said, I don't really push my MINI hard all the time, and I don't race at all, so it's a little different for me. However, the last time (~2months ago) I had my IC off, there was no fluid, but there's none ever in my OCC either...I would suggest cleaning it ever 50k miles or so and you'll see some build up.
-Cody
  #31
Old 12-15-2007, 03:13 PM
JedzMCS's Avatar
JedzMCS
JedzMCS is offline
in the aspect of mods making power or freeing up more hp, no. in the aspect of efficiency down the road, yes. no one likes oil to gunk up the intercooler, throttle body, spark plugs, etc.
  #32
Old 03-17-2010, 07:38 PM
DMBFan2's Avatar
DMBFan2
DMBFan2 is offline
-Cody
I know this is an old thread and topic but....What does an OCC actually do? You said that there is no difference in hp or performance so whats the benefit and what is the difference between the types of catch cans? Are they just that - cans-? No internal filter, just a can?
  #33
Old 08-15-2016, 05:30 PM
Dennis Bratland's Avatar
Dennis Bratland
Dennis Bratland is offline
How is the oil mist going to condense when the can is located directly above the exhaust manifold? Even with the heat shield, it seems like one of the hottest places under the hood.
  #34
Old 01-11-2020, 06:57 AM
Grand-Cayman's Avatar
Grand-Cayman
Grand-Cayman is offline
Super old thread, but replying anyway...
The OCC captures oil vapor before it runs back through the intake system. If you take your intercooler off (and you have 20k+ miles on the car), you'll see oil that has accumulated on the surfaces. This reduces the ability of the intercooler to do its job (cool the air). Plus, if extreme, it can reduce air flow.
Regarding location of the OCC above the exhaust...not a problem IMO. It should not get hot enough to vaporize/boil the oil.
  #35
Old 01-20-2020, 01:41 PM
MiniManAdam's Avatar
MiniManAdam
MiniManAdam is offline
Just a side note..to simplify it..just install the can inline with the pcv valve . You can use a Barb fitting into the stock line and then you don't have to remove the intercooler . See my attached pic.. hope this helps make things easier for someone .
  #36
Old 08-17-2020, 08:02 AM
Serafin's Avatar
Serafin
Serafin is offline
An fittings
Hello. Anyone know what size threads for the PCV valve. I would love to replace my rubber house with stainless braided lines and AN FITTINGS.
Cleaner and for show. A good right angled an fitting would be great.
RandyBMC
How to
112
02-08-2020 11:13 AM
nshannon29
06-29-2017 02:55 PM
Jaydavid
36
05-09-2013 01:47 PM
abuzavi
36
06-30-2008 04:58 AM
imortalsin84
02-05-2008 11:40 AM
Quick Reply: How To R53 Drivetrain :: Oil Catch Can How-To
