How To DIY Requests....
Old 11-22-2013, 02:52 PM
Kongfish's Avatar
Kongfish
Kongfish is offline
Yea, just remove the clutch start safety override button that should be located behind the clutch if it is like most cars.
  #127
Old 12-27-2013, 08:29 AM
MTB235's Avatar
MTB235
MTB235 is offline
Looking For a How To on Clutch Replacement on an R53.
I have an 2004 S, but I'm assuming there all the same from 02-05.
So far the only thing I've seen is that the VALEO OE CLUTCH KIT is the best bang for the buck. Other than that I'm not seeing much.
Any Help would be greatly appreciated.
**Answering My own Question (See below link)**
http://www.pelicanparts.com/techarti...eplacement.htm
  #128
Old 12-29-2013, 09:54 AM
DrDubya's Avatar
DrDubya
DrDubya is offline
JCW ECU Map using GT1 or SSS
I have all the software and a cable just need to know how to load the JCW map on my 06MCS R53 for the 380cc injector upgrade
  #129
Old 01-19-2014, 09:10 AM
gokartowner's Avatar
gokartowner
gokartowner is offline
Replacing front and rear struts on 2007 Cooper
  #130
Old 07-15-2014, 07:09 PM
O4mcs's Avatar
O4mcs
O4mcs is offline
Removing exterior door handles r53
  #131
Old 06-09-2019, 02:28 PM
pierini1's Avatar
pierini1
pierini1 is offline
what do I need to do to swap a JCW engine into an s
I have a 2002 JCW engine with low millage that I would like to put into my 2006 r53. I figure that i need to put the JCW computer in, but are there any other issues that I need to be aware of? I am guessing that My existing Borla exhaust will mate up?
  #132
Old 06-09-2019, 06:06 PM
BlwnAway's Avatar
BlwnAway
BlwnAway is online now
Everything should match up as long as you use your existing transmission and all mounts from the 2006.
And no, you won't need the ECU from the 2002, your ECU will adapt just fine to the small differences in the engines.
  #133
Old 06-09-2019, 07:57 PM
pierini1's Avatar
pierini1
pierini1 is offline
thanks for the info
elverado
01-18-2022 02:51 AM
M7Speed
10-01-2015 07:05 AM
whowantstorace
09-27-2015 06:16 PM
Tires, Wheels & Brakes
09-16-2015 06:45 AM
09-14-2015 12:48 PM
Quick Reply: How To DIY Requests....
